1.2 TDI EGR problems
Vard593
Drives: MK8 1.2 TDI
Post by Vard593 »
Had an error code p2563, tool to the garage they replaced the egr system, car was then boosting properly no problems, to then after about 6 months the same error code and performance issues...
Any help? Could it be a vaccuum problem or a sensor?
My engine code is CFWA if thats any help
Re: 1.2 TDI EGR problems
If you google the eror its not thenegr fault
If they replaced the EGR for a P2563, then I'd have a good conversation why they did it. It's clearly a turbocharger system fault (not just the TC, but the vacuum system or piping).
So check VGT, vacuum, wiring, N75, sensor on the turbo.
Vard593
Drives: MK8 1.2 TDI
Post by Vard593 »
To be fair it sorted the problem for a while must have been a gunked up egr, but also something else, code hasnt reappeared, since changing n75 valve but engine feels sluggish, get some boost at 2000rpm but not as before.
