some errors after upgrading 1S0937087D bcm to 1S0937090F
Re: some errors after upgrading 1S0937087D bcm to 1S0937090F
Okay, I'm going to do your new BCM coding, hopefully no errors come up due to the license plate lights.
Please wait a while. Thank you.
H2Deetoo
- Drives: VW UP/Passat B6
Fresh auto scan:
Best regards,
H2Deetoo
Friday,20,November,2020,16:00:17:00008
VCDS Version: 18.9.1.0
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAAZED094213 License Plate:
Mileage: 111560km-69320mi Repair Order:
Chassis Type: AA-VW12 (1S0)
Scan: 01 02 03 09 10 15 17 19 25 44 56 AD
VIN: WVWZZZAAZED094213 Mileage: 111560km-69320miles
AD-Brake Sensors -- Status: OK 0000
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 AN HW: 04C 907 309 N
Component: R3 1.0l MPI H23 9104
Revision: UOH23---
Coding: 00140012022400000000
Shop #: WSC 00900 211 00000
ASAM Dataset: EV_ECM10MPI01104C906020AN 001008
ROD: EV_ECM10MPI01104C906020AM.rod
VCID: 67DD0D9C9E6DDC727C-8032
Readiness: 1110 0001
Address 02: Auto Trans (J514) Labels:| User\0C8-927-750.clb
Part No SW: 0CT 927 750 A HW: 0CT 927 750 A
Component: SQ100 H10 0013
Coding: 010120
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMSQ101011 004010
ROD: EV_TCMSQ101011_004.rod
VCID: 4683E018F9A7E57AA7-8012
Address 03: ABS Brakes (J104) Labels: 1S0-614-517.clb
Part No SW: 1S0 614 517 E HW: 1S0 614 517 E
Component: EBC 460 ESP H08 0012
Serial number: A00IP1V
Coding: 12BF24718BB602F548FC24F6D1AC404059B200
ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
ROD: EV_Brake1ESPMP1TRWVW120.rod
VCID: 3169A3C4602952C262-8064
Address 09: Cent. Elect. (J519) Labels:. User\1S0-937-090-F.lbl
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 215160666
Coding: 7AB82B0000010000090806446DEBBCC870C040F0608A2440200000400100
VCID: 366390D8814775FA37-8062
Subsystem 1 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 090608 04 46 0204
Coding: 033025
Subsystem 2 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO26347321
Coding: 181100
Subsystem 3 - Part No SW: 2H0 959 442 HW: 2H0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29170001883980077353
Coding: A4FFFF
Address 10: Park/Steer Assist (J446) Labels:| User\1Sx-919-475.lbl
Part No SW: 1S0 919 475 B HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0013
Revision: -------- Serial number: 32931725102029
Coding: 100101
ASAM Dataset: EV_EPHVA14VW1200000 001009
ROD: EV_EPHVA14VW1200000.rod
VCID: 39799BE4B8599A82DA-806C
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag00N H03 0006
Revision: -------- Serial number: 003MY006R7KX
Coding: 00000000000000000000000000000000304E
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3D718FF4AC71A6A2F6-8068
Serial number: 3495RRB400M50S02MPQ5
Serial number: 3505RRB400850SKCG8FM
Serial number: 3555NRB401A50RN8EQ2R
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 1S0 920 870 HW: 1S0 920 870
Component: KOMBI H05 0010
Revision: X0005001 Serial number: 00000000000000
Coding: 1148010000
ASAM Dataset: EV_KombiUDSMM9RM10 A05808
ROD: EV_KombiUDSMM9RM10_A05_VW12.rod
VCID: 6ED378B8B1970D3A3F-803A
Address 19: CAN Gateway (J533) Labels:. User\6N0-909-901-6R.clb
Part No SW: 1S0 909 901 HW: 1S0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: BW081001
Coding: 001200
VCID: 70EF66C0A3A31BCA2D-8024
Part No SW: 5K0 953 234 HW: 1S0 920 870
Component: IMMO H05 0010
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADB74A88D7FE11A63-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 R HW: 6R1 909 144 E
Component: EPS_TRW_ALow 311 3111
Serial number: CE240147
Coding: 0007
Shop #: WSC 31104 001 1048576
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
Part No SW: 1S0 035 156 A HW: 1S0 035 156 A
Component: Radio 567 5543
Revision: AA001001 Serial number: VWZ8Z1P0142252
Coding: 0000040802
VCID: 29594BA440F92A02AA-807C
1 Fault Found:
00871 - Bass Speaker Front Right (R23)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H06 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 285F4EA053F3130AB5-807C
End-------------------------(Elapsed Time: 02:39)--------------------------
Best regards,
H2Deetoo
Thanks, I'll build on it for the new BCM coding.
H2Deetoo
If the current license plate installation will result in some error I will put a new wire directly to T73b/7 to sort it
OK.
Test this new BCM coding:
7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000420100
Please report the result, don't forget to also check the reverse gear.
If there are faults in the scan for any of the lights, please tell me the type of bulb installed for that light. Thanks.
H2Deetoo
I tried the new coding and the situation remains the same: No interior lights, no permanent high beam (stalk forward).
Also no faults (even after driving for a minute):
Reverse gear is (and was) OK.
Some small additional notes about your coding:
- I have an automatic gear
- I don't want to use rain sensor at this time
Rgs H2Deetoo
Address 09: Cent. Elect. Labels: User\1S0-937-090-F.lbl
Control Module Part Number: 1S0 937 090 F HW: 1S0 937 090
Component and/or Version: BCM PQ25 1MX4 H81 0744
Software Coding: 7AB82B0000010000090806D46CEBBEC870C040F0608E2441200000400100
Work Shop Code: WSC 31414 790 00001
Rgs H2Deetoo
Ok, thanks for the clarifications, you can later select what best suits your needs or taste.
Well, some part of the wiring is not properly installed, we will have to investigate the causes.
I have to check the diagrams for your UP, I haven't seen these diagrams in a long time, it will take me some time to ask you some questions about the electrical installation you have done.
Note: In the previous autoscan that you posted you had the diagnostics of some lights disabled, I don't know the reasons or if it was that way from the factory. I never enable the lamp diagnostics that are previously disabled.
Wait a minute,
.... double check that you copied and pasted the new BCM coding correctly.
Because the one you show here is not correct.
viewtopic.php?p=577622#p577622
I hope you are not getting help from someone else and you are not following my guidelines.
You have to do exactly what I tell you, otherwise my help has ended right now.
H2Deetoo
I am sorry I made a mistake in copying, my apologies.
But I need to change 1 bit because I have an automatic gear and not a manual gear, so byte 27 needs to be 40h and not 42h.
After writing the correct coding you specified (byte 18 to 60h instead of 40h which I forgot) the main beam *is* working! Great
And still no errors in bcm:
Only the interior lights are not working yet.
Regards,
H2Deetoo
Friday,20,November,2020,18:15:36:00008
VCDS Version: Release 18.9.1 Running on Windows 7 x86
www.Ross-Tech.com
Software Coding: 7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000400100
VCID: 366390D8914775FA37-8062
Regards,
H2Deetoo
Enable Bit1 of Byte 27 and check your interior lights.H2Deetoo wrote: Fri Nov 20, 2020 5:16 pm
But I need to change 1 bit because I have an automatic gear and not a manual gear, so byte 27h needs to be 40h and not 42h.
Regards,
H2Deetoo
Please understand that there are many people waiting for my help. Thank you.
H2Deetoo
Ciclo, your help is greatly appreciated, ever since the beginning of this project!
I did set bit 1 of byte 27 now and interiour lights *are* working now !
And no fault codes in bcm:
So the description for this bit is defined wrong in the VCDS label file it seems :-/
Or you have some other explanation?
Muchas gracias!
Friday,20,November,2020,18:48:54:00008
www.Ross-Tech.com
Software Coding: 7AB82B0000010000090806D46CEBBEC870C060F0608E2441200000420100
Muchas gracias!
Perfect!
The explanation is obvious, we do not have the same information.
Some of the following links/info may be useful for you:
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
viewtopic.php?f=56&t=58703&start=4020#p529332
Depending on the year of manufacture of the BCM and other factors, some information in the previous links may not work for your car.
H2Deetoo
Thanks for the links. I will review them and update my label file if apropriate.
Thanks again for your time and effort!
H2Deetoo
H2Deetoo
Perhaps slightly offtopic, but massive respect for this work on your VW Up!.
I did a cruise control retrofit on one today and I'm always yelling and cursing at the BCM connectors. Especially the bastard white one since it's always in places my fingers cannot reach.
It's hard to imagine removing terminals and doing a BCM max retrofit.
Share your secret, pretty please
