Efficiency Below Threshold - o2 sensor?
Polobear6r
Drives: Polo
Post by Polobear6r »
So I got this check engine light I drove normal at a 100KM for about 40 minutes and suddenly the check engine came up. I cleared the code but a few days later I got the same code again while waiting for a stop sign. (autoscan below)
Is this a familiar code and does someone know where the fault is? My guess it is one of the 2 O2 sensors? (I believe in the Netherlands we call them lambdasensor ?)
Or is it the catalytic converter itself?
the autoscan says:
1 Fault Found:
6093 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
But is Bank 1 a fixed position? For example the Oxygen sensor that is mounted on the exhaust manifold? (and bank 2 the sensor after the catalytic converter?)
Is there a way to clean o2 sensors? I see some video's on youtube but do they work?
Friday,11,December,2020,12:19:27:23303
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WVWZZZ6R(removed for privacy reasons)   License Plate:
Mileage: 241790km-150241mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
VIN: WVWZZZ6R(removed for privacy reasons)   Mileage: 241790km-150241miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8949
   Revision: --------    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12MPI02103E906019M 001007
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E57F709714C42F4A0-807A
1 Fault Found:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine RPM: 836.00 /min
                    Normed load value: 19.2 %
                    Vehicle speed: 8 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 20 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 13.507 V
                    Test of catalytic converter: measured value-EFF_CAT_DIAG_OBD[1]: 1.140625
                    Cat. temperature: bank 1: 769.78751 °C
                    Engine RPM: 827 /min
                    Air mass: actual value:-MAF: 101.18 mg/stroke
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3217000B6842924EB84DA00401100
   VCID: 071962ADB27633BC43-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 316DEC7568725D0CBD-8064
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 035110798
   Coding: 7BB02BBF08A10048002008002D2B0C900040410F60060000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 428FB3B9DDD4D69454-8016
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100014122
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU016061100013956
   Coding: 08BC30
   Part No SW: 6R0 959 655 K    HW: 6R0
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00PVUS.
   Coding: 003232
   VCID: 4A9F9B99EDE40ED49C-801E
   Serial number: 3575HRB404V0JR9KC0K6
   Serial number: 3585HRB40570ISD6CGHU
   Serial number: 3515RRB40530L9U4H1JK
   Serial number: 3525RRB405D0L2V2C8FL
   Part No SW: 6R0 920 860 G    HW: 6R0 920 860 G
   Component: KOMBI         H03 0505
   Coding: 140200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 387BD15183088C44FA-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002200
   VCID: 70EB2971A3F81404F2-8024
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADF3B198D24EED4BC-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F69EA0DEA464BFCAB-807A
End-------------------------(Elapsed Time: 02:00)--------------------------
                Address 01: Engine       Labels: 03E-906-019-CGP.clb
Control Module Part Number: 03E 906 019 M    HW: 03E 906 019 B
  Component and/or Version: SIMOS11.1     H03 8949
           Software Coding: 00110016000400080000
            Work Shop Code: WSC 00788 648 00255
              ASAM Dataset: EV_ECM12MPI02103E906019M 001007 (VW25)
1 Fault Found:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Re: Efficiency Below Threshold - o2 sensor?
No, "bank 1" in your "3 in line engine" is the only bank, the "bank 1" and "bank 2" is for a Vee configuration engine.
Sensor 1 is pre cat and sensor 2 is post car sensor, so your car has S1 B1 and S2 B1 for before and after the cat, we call these sensors Lambda sensors as well as they measure the Lambda of the exhaust.
Edit:- if there was a functional failure detected for either the S1 B1 or the S2 B1 then VCDS should have been able to report that and report it before the car looked like it was under performing.
I've never had this problem but maybe you could view live data to see how the S1 B1 was behaving at the same time as viewing live data for the S2.
That car has run many miles/kms so maybe it is just a failed cat.
d-ash
Drives: 6C 2016 R-Line 1.2 90PS - Blue Silk
Post by d-ash »
... or failed sensor, as happened to my 1.2Tsi recently. It drove fine with the Engine Management light illuminated, but was using 20% more petrol than normal (demonstrating how the feedback from the sensors influences fuel mix). VW recommend replacing both sensors as there seems to be history of the second failing soon after the first. Cost nearly £500 !!
d-ash wrote: Mon Dec 14, 2020 8:42 pm
Well, I would hope in your situation, there were Lambda sensor fault codes stored, and so made sorting this out a bit more logical than just going with an idea, the pre cat sensor does have the ability to change the fuelling, that is its purpose, the post car sensor is only there to monitor the cat's performance and verify that the gases passing out of the cat are staying within emissions limits when they should be.
Edit:- in the OP's opening post the VCDS scan results clearly only indicate an issue with the cat, there are no stored Lambda sensors faults, so looking at the live data from both Lambda sensors would be useful in trying to work out what seems to be the most likely root cause.
Polobear6r
Drives: Polo
Thanks guys for the replies.
Well i guess i'll have to figure out how i can show live data and where to look for.
