VW T5.1 Caravelle BCM Upgrade and Cruise Control on Steering Wheel...SOLVED
Re: VW T5.1 Caravelle BCM Upgrade
Have you touched the SC22 10A fuse?
It is probably not seated properly or is blown.
It is the culprit (or the wires that reach it) of the faults detected in Auto HVAC (J255).
This is one of those fuses that you had already changed before this installation, maybe it will give you a clue of what is happening.
Limalex
- Drives: Touareg R-line
Yes I forgot to put it back. It was that fuse
I ordering Osram LED bulbs for the low beam and the side lights.
Maybe t here is an issue with the quality of the LEDs I put in .
Well, it is possible, but I don't think the problem is the quality, it is possible that the problem (the three detected faults) is due to the low consumption of these LED lamps.Limalex wrote: Tue Feb 16, 2021 1:19 pm I ordering Osram LED bulbs for the low beam and the side lights.
If you want we can try a new BCM coding to try to avoid detected faults due to LED lamps, but the result will be uncertain ...
Set Byte 16 to 55 HEX, autoscan, and report what happens ...
Limalex
Hi Ciclo,
I did not really understand what you meant by 55 HEX. So I simply changed the value from 50 to 55 on bit 16.
What happening is well beyond my understanding.
Here is the first scan. As you see with one fault only.
Wednesday,17,February,2021,12:05:54:36108
VCDS Version: 20.12.0.1 (x64) HEX-NET CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: WV2ZZZ7HZCH133237 License Plate: AJ62
Mileage: 141750km-88079mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 69 78 0B
VIN: WV2ZZZ7HZCH133237 Mileage: 141750km-88079miles
0D-Slide Door, Left -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
69-Trailer -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JD HW: 03L 907 309 H
Component: R4 v002 EDC X36 8749
Revision: 22X36--- Serial number: 00000000000000
Coding: 0125401A232400080000
Shop #: WSC 79883 336 16496
ASAM Dataset: EV_ECM20BTD01103L906022JD 002011
ROD: EV_ECM20BTD01103L906022JD_002.rod
VCID: 70ACD288AB2E1F04F2-8024
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1789
Revision: 00H05V01
Coding: 0018
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_A01_VW36.rod
VCID: 3FCE41B4A6F0B07C3B-806A
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD09A7089826A49074AA6510
Shop #: WSC 02756 790 49152
VCID: 393A2FACB0D49E4C05-806C
Serial number: 13011913470275
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB0FCB0E17A797470-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AC HW: 7E5 907 040 AC
Component: ClimatronicT5 H19 0407
Revision: 00001003
Coding: 0004000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 699ABFEC88F4EECCB5-803C
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0012304120015096
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 170170512
Coding: A0B279B82E61241393288ED06CEB8EDD5580612F60846040300003020800
Shop #: WSC 02737 534 163773
VCID: 2B1605E44A883CDC87-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180412 05 54 0403
Coding: 02302E
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Coding: 010000
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 171
1 Fault Found:
02746 - Bulb for Daytime Running Light; Right
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 66
Reset counter: 191
Mileage: 141755 km
Time Indication: 0
Date: 2015.07.11
Time: 23:09:37
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02756 790 00000
VCID: 302C1288A3AE5F04B2-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 E HW: 7E0 919 475 A
Component: PARKHILFE 8K H11 0013
Revision: -------- Serial number: 47461208500166
Coding: 108102
ASAM Dataset: EV_VW75XParkAssis8K A01005
ROD: EV_VW75XParkAssis8K_A01.rod
VCID: 34241E989FB66324D6-8060
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H07 0013
Revision: -------- Serial number: 003HM002866L
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3620249089CA7134E8-8062
Serial number: 3495ZRB405B0P7HOEHCF
Serial number: 3505ZRB40510P7AOGGM1
Part No SW: 7E0 920 980 E HW: 7E0 920 980 E
Component: KOMBI H04 0306
Coding: 460F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2D120BFC7C9C32EC99-8078
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2404EED8E756F3A446-8070
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042305
VCID: 689CBAE89BFED7C4AA-803C
Component: IMMO H04 0306
Serial number:
VCID: 6A98C0E08DF2E5D4BC-803E
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000509112665
Coding: 0100000101000000
VCID: 322818806DA26D14C4-8066
Address 78: Slide Door, Right Labels: Redir Fail!
End----(Elapsed Time: 01:59, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
[CODE]
Limalex
I am not using the car daily but yesterday took the Caravelle to work to test the CC Emulator ( which is not functioning at the moment) Anyway The Auto light works the way that it switches to low beam and CH/LH works however, does not switch to high beam and cornering function still not working.
Today I received the two quality Osram W5W LEDs for the front so I replaced them. and Low beam faults come back.
Here is todays scan
Here is todays scan
Thursday,18,February,2021,16:22:33:36108
www.Ross-Tech.com
Mileage: 141790km-88104mi Repair Order:
VIN: WV2ZZZ7HZCH133237 Mileage: 141790km-88104miles
Revision: 00H05V01
Coding: 0018
Revision: 00H43001
Coding: 01
Revision: 00001003
Coding: 0004000102
Slave 1:
Coding: 02302E
Coding: 010000
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 141791 km
Time Indication: 0
Date: 2015.07.12
Time: 00:07:33
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 141791 km
Time Indication: 0
Date: 2015.07.12
Time: 00:07:33
Coding: 108102
Coding: 460F01
Coding: 0000031
Revision: B9082001
Coding: 042305
Serial number:
End----------(Elapsed Time: 02:00, VBatt start/end: 13.9V/13.8V)-----------
[CODE]- ciclo
In this case, 55 'Hex' is the hexadecimal representation of Byte 16, instead of the binary representation (01010101).
In any case, it has not had any effect, and it is due to how the halogen lights are parameterized in the BCM (in your case), which in turn depends on how Byte18 is coded.
The multiple combinations of 'Bits' in Byte18 parameterize the set of lights with the correct values for each original PQ25 model.
For your new OSRAM Low Beam LED lamps you will have to try different codings on Byte 18 (63, 65, 67), and maybe play with the PWMs on Byte 16 for Low Beam.
With the 67 Hex value in Byte 18 very good results are obtained when some people retrofit aftermarket headlights, but these headlights usually have a respectable Amp draw.
You can also go back to the original halogen lamps, you can be sure that the Autoscan will be clean of faults.
I believe that with VCP you can modify some parameters for fault detection, but I prefer not to do it, so I do not recommend it, I would rather live with the detected faults in the Autoscan if there is no warning lamp in the instrument panel.
High beams and SCLs should work properly, according to Autoscan, ... in previous posts you commented that the high beams were working properly viewtopic.php?p=580324#p580324, but since you are doing work on the T41 connector, any result is possible ...
as I told you, it would have been better to do the BCM Max and the 7E0 stalks adaptation/wire installation first, and later the CCE installation.
My recommendation is that you finish the work on the T41 connector for CCE and then do a report on the operation of the lights.
Limalex
Thank you the clarification Ciclo.
I will play around with the coding and see what else can I try, but no warning light on dash so I am very happy an thank you all your support.
As for the high beam I did not say it not working. It working fine with the switch. The Auto function not switching the high beam when the road clear ahead. I am not sure if VW does this function, but my CRV in auto function changes between low and high beam on motorway.
I might need some help with the emulator. Should I open a new thread for that?
At the moment I messed up something very badly and no horn no functions at all on the steering wheel and it does not lit up either.
I will order some terminals and remake the T41/ 26,27,28,30 31 wires because the originals damaged during removal and crimping probably was not a good idea.
Well the first thing, don't worry excessively and have a totally positive attitude, we are going to solve this mess, nobody is perfect! .... except me.
You do not need to open any new thread, this thread is your total property, the masters of the universe have granted it to you forever so that you can contact the rest of the universe. I am sure that we can solve all your concerns about the T41 connector.
We will need pictures of the current state of your T41 connector, to better guide you on what to do, please take pictures from various angles from T41 connector.
In the same way you read the adaptation channels for the BCM MAX 7E0 D viewtopic.php?p=574089#p574089 read the current BCM C channels and please provide me with a link to the file. I have to see what happens with the high beam in Auto, it should work the same way as in your CRV.
Thanks Alex.
We will solve it!
Thanks Alex.
We will solve it!
I think I did not understand you well ...
You mean that with the switch in Auto position, it doesn't automatically switch between high beam and low beam, it's right?
Limalex
Yes correct.ciclo wrote: Sun Feb 21, 2021 6:17 am I think I did not understand you well ...
Limalex
I am perfect toociclo wrote: Sat Feb 20, 2021 8:39 pm Well the first thing, don't worry excessively and have a totally positive attitude, we are going to solve this mess, nobody is perfect! .... except me....
I feel so special that the whole universe masters here at my disposal. Really appreciate it
Here is the link for the log CSV https://drive.google.com/file/d/168LyQP ... sp=sharing
The installation of the CCE requires some explanation. As I mentioned some mistakes happened at my part even dough I am perfect too
The wire colours are not the genuine colours on the 8E0971980 Coupling because the little MQS terminals broke into the T41 connector. It happened maybe my lack of patience
Pin1 - empty
Pin2 is the extra green/black goes to T41/10 LinBus MFSW
Pin3 original Blue/Black
Pin4 original Orange/yellow
Pin5 - empty
Pin6 - empty
Pin7 Yellow to LinBus T73b/17
Pin8 original Blue/Yellow
Pin9 original Blue with yellow stripes
Pin10 original White
Here are some pictures. Sorry some of them a bit blurry
- IMG_0090.jpg (362.21 KiB) Viewed 5388 times
- IMG_0092.jpg (466.44 KiB) Viewed 5388 times
- IMG_0091.jpg (541.03 KiB) Viewed 5388 times
- IMG_0094.jpg (242.89 KiB) Viewed 5388 times
- IMG_0093.jpg (307.33 KiB) Viewed 5388 times
- IMG_0089.jpg (390.73 KiB) Viewed 5388 times
- IMG_0088.jpg (843.85 KiB) Viewed 5388 times
- IMG_0084.jpg (744.64 KiB) Viewed 5388 times
Alex, it is possible to have the automatic function to switch between LB and HB, but it is necessary to install a camera to make it possible.
For the PQ25 the camera is installed in the rear view mirror.
This function is called High Beam Assist or Light Assist.
Related information
... but you already knew this, right?
Returning to the matter, your high beams work perfectly in the Auto position ... manually.
Some MQS terminals on the T41 connector are difficult to remove, or at least have a strange way of being removed.
When the MQS terminals are removed from the T41 slots, the metal retaining tabs on the terminals are jammed a second time during the removal stroke.
It is necessary to use a small hook (L shape) to re-release the tab from the terminal. You can even make this L-shaped hook out of an office clip.
This is the hole where you can insert the hook to release the MQS terminal tab a second time:
I recommend using a flashlight to illuminate the hole in its entire depth and to be able to press on the tab of the exact terminal that you are releasing.
Limalex
Hi Ciclo,
No I was not aware of the camera unfortunately. It not something I wish to do right now.
I planning to retrofit heated windscreen at some point in the future.If/ when I doing I will consider the mirror upgrade.
I am extremely happy with results as it is right now
May I ask why should we bother with MQS terminals remaining bits removal?
I spent two hours in the morning without a success.
They are not connecting to anything anyway. The stalk does not have any pins for those locations.
I believe the problem is in the wiring of the new connector. I was distracted many times during I was doing that and it is possible that I mixed up some wires.
Is it possible?
It is very strange that the SW lost all functionality and does not lit up at all also the horn operates with the 0/1 button only
I have some wiring diagrams for the T5.1 I will try to identify the wires by colour and confirm whether I put them in a right location or not.
Is it possible?
