Franciswat's Polo 6R 1.6 Bifuel
Re: Franciswat's Polo 6R 1.6 Bifuel
Thank you for your invitation Francesco, but for now I do not do any more retrofitting on the 6R, it already has too much equipment, now I only drive it around the city and surroundings without trying to achieve the fast lap with its 125 donkeys.
Right now I am dedicating myself to my wife's golf, this past summer I achieved a Master's Degree in terms of retrofits for my wife's golf (madwarlock and me did a crash course with successful results), and now in winter I will try to get the Nobel Prize ...
- Franciswat
- Drives: 6R 1.6 Bifuel
After so many works you deserve to make some good miles! In the end I think your car is more like brand new because it has 50k km more or less (mine ha more than 100k!)
You definitelly deseve a Nobel for your retrofits.
How's your wife's golf compare to our Polo? I think its electonic is more complicated.
Do you know if those pedals fit our Polo?About the pedals ... no comment, you know.
https://i.ebayimg.com/images/g/50EAAOSw ... -l1600.jpg
Our 6Rs have an added value, and in my opinion, today it is very difficult to find a car of the dimensions of our 6Rs to move easily in any circumstance (city, surroundings or highways).
You are right, my 6R is very new even though it is more than 8 years old, ... it is something premeditated, I wanted a durable toy.
Now, mainly I do not travel longer distances with the 6R due to my other vehicles and my commitment to the pandemic situation.
The retrofits in the Golf 7.5 are easier to do than in the 6R, there is a huge amount of information on the net, which together with our experience and personal information, it is easy to face any retrofit. As for the electronics, it is somewhat more complex, but with the appropriate diagnostic tools and some patience, everything is solved.
Money, money and then money ...
The pedals you show are shaped properly for the 6R, but without the part number I don't know what to tell you.
- Platinum Member
Just dont overtighten zip ties and dont use the fat ones. My pedals arent budging
- Franciswat
I agree with you.ciclo wrote: ↑Fri Nov 20, 2020 5:29 am Our 6Rs have an added value, and in my opinion, today it is very difficult to find a car of the dimensions of our 6Rs to move easily in any circumstance (city, surroundings or highways).
At the moment would not change my Polo with any other car and like you I want it to lasts long time.
I thought Golf's retrofits were more complicated due to the sophisticated electronic and all new components protections . I think tools such as Odis are a must for these cars.
Fernando is there anything else I can check a part from voltage and wires integrity before to buy a new RLS again?
Thanks , the issue is to find good quality caps.
- Franciswat
Hi guys you know the difference between 5k7955559A, 5k7955559B and 5k7955559C? Is 5k7955559C more recent so a better choice?
''C has much better software, which will work perfectly for all possible new functions that require the RLS to function.
- Franciswat
Thanks Fernando, I will purchase a C version then.
- Franciswat
Hi guys, in the last days I had fun with snow..
The new RLS "C" version has arrived.
The original ground point was a bit overcrowded so I used an existing hole to create a new one.
After installing the new RLS I found the issue was not related to the sensor but It was caused by an intermittent contact of the positive wire (unfortunatelly I got this only after remaking the whole wiring).. all's well that ends well.
Thursday,31,December,2020,16:14:05:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000 License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 3C 44 55 5F 77 0B
VIN: WVWZZZ6RZCY540000 Mileage: 112920km-70165miles
3C-Lane Change -- Status: Malfunction 0010
5F-Information Electr. -- Status: Cannot be reached 1100
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210228E3217100B5842514E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BB808E1240093380E916CEB0FD9DAC0672F608D30D1200000030000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 121016 04 42 0106
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20231629400567
Coding: 108001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XPrakAssis8K 001003
ROD: N/A
VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XPrakAssis8K" (VW25)
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaWV10BPAVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaWV10BPAVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140E00
ASAM Dataset: EV_Kombi_DUS_VDD_RM09 A04113
ROD: N/A
VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_Kombi_DUS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Time Indication: 0
Date: 2015.05.24
Time: 00:28:51
03158 - Control Module for Information Electronics 1 (J794)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Time Indication: 0
Date: 2015.05.24
Time: 00:28:51
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03009
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 7E0 907 566 C HW: 4H0 907 566 F
Component: SWA Master H07 0030
Serial number: 0388724741
Coding: 010321
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_LancEhangAssis 001028
ROD: N/A
VCID: 3068CB826BB813C159-8064
No ASAM data for: "EV_LancEhangAssis" (VW25)
4 Faults Found:
388355 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Date: 2020.12.31
Time: 00:28:45
729349 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Date: 2020.12.31
Time: 00:28:45
729605 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Date: 2020.12.31
Time: 00:28:45
733440 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 253
Mileage: 112923 km
Date: 2020.12.31
Time: 00:28:45
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
ASAM Dataset: EV_HeadlRegulWVLWRPt 001004
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlRegulWVLWRPt" (VW25)
Address 5F: Information Electr.
Cannot be reached
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:38)--------------------------
haha i have the same issue with the grounding point on top of the steering column
Hello Francesco, happy new year 2021!
Most importantly, you managed to figure out what was wrong with the RLS.
- Franciswat
Thank you Fernando!
Happy new year guys!
- Franciswat
Hi everybody, I'm glad to inform you that thanks to Roman's job (rofireman) who wrote a new software specific for my car's ECU, the GRA high emulator finally works!
Wow ... excellent work !!! (High level)
Thanks for letting us know and for the video Francesco, I was waiting for this great news!
I'm very happy that you both made it, ... enjoy it.
- Franciswat
Thank you Fernando! No need to thank me, I should thank you for what my little Polo has become.
Hi my friends, today just a little update about my last mod: Golf 7 R-line style keyfob for 6R.
Parts:
Key -> Aliexpress
R-Line clip -> VW dealer
100% Perfect fit.
Programming tools:
BCM -> Rosstech VCDS
Key transporter (ID48) -> Xhorse VVDI
Final result:
Parts:
Key -> Aliexpress
100% Perfect fit.
Programming tools:
Final result:
