Upgrading BCM to MAX
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Hi Polo wise people!
I have a 1.6 tdi comfortline bmt
Im upgrading my "highline" headlights (h7/h7) to bi-xenon with 10-14 adapters (no auto leveling)
In the that process im upgrading my bcm from 6R0 937 088F to 7E0 937 090B
Now to my question: is the only thing I need, a can wiring loom from t73b/57-54 to t32/29-28 or do I need anything else?
Best Regards
Re: Upgrading BCM to MAX
Your 88f should be perfectly capable of controlling bi-xenon headlights as well
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
iichel wrote: Wed Feb 10, 2021 7:34 am Your 88f should be perfectly capable of controlling bi-xenon headlights as well
As far as I can see it dosent have the pins for LED DRL or cornering lights, beside the 90b can light up my mfsw :D
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Either way, I would really like to have the BCM Max to function in my car
I cant upload autoscan yet, need more post :(
Just paste the autoscan as plain text, it's much easier to read as well.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
VIN: WVWZZZ6RZCY508726 License Plate:
Mileage: 199930km-124230mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61 77
VIN: WVWZZZ6RZCY508726 Mileage: 199930km-124230miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 ME HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9978
Revision: --H33--- Serial number:
Coding: 00114016002401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023ME 003014
ROD: EV_ECM16TDI02103L906023PL.rod
VCID: 75B7E3E0754F3FF3504-8020
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3416D00BA842C14E482D700521300
VCID: 074B99281F633D63328-8052
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 38292AD4225D829B8B2-806C
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0351
Revision: BU050001 Serial number: 0456 172110435
Coding: 3CB02BB808A10000213807C22D2B0FD00A80610F7E060149200000010000
Shop #: WSC 00763 204 00001
VCID: 41DF47307187C3533CC-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 270611 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU014061100017565
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU015061100015010
Coding: 48BC30
Subsystem 4 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 39180000235390058087
Coding: A4FFFF
Subsystem 5 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU018061100010892
Coding: 48BC32
Subsystem 6 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010061100016888
Coding: 48BC32
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GY003PE4D
Coding: 003232
VCID: 4BC36518434B1903D60-801E
Serial number: 3575HRB404R0H4DK41GD
Serial number: 3585HRB40650CTC46HJI
Serial number: 3515RRB404R0M8GCLH4%
Serial number: 3525RRB404V0M8GC28O$
Part No SW: 6R0 920 861 H HW: 6R0 920 861 H
Component: KOMBI H03 0505
Coding: 540E01
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3A2D30DC1CD1908B7D6-806E
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0034
Revision: H38 Serial number: 140611F2002020
Coding: 2500C2
VCID: 34311EE43E3566FBA7A-8060
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A8DC09C2CF1E00BCD6-803E
Address 44: Steering Assist Labels: None
VCID: 55F783609C4F5FF3704-8000
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0034
Coding: 030B1A5A
VCID: 74B1DEE47EB526FB67A-8020
Subsystem 1 - Part No SW: 6R0 915 181 D HW: 6R0 915 181
Component: J367-BDM H07 0180
Serial number: 00000000008900687690
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:19, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
For the new BCM 7E0 to work properly in your BlueMotion, in addition to the new CAN lines for the IC, you need to connect all the wires going to the current Gateway to the new BCM 7E0, thus eliminating the external Gateway. There is a clear correspondence from where each wire goes to the new BCM (erWin, elsa).
The functions of the old removed Gateway are now performed by the internal Gateway of the new BCM 7E0.
Your old original BCM can manage all the functions for Bixenon headlights (DRLs, SCLs, side lights, etc), but as you say, not the lighting of your new MFSW.
...if you need the codings for the whole process (7E0 BCM + Bixenon) you only have to ask for it once you have finished with the electrical installation.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Hi ciclo!
Thanks for guidance :D
Is this correct understood then?
wiring for new bcm.png (561.27 KiB) Viewed 2345 times
It is right.
However, verify that the convenience and powertrain CAN lines reach the white connector of the BCM, add the diagnostic ones and the new ones from the IC.
You must also connect the LIN wire for alternator - battery monitor (violet-white wire T20/12 GW) to T73b/37.
For interior lights you must also change the position of the wire T73b/1 to T73b/4. It is a different terminal, they are both MCP, but different in size.
For this, I recommend adding a new wire (1.10 m of 1.0mm2) from T73b/4 to T6/3 of the Dimmer. Isolate current terminals, T6/3 and T73b/1.
easy... :)
These retrofits are so interesting to do. Good luck, maybe taking the driver seat for more comfy laying position.
6R
7E0 ("T6", Amarok, ... and current PQ25 around the world)
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Hi
Convinience reach the White connecter, so Im going to add can lines for the powertrain 8)
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Is it enough just to isolate those wires that went to the old gateway or do I have to add a resistor so the circuit is kept closed?
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Hi Ciclo
All wires is connected now, just need a bit of help with the coding, by the way, went for autolight with ch/lh, followed your guide :D
Tried to plug in the xenon, main beam works but thats it, no led drl og shutter...
by the way tried to send autoscan but im getting: forbidden, contains cantacs
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
