Hallo
I wanted my Polo6C 1.4 TDI 3 cylinder 2014 75 HP
WVWZZZ6RZFY133526
Retrofitting cruise control, what have I done so far.
- Steering column switch exchanged
- 6 cables pinned to the steering column switch
- BCM (6C0937087A) 4 cables pinned
- 1 cable laid to fuse 37A
- 1 MSG pin 44 cable pinned
my problem as soon as I activate VCDS in MSG GRA I get a drive train error and an implausible signal
what doesn't fit there.
Polo 1,4 TDI Cruise Controll
Re: Polo 1,4 TDI Cruise Controll
You need to visit the dealership with your activation document. It cannot be done with vcds
Thanks for your trouble. One more question is pin 44 the right one.
yes it is the right one for your 1.4 TDI engine
Hi
Cruise Control successfully activated Toddy I had to buy an Aktivation document for the
GRA from the dealer and have it activated with Odis
@ iichel Thanks for your help.
