Hello Everyone, I had installed the BCM Max Adaptation and auto lights wiring this week on my Polo 6R.
It took me 5 days to complete the installation. Everything works beautifully. The wiring provided by ciclo sir is of excellent quality and perfect. I finished all the installation today and posting here the final Autoscan.
Friday,26,February,2021,17:05:36:00233
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WVWC14608ET069582 License Plate: 4259
Mileage: 85490km-53121mi Repair Order: 4
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWC14608ET069582 Mileage: 85490km-53121miles
Address 01: Engine (J623-CLNA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 36792 002 104857
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023CR_003.rod
VCID: 050BCCD68421CFAE38-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412918C90619E471825318020000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 030FD2CE8A15F19E16-8056
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40851DC2D3832A864B-8014
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 238150833
Coding: 3AB82FB848A10000013806D03CCB9E90F08067FF60002001200400030000
Shop #: WSC 12345 123 12345
VCID: 2F674E7E7E1DA5FEA2-807A
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 260215 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576131205051351
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579131210074912
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2771621065102472AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580131212230948
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581131127234117
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00PX2AZ
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499300E6E8B9EBCE9C-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140C00
Shop #: WSC 11802 938 12345
VCID: 479706DEFEAD1DBE8A-8012
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002300
VCID: 70E58D02A3A3FA06FB-8024
Component: IMMO H04 0805
VCID: 6AD19F6A8D7F00D6B5-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54AD21923FFBA626FF-8000
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09475GD0078320
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 458B0CD6CCA10FAE78-8010
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 174
Mileage: 85499 km
Time Indication: 0
Date: 2021.02.26
Time: 11:42:02
End-------------------------(Elapsed Time: 02:17)--------------------------
The BCM max coding given by ciclo sir worked perfectly. BCM threw error of heated mirrors. It was my mistake that i kept on that feature unnecessarily. later it went off when i disabled it through vcds.
Thanks Ciclo sir for all the help and support during installation. I learned alot from you. You are a Genius.
