Upgrading BCM to MAX
Re: Upgrading BCM to MAX
The height leveling of the bi-xenon headlamps only works if you have the 55 unit installed ... magic has its limits.
Interior lights for switches viewtopic.php?p=580205#p580205 :?:
61 :?:
I am not asking you for a complete autoscan because post it only depends on you.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Ahh thought so, well 55 will be a spring project 8)
Interior wires are done like
61 will be enable in the weekend, ran out of connectors for the lin wire :shock:
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Connectors came early 8)
61 :!: is now enabled -- But start/stop would be nice to have permanently off
Interior lights working :!:
Its more or less only high beam and cornering lights I would like to have fixed :mrgreen:
Latest autoscan with a new error code for high beam
VIN: WVWZZZ6RZCY508726   Mileage: 200180km-124386miles
Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 ME    HW: 03L 907 425 B
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023ME 003014
   ROD: EV_ECM16TDI02103L906023PL.rod
   VCID: 75B7E3E0754F3FF3504-8020
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3416D00BA842C14E482D700521300
   VCID: 074B99281F633D63328-8052
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38292AD4225D829B8B2-806C
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
            013 - Check DTC Memory - Intermittent
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 200183 km
                    Time Indication: 0
                    Date: 2015.07.12
                    Time: 00:04:51
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 320160060
   Coding: 3CB02FB848210000213807B17DEB1FD85A80672F600530C1200000030000
   Shop #: WSC 00763 204 00001
   VCID: 2A0D009CECF1200B0D6-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 270611 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100017565
   Coding: 58BC30
   Subsystem 3 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU015061100015010
   Coding: 48BC30
   Subsystem 4 - Part No SW: 2H0 959 442     HW: 2H0 959 442
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000235390058087
   Coding: A4FFFF
   Subsystem 5 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU018061100010892
   Coding: 48BC32
   Subsystem 6 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010061100016888
   Coding: 48BC32
1 Fault Found:
03906 - Control Circuit for High Beam Relay
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 200183 km
                    Time Indication: 0
                    Date: 2015.07.12
                    Time: 00:58:21
   Part No SW: 6R0 959 655 L    HW: 6R0 959 655 L
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GY003PE4D
   Coding: 003232
   VCID: 4BC36518434B1903D60-801E
   Serial number: 3575HRB404R0H4DK41GD
   Serial number: 3585HRB40650CTC46HJI
   Serial number: 3515RRB404R0M8GCLH4%
   Serial number: 3525RRB404V0M8GC28O$
   Part No SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Component: KOMBI         H03 0505
   Coding: 540E01
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3A2D30DC1CD1908B7D6-806E
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 2500C2
   VCID: 6889BA94327DD21BDB2-803C
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC09C2CF1E00BCD6-803E
Address 44: Steering Assist        Labels: None
   VCID: 55F783609C4F5FF3704-8000
   Part No SW: 5K7 035 200 L    HW: 5K7 035 200 L
   Component: MU-S--ER      H41 0478
   Serial number: VWZAZ2U0687010
   Coding: 065700003C00000011110001000808001F0100C40020010002
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 2D070B80DD9F3733E84-8078
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 200183 km
                    Date: 2021.02.18
                    Time: 00:04:48
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name:
15360256 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 200183 km
                    Date: 2021.02.18
                    Time: 00:04:48
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 200183 km
                    Date: 2021.02.18
                    Time: 00:04:51
                    Voltage terminal 30: 11.7 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H81 0744
   Coding: 030B1A5A
   Shop #: WSC 12345 123 12345
   Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900687690
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:23, VBatt start/end: 12.9V/12.0V. VIgn 12.0V)-----
Due to the autoscan, who made and installed your wiring for automatic lights?
Check it.
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
Did it myself according to your diagram, will double check later today
t17 to t10 alw.PNG (257.1 KiB) Viewed 869 times
jiimien
Drives: 6R 1.6 TDI
Post by jiimien »
ciclo wrote: Fri Feb 19, 2021 5:51 am Due to the autoscan, who made and installed your wiring for automatic lights?
Check it.
Of course! it was my error.. It's fixed now, and everything works perfectly!!! :mrgreen: :mrgreen: :mrgreen:
Thank you for all of your help! It's much appreciated !
Two quick follow-up questions:
Is it possible to code Reverse gear, to turn both cornering lights on?
and
is it possible to turn them manually on, maybe via a lightswitch with front fog lights, this is of course not for public road.
(I live down a 1km long gravel road, where the extra light could useful to spot animals)
Otherwise just very thank for your help! :D :D
