some errors after upgrading 1S0937087D bcm to 1S0937090F
Re: some errors after upgrading 1S0937087D bcm to 1S0937090F
Great! 8)
H2Deetoo
Drives: VW UP/Passat B6
Post by H2Deetoo »
I also put in some illuminted window switches without chrome. Still waiting on China :(
Regards,
Bonny
H2Deetoo
Post by H2Deetoo »
For completeness here is my current vcds log:
Wednesday,04,November,2020,20:44:40:00008
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAAZED094213   License Plate:
Mileage: 111360km-69195mi   Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 02 03 09 10 15 17 19 25 44 56 AD
VIN: WVWZZZAAZED094213   Mileage: 111360km-69195miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 020 AN    HW: 04C 907 309 N
   Component: R3 1.0l MPI   H23 9104
   Revision: UOH23---
   Coding: 00140012022400000000
   Shop #: WSC 00900 211 00000
   ASAM Dataset: EV_ECM10MPI01104C906020AN 001008
   ROD: EV_ECM10MPI01104C906020AM.rod
   VCID: 67DD0D9C9E6DDC727C-8032
Readiness: 1110 0001
Address 02: Auto Trans (J514)       Labels:* None
   Part No SW: 0CT 927 750 A    HW: 0CT 927 750 A
   Component: SQ100         H10 0013
   Coding: 010120
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMSQ101011 004010
   ROD: EV_TCMSQ101011_004.rod
   VCID: 4683E018F9A7E57AA7-8012
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 E    HW: 1S0 614 517 E
   Component: EBC 460 ESP   H08 0012
   Serial number: A00IP1V
   Coding: 12BF24718BB602F548FC24F6D1AC404059B200
   ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
   ROD: EV_Brake1ESPMP1TRWVW120.rod
   VCID: 3169A3C4602952C262-8064
Address 09: Cent. Elect. (J519)       Labels:. User\1S0-937-09x-V1.lbl
   Part No SW: 1S0 937 090 F    HW: 1S0 937 090
   Component: BCM PQ25 1MX4 H81 0744
   Revision: BW081001    Serial number: 0978 215160666
   Coding: 7AB82B0000010000090800446DEBBCC830C040FD608B2400200000400100
   VCID: 366390D8814775FA37-8062
   Subsystem 1 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS 090608 04  46  0204
   Coding: 033025
   Subsystem 2 - Part No SW: 6R0 959 591 B    HW: 6R0 959 591 B
   Component: J245 PS72.023  H02 0007
   Serial number:     WOO26347321
   Coding: 181100
   Subsystem 3 - Part No SW: 2H0 959 442     HW: 2H0 959 442   Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 29170001883980077353
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Sx-919-475.clb
   Part No SW: 1S0 919 475 A    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0009
   Revision: --------    Serial number: 32901402003642
   Coding: 100101
   ASAM Dataset: EV_EPHVA14VW1200000 001008
   ROD: EV_EPHVA14VW1200000.rod
   VCID: 387F9EE08353838A25-806C
   Part No SW: 1S0 959 655 B    HW: 1S0 959 655 B
   Component: VW10Airbag00N H03 0006
   Revision: --------    Serial number: 003MY006R7KX
   Coding: 00000000000000000000000000000000304E
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 3D718FF4AC71A6A2F6-8068
   Serial number: 3495RRB400M50S02MPQ5
   Serial number: 3505RRB400850SKCG8FM
   Serial number: 3555NRB401A50RN8EQ2R
Address 17: Instruments (J285)       Labels:| 1Sx-920-xxx-17.clb-SRI1
   Part No SW: 1S0 920 870     HW: 1S0 920 870
   Component: KOMBI         H05 0010
   Revision: X0005001    Serial number: 00000000000000
   Coding: 1148010000
   ASAM Dataset: EV_KombiUDSMM9RM10 A05808
   ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
   VCID: 6ED378B8B1970D3A3F-803A
   Part No SW: 1S0 909 901     HW: 1S0 937 090
   Component: GW-K-CAN TP20 H81 0744
   Revision: BW081001
   Coding: 001200
   VCID: 70EF66C0A3A31BCA2D-8024
   Part No SW: 5K0 953 234     HW: 1S0 920 870
   Component: IMMO          H05 0010
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
   ROD: EV_ImmoUDSMM9RM10_VW12.rod
   VCID: 6ADB74A88D7FE11A63-803E
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  311 3111
   Serial number: CE240147
   Coding: 0007
   Shop #: WSC 31104 001 1048576
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   Part No SW: 1S0 035 156 A    HW: 1S0 035 156 A
   Component: Radio         567 5543
   Revision: AA001001    Serial number: VWZ8Z1P0142252
   Coding: 0000040802
   VCID: 29594BA440F92A02AA-807C
2 Faults Found:
00870 - Bass Speaker Front Left (R21)
            011 - Open Circuit - Intermittent
                    Fault Status: 00111011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
00871 - Bass Speaker Front Right (R23)
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
Address AD: Brake Sensors (J939)       Labels: 1S0-907-201.clb
   Part No SW: 1S0 907 201 A    HW: 1S0 907 201 A
   Component: CV-SENSOR     H06 0460
   ASAM Dataset: EV_CVSen 001001
   ROD: EV_CVSen.rod
   VCID: 285F4EA053F3130AB5-807C
End-------------------------(Elapsed Time: 02:29)--------------------------
Rgs H2Deetoo
Perfect, we will review and update the BCM coding when the wiring installation for the automatic lights is finished, ... or when needed.👍
H2Deetoo
Post by H2Deetoo »
Today I replaced the existing T73b/11 fog+drl power input with a new wire.
I used a bridge in relay J33 to get permanent 12v (+30) and routed it to fuse SC50 (20A) and from there to T73b/11.
So now I'm ready to reconnect the DRLS directly to the BCM, hopefully soon...
Here's a picture of the new side mirrors with integrated turn flasher:
Best regards,
H2Deetoo
H2Deetoo
Post by H2Deetoo »
Hi guys,
I was just wondering if it is possible to activate the "faulty lamp" icon the UP/Citigo MFA+ (or for example Polo) cluster?
The last year I was driving with several errors about lamps in BCM because of unfinished wiring but I didn't have the "faulty lamp" icon in cluster.
Also the cluster doesn't show this information on the LCD afaik.
It is nice to have lamp diagnostic but without any indication to the driver it isn't much helpfull :roll:
On Passat/Golf6/etc. (PQ4x) platform the cluster checks a specific canbus message to activate this icon, but I have a feeling on Polo/UP (PQ25) platform this "faulty lamp" icon is maybe controlled by a signal on the cluster's 32pin connector?
Does anyone have information how to make this "faulty lamp" icon work, if possible at all?
Thank you,
H2Deetoo
I think the first thing you should do is check if the icon is available on the dial, you can bring a powerful flashlight to the dials to display the icons available on your IC.
If the icon is available you will have to remove the IC and physically check if it is possible to solder an appropriate SMD LED at the exact two points (+/-) to match the icon.
The third and last step would be to find out in the eeprom data dump which is the hexadecimal Byte to modify so that the icon turns on when it should.
The ideal and easy thing would be to find a second-hand IC for VW UP that has this function available.
Some specialized diagnostic tools are necessary.
Madwarlock is the magician of the ICs, try to contact him (although it will be difficult because lately he is a very busy daddy 😊).
H2Deetoo
Post by H2Deetoo »
I just checked a Polo lowline cluster, it does have the icon and led soldered in place.
Then I checked a Beetle 5C5 cluster (which is same hardware as the UP MFA+ cluster) and it doesn't have this icon.
The layout could be different so I will check my actual UP cluster (later).
I will simply try and gather more infos for now.
Let MadWarlock enjoy his new family :)
Regards,
H2Deetoo
H2Deetoo
Post by H2Deetoo »
Hi guys,
Today I was able to rewire my DRLs so that they are under BCM control.
Last week I already replaced the orig wire from T73b/11 with a new 1.5mm2 wire to free fuse SC50 (20A) which I wired to J33 with bridge to get 12v 30a, for my fog lights and as preparation for the DRLs.
Here is what I did today:
First I removed,isolated orig T73b/68 and put a new wire (at least) 1.0mm and connected to fuse SC43A (15A) which comes from fuse SB2 (30A) from battery.
Then I isolated the left DRL and connected a new wire to it and routed it inside.
The right DRL was still connected to fuse SC22 connected to lightswitch T17/3.
Quick in between test:
After ingnition on and light switch on '0' only the right DRL was still working. Good.
Next step I connected left DRL wire to T73b/3.
Then removed fuse SC22 and removed wire SC22A and connected it to T73a/5.
Last wire I placed from T73b/29 to T17/3 (and I removed and isolated the orig gray wire in T17/3)
At that time I did not changed any coding regarding to DRL but I decided to test the current behaviour. It seems the DRLS didn't work, which is obvious.
But also the dipped beam did not work anymore!?
I panicked a little and disconnected the wire T17/3 and left it floating.
Then I coded several bits in the BCM to enable Daytime Running Lights and to my surprise the DRLs started to work as they should: on when switch '0' and off in all other situations.
How is this possible without T73b/29 (T17/3) being connected??
After a coffee break I reconnected T17/3 and everything worked as expected.
I tested most or all light situations and they all looked OK.
Does anyone have any idea how my DRLS could work without T73b/29 being connected (left floating)?
I ask this to double-check if I didn't make a mistake somewhere...
For completeness here is VCDS log (and the BCM is still error free):
Saturday,14,November,2020,17:26:34:00008
www.Ross-Tech.com
Mileage: 111490km-69276mi   Repair Order:
VIN: WVWZZZAAZED094213   Mileage: 111490km-69276miles
   Revision: UOH23---
Readiness: 0110 0001
Address 02: Auto Trans (J514)       Labels:| User\0C8-927-750.clb
   Coding: 010120
Address 09: Cent. Elect. (J519)       Labels:. User\1S0-937-090-F.lbl
   Coding: 7AB82B0000010000090806446DABBCC870C040F0608A2440200000400100
   Coding: 033025
   Coding: 181100
   Coding: A4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| User\1Sx-919-475.clb
   Part No SW: 1S0 919 475 B    HW: 1Q0 919 475
   Component: PARKHILFE 3K  H03 0013
   Revision: --------    Serial number: 32931725102029
   Coding: 108101
   ASAM Dataset: EV_EPHVA14VW1200000 001009
   VCID: 39799BE4B8599A82DA-806C
   Coding: 1148010000
Address 19: CAN Gateway (J533)       Labels:. User\6N0-909-901-6R.clb
   Revision: BW081001
   Coding: 001200
   Coding: 0007
   Coding: 0000040802
1 Fault Found:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
   ROD: EV_CVSen.rod
End-------------------------(Elapsed Time: 02:28)--------------------------
Is someone (ciclo?) willing to have a look at my BCM coding to see if there are improvements to do?
Btw, I noticed some funny coding options like:
- DRL inactive when handbreak engaged
- Foglights on when in reverse
- Foglights off when high beam enabled
What's the reason for them? Mandatory in some countries?
Also can someone explain what these coding options will do:
LC,12,1,Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster)
LC,21,0,Tagfahrleuchtenkombination, 0 = 20 W, 1 = LED
LC,21,1,Switch/Instrument Lights Dimming via Fixed Value active
Next job will be to install the AutoLights loom with relay which ciclo provided!
Best regards,
H2Deetoo
These are just nice to have but not mandatory here.
LC,12,1,Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster) --> part of auto lights coding
LC,21,0,Tagfahrleuchtenkombination, 0 = 20 W, 1 = LED --> on Polo 6R and T5.2/6 they are for the factory bi-xenon/LED headlights for the DRL module
LC,21,1,Switch/Instrument Lights Dimming via Fixed Value active --> parking lights at full brightness for LED DRL on the bi-xenon/LED headlights
H2Deetoo
Post by H2Deetoo »
Thanks for the explanation iichel!
Rgs H2Deetoo
H2Deetoo wrote: Sat Nov 14, 2020 6:40 pm
How is this possible without T73b/29 (T17/3) being connected?? Does anyone have any idea how my DRLS could work without T73b/29 being connected (left floating)?
Best regards,
H2Deetoo
Your BCM Max knows at all times what the positions of the light switch and the ignition switch are, so the T73b / 29 cable is not really necessary after introducing the new BCM coding for DRLs.
A long time ago I assumed that the cable is installed because the electrical signals that the BCM receives in all VW PQ25 models sold all over the world with different engines and different electrical configuration (light switch, etc.) are not the same. In this way it is certain that the DRLs will work (which are mandatory in many countries).
Leave the BCM coding as it is ... everything is OK for now, I will review it in depth when you finish the installation of the wiring for automatic lights (it is my obligation :wink:).
As I did with everyone I will provide you with some links to activate or deactivate functions for the lights, although I see that you have found some of them. You can see these links on the first page of my 6R thread. This is what I have always done after I was informed of the correct operation of all lights after someone installed my auto light wiring.
iichel wrote: Sat Nov 14, 2020 7:31 pm LC,12,1,Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster) --> part of auto lights coding (NO)
LC,21,1,Switch/Instrument Lights Dimming via Fixed Value active --> parking lights at full brightness for LED DRL on the bi-xenon/LED headlights (NO)
Recommendation, check the information you have, or do tests on your 6R.
note: LC 12,1, not possible for 6R and many others PQ25, it depends on the IC software or information system (Head unit).
H2Deetoo
Post by H2Deetoo »
Today I put in the auto-lights loom with red connector and 10pin headlight switch.
Most lights work (fog front, fog rear, DRL, parking, dipped beam) but I have some problems:
- main beam works only when flashing (pulling stalk towards me). It does not work when push stalk away.
I see only ~1.5v on T73a/1 and it doesn't change. So the relay does not activate.
- Interior lights don't work. There seems to be no voltage coming from T73b/4 (dimmer output).
Maybe I made a mistake in wiring or some additional coding is needed?
Auto light function is working. Also leaving-home is working, I can even select to use dipped beam or fog lights, both work for LH.
I haven't tested CH yet.
Regards,
H2Deetoo
Yes, a new BCM coding is required.
Please post a new Autoscan with the auto light wiring installed.
Just to confirm:
- DRLs under BCM control installed :?:
- Interior lights dimmer installed :?:
- LED license plate lights installed :?:
I guess you should have asked me before doing all the measurement work on the terminals.
Remind you that CH is a semi-automatic function:
- Remove the key from the ignition switch, pull the HB lever towards you once (flash), and when you open the driver's door or with the door open the lights will come on.
H2Deetoo
Post by H2Deetoo »
YES
NO. I don't have a dimmer and when we discussed the loom I decided to not use an external dimmer.
No LED but normal lamp (I think). I did not connect it separately to BCM because it is currently already working and not enabled when using parking light left or right when ignition off.
BCM coding hasn't changed since the previous one I posted in my topic but I will make a new scan and post it here.
I can confirm CH is working also correctly.
Regards,
H2Deetoo
