Upgrading BCM to MAX
jiimien
Drives: 6R 1.6 TDI
Re: Upgrading BCM to MAX
Post by jiimien »
By the way, when i did the wire job for the autolight, I noticed that, the wire for the original t17/3 wasn't there on my car..
I can see, that if, it had been there it's connected to A9 and then to fuse SB9 / SB39.
Maybe this only applies for cars that original has H4 headlamps or lower bcm to start with..
Should I install that wire connection any way? :roll:
3 is the DRL wire. It is not always necessary to have it in BCM max.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Hello!
Here is an update!
Its working somewhat now..
Lightswitch:
0 = LED on
Auto = LED on, no low beam
Parking light = all lights off
Low beam = Led off, low beam on
On all settings, I can flash high beam, but not turn it on constantly. No cornering lights either
Low beam level regulation, and interior dimmer is not responding either
Autoscan
VIN: WVWZZZ6RZCY508726   License Plate: AFTER NEW CODE
Mileage: 200050km-124305mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 5F 77
VIN: WVWZZZ6RZCY508726   Mileage: 200050km-124305miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 ME    HW: 03L 907 425 B
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023ME 003014
   ROD: EV_ECM16TDI02103L906023PL.rod
   VCID: 75B7E3E0754F3FF3504-8020
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416D00BA842C14E482D700521300
   VCID: 074B99281F633D63328-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38292AD4225D829B8B2-806C
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 15
                    Reset counter: 99
                    Mileage: 200039 km
                    Time Indication: 0
                    Date: 2015.07.07
                    Time: 03:09:50
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FB8482100002138073F3FEB1FD81A80672F600510C1300000000000
   Shop #: WSC 00763 204 00001
   VCID: 2A0D009CECF1200B0D6-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 270611 05  54  0403
   Coding: 0E302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100017565
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU015061100015010
   Coding: 48BC30
   Subsystem 4 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000235390058087
   Coding: A4FFFF
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU018061100010892
   Coding: 48BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010061100016888
   Coding: 48BC32
4 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200054 km
                    Time Indication: 0
                    Date: 2015.07.08
                    Time: 16:46:11
01504 - Bulb for License-Plate Light (X)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200054 km
                    Time Indication: 0
                    Date: 2015.07.08
                    Time: 16:46:11
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200054 km
                    Time Indication: 0
                    Date: 2015.07.08
                    Time: 16:46:11
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200054 km
                    Time Indication: 0
                    Date: 2015.07.08
                    Time: 16:46:11
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GY003PE4D
   Coding: 003232
   VCID: 4BC36518434B1903D60-801E
   Serial number: 3575HRB404R0H4DK41GD
   Serial number: 3585HRB40650CTC46HJI
   Serial number: 3515RRB404R0M8GCLH4%
   Serial number: 3525RRB404V0M8GC28O$
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 540E01
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A2D30DC1CD1908B7D6-806E
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 2500C2
   VCID: 6889BA94327DD21BDB2-803C
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC09C2CF1E00BCD6-803E
Address 44: Steering Assist        Labels: None
   VCID: 55F783609C4F5FF3704-8000
   Part No SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Component: MU-S--ER      H41 0478
   Serial number: VWZAZ2U0687010
   Coding: 065700003C00000011110001000808001F0100C40020010002
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2D070B80DD9F3733E84-8078
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
                    Voltage terminal 30: 13.6 V
                    Status_Software_Version_Management-module_name:
15360256 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:13
                    BAP-BAP_Function_ID: 02
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:17, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
This is a diagram that I made a long time ago and that you must follow for your Bixenon headlights wires installation.
🔎https://drive.google.com/file/d/0B2nv91 ... sp=sharing
NoTe: :)
Pay special attention to the wires for the Parking / side lights, your 6R BlueMotion has the wires in the headlight connectors for these lights but they are not appropriate. You must isolate them and install new ones from the BCM to the new T14 connectors. As indicated in the diagram.
When you have done it exactly as indicated in the diagram, we will code your 7E0 BCM and RLS for Bixenon and Autolights. :wink:
NoTe 2:
The thread statement says it is the BCM update, then you comment that YOU are installing the Bixenon headlights ...
jiimien wrote: Sat Feb 13, 2021 9:31 am Hi
Convinience reach the White connecter, so Im going to add can lines for the powertrain 8)
Hi jiimien,
Things to keep in mind:
- The new CAN lines for powertrain are not the same as the new CAN lines for the IC.
With 7E0 BCM the CAN lines for IC are independent of the CAN lines for powertrain.
jiimien wrote: Sat Feb 13, 2021 10:41 am Is it enough just to isolate those wires that went to the old gateway or do I have to add a resistor so the circuit is kept closed?
The old wires that reached the old GW and that are not necessary for the new modifications in the wiring, can be perfectly isolated / inserted in the old GW connector.
You don't have to add any resistance or do weird things ... :) :wink:
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
ciclo wrote: Sun Feb 14, 2021 6:56 pm This is a diagram that I made a long time ago and that you must follow for your Bixenon headlights wires installation.
NoTe: :)
NoTe 2:
Hi Ciclo
All can wires is done, IC, Convenience, powertrain and diag.
Wires for 10-14 connector and autolights loom is done too, all done according to your diagrams :D
So Im all set for coding 7E0 Bcm and RLS for Bixenon and Autolights.
My current issues right is:
Lightswitch:
0 = LED on
Thanks for your help! :lol: :mrgreen:
Here is my newest autoscan:
VIN: WVWZZZ6RZCY508726   Mileage: 200080km-124323miles
   Revision: --------
   Revision: V0000000
1 Fault Found:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 100
                    Mileage: 200039 km
                    Time Indication: 0
                    Date: 2015.07.07
                    Time: 03:09:50
   Coding: 3CB02FB8482100002138073F3FEA1FD81A80670F600510C1300000000000
   Coding: 0E302D
   Coding: 58BC30
   Coding: 48BC30
   Coding: A4FFFF
   Coding: 48BC32
   Coding: 48BC32
4 Faults Found:
            010 - Open or Short to Plus - Intermittent
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 60
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 18:01:24
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 18:00:02
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 5
                    Reset counter: 100
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 18:01:22
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 18:00:02
   Coding: 003232
   Coding: 540E01
   Revision: B9081001
   Coding: 2500C2
   Serial number:
3 Faults Found:
          B201A 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:13
Cannot be reached
End----------(Elapsed Time: 01:18, VBatt start/end: 12.2V/12.2V)-----------
3CB02FB848210000213807B17CEB1FD85A80672F600530C1200000020000
61? :lol:
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
ciclo wrote: Mon Feb 15, 2021 7:54 pm61? :lol:
What 61 ? :oops:
ciclo wrote: Mon Feb 15, 2021 7:48 pm 3CB02FB848210000213807B17CEB1FD85A80672F600530C1200000020000
That help a lot, still a few issues:
Lightswitch:
0 = LED on ---- ok :D
Auto = LED on, no low beam -- not ok :cry:
Parking light = dimmed led --- ok 8)
Low beam = Led dimmed, low beam on --- ok 8)
On all settings, I can flash high beam, but not turn it on constantly :shock: . No cornering lights either
Low beam level regulation, and interior dimmer is not responding either.
No Ch or lh, unless I do manual, by flashing high beam
Also there is some new error codes :shock:
Autoscan:
   Revision: --------
   Revision: V0000000
1 Fault Found:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 8
                    Reset counter: 60
                    Mileage: 200039 km
                    Time Indication: 0
                    Date: 2015.07.07
                    Time: 03:09:50
   Coding: 3CB02FB848210000213807B17CEB1FD85A80672F600530C1200000020000
   Coding: 0E302D
   Coding: 58BC30
   Coding: 48BC30
   Coding: A4FFFF
   Coding: 48BC32
   Coding: 48BC32
2 Faults Found:
03433 - Terminal 30 for Backup Lights and Adaptive Lights
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 60
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 21:49:34
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 100
                    Mileage: 200088 km
                    Time Indication: 0
                    Date: 2015.07.09
                    Time: 21:49:54
   Coding: 003232
   Coding: 540E01
   Revision: B9081001
   Coding: 2500C2
   Serial number:
3 Faults Found:
          B201A 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:11
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 59
                    Mileage: 200039 km
                    Date: 2021.02.13
                    Time: 03:30:13
Cannot be reached
End----------(Elapsed Time: 01:17, VBatt start/end: 11.9V/12.1V)-----------
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61 77
VIN: WVWZZZ6RZCY508726 Mileage: 199930km-124230miles
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: ?
You must enable it in the installation list of your 7E0 GW.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Okay, will do that, what should I do about the lighting issues? :oops:
Check that a wire black/green reaches T73b/11. Take a picture of the fuse box.
Check/Set BCM adaptation channels 53 and 54 to 0 in case the values are 1. That is, from 1 to 0 in both cases.
In case you have installed LED lamps in some of the lights, tell us where you installed them and the exact model.
Study how the CH, LH and automatic lights work on the PQ25...
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
ciclo wrote: Tue Feb 16, 2021 5:36 am Check that a wire black/green reaches T73b/11. Take a picture of the fuse box.
No wire present at T73b/11
My fuse box
Channels 53 and 54 was 1, now set to 0
I have WV Original LED license plate, thats it, otherwise halogen bulbs
Your 6R is missing the SB57 fuse, the SB57 output wire feeds the BCM for the SCLs and Backup lights as per autoscan.
Easy.
Fortunately your 6R has an empty slot for the SB44 fuse.
Install a 1.0-1.5mm2 wire from SB44b to T73b/11 and put a 15A fuse on SB44.
I imagine your high beams are now working properly ... :?:
New BCM coding
: (LED plate lights)
3CB02FB848210000213807B17CEB1FD85A80672F600530C1200000030000
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
That helped out 1 error, still one remaining though.
So still not able to control dimming or LWR.
No high beam :roll: (only highway flash)
I am maybe too used to autolights from MQB, but shouldnt it be able to turn on the low beam, when its dark enough?
And another thing :?:
Shouldnt there be some backlight at the top buttons?
   Coding: 3CB02FB848210000213807B17CEB1FD85A80672F600530C1200000030000
   Coding: 0E302D
   Coding: 58BC30
   Coding: 48BC30
   Coding: A4FFFF
   Coding: 48BC32
   Coding: 48BC32
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 100
                    Mileage: 200135 km
                    Time Indication: 0
                    Date: 2015.07.11
                    Time: 15:00:14
