I need help for-test cluster on bench Polo 6R wiring
mahesh_parmar
Drives: Polo 6R
Post by mahesh_parmar »
Hi all,
Can someone help with a bench cable connection diagram for testing & programming instrument clusters for the polo 6R. What part I need for test bench and wiring help me please
Thanks.
Re: I need help for-test cluster on bench Polo 6R wiring
mahesh_parmar
Drives: Polo 6R
amer6R wrote: Wed Jan 06, 2021 7:25 am Image
I have this but can’t work need with gateway wiring
gelotus
Drives: 6r 1.6 TDI Highline
Post by gelotus »
Would be better if you tell us exactly what do you want to do with the cluster, for immo programming you need only terminal 15, terminal 30, gnd, can low and can high pins, gateway is not needed, same with vcds for coding and adaptions.
mahesh_parmar
Drives: Polo 6R
gelotus wrote: Wed Jan 06, 2021 7:34 pm Would be better if you tell us exactly what do you want to do with the cluster, for immo programming you need only terminal 15, terminal 30, gnd, can low and can high pins, gateway is not needed, same with vcds for coding and adaptions.
I want for vcp and vcds
gelotus
Post by gelotus »
obd pin 16, cluster pin 31, 32 -> +12V
obd pin 5, cluster pin 16 -> gnd
obd pin 6 -> cluster pin 28
obd pin 14 -> cluster pin 29
