peter_dk25
Drives: Blue GT
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by peter_dk25 »
Thanks a lot, Ciclo - I will consider the BCM change again :-)
So I decided today was a good day to change the battery. The 105 Ah battery was from 2016 and was showing mild signs of wear.
Since my current setup doesn't require an expensive AGM battery anymore, I decided to go for a 'normal' EFB. The Bosch S5 015.
110 Ah, 920 CC to start my monstrous V12... I mean 1.2L.
Fun fact, the previous battery was an OEM JCB 105 Ah VW battery from a Touareg V10 TDI:
Next to the normal size 60 Ah for this car:
In the car:
Coding is needed for cars with the BDM battery monitoring:
61 - battery Regulator
Long adaptation
Battery replacement information
Changed "VA0 105 1111111114" to "VA0 110 1111111115".
VA0 stands for Varta (since Bosch and Varta are the same battery, just a different sticker), 110Ah and a theoretical serial number 1111111115 (the 5th battery in this car).
1 - OEM battery (4 years, died after a full flat)
3 - Bosch S5A AGM (1 week, replaced under warranty)
4 - Bosch S5A AGM (4 years, died after a full flat)
Then I realised that my heavy modding probably put a bit more strain on the battery... so bigger is better and the battery moved to the boot to allow 353x175x190mm
4 - VW 105Ah AGM (2 years, used battery, in ok condition but sometimes ABS lights show after start/stop and radio goes off)
5 - Bosch S5 015 110 Ah new
So now after 10 years, the 5th battery in my Polo 6R
Wow 110 battery :mrgreen: i didnt know that other polos had foam/ish insulation in the spare tire well.
This is the setup from Polo GTI/WRC
Huge 110 battery, ... something in your 6R is parasitizing power from your batteries. 🤭 😉
The original battery from my 6R died shortly after about 8.5 years, but it was installed in the 9N3 which is the car used by my father-in-law, and every now and then he forgot to turn off the light switch. 😄
Haha, well, my car was born with 13 control modules incl slaves but not counting internal modules (like 17 + 25):
01, 03, 04, 08, 09 + 2 WRM, 15, 17, 19 (external), 25 (internal) 44, 56, 61 (internal) +1
In the current state, the car has a little more :mrgreen: it's 33, not counting internals:
01, 03, 04 (internal), 05, 08, 09 + 8, 10, 15, 17, 19 (internal), 20, 25 (internal) 2B, 2E, 37/56, 3C +1, 44, 47, 55, 56, 57 +1, 61 (internal) + 1, 65, 69, 6C, 77
fun fact, the sole surviving module from factory is the 01 controller.
03 -> ESP8.2i to 9.0i
04 -> replaced with 6C steering racks internal sensor
05 -> Kessy added
08 -> upgraded to climatronic
09 -> upgraded to 7E9 090 -> 090B -> 090C + slaves: front WRM replaced with folding mirrors, rear WRM added, MFSW added, RLS added, DWA sensor + horn added
10 -> added 7E0 8K PDC -> 1K8 8K PDC
15 -> upgraded to passenger deactivation
17 -> replaced with MFA+
19 -> removed with BCM 7E0 upgrade
20 -> HBA added
25 -> replaced with MFA+
2B -> ELV added for kessy
2E -> MDI added
37-> upgraded RCD210 to RNS510 -> RNS510 with DAB+
3C -> added SWA (2x)
44 -> replaced electrohydraulic with electromechanical power steering
47 -> added dynaudio
55 -> added AFS
56 -> see 37
61 -> see 09, replaced battery sensor in the engine bay with 6C sensor from GTI in the boot
65 -> added TPMS direct
69 -> added trailer coupling
6C -> added RVC high
77 -> added bluetooth module
and only the 10, 22, 55 and the 3C live on the +15 line, all the other ones live on the +30 line.
dominis23
Drives: POLO 6R
Post by dominis23 »
Hi, I have a question. I put on the 8P0035503K (GPS; GSM) antenna. I have a Polo 6R in the flap, I have no space for a second antenna (amplifier). Can you tell me where you connected the second amplifier?
yes, also to the rear glass on the other side. there are two places for the amplifiers, left and right.
dominis23
Drives: POLO 6R
Post by dominis23 »
Thanks for the answer. However, on the right side, I have no place where I can solder this amplifier to the glass.
Yes, you'll need to create your own soldering point but that's not too hard.
New mod: Ibiza 6J 6J0959441A multifuntion module / RNS remote
part: 6J0959441A + 1K0972704G
Wiring:
SA3 -> SC46 is +30
Address 4B: Multifunc. Module        Labels: None
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Coding: 0000002
   Shop #: WSC 17603 003 00000
   VCID: 3163E654D15B
https://streamable.com/mq875g
The only problem is, as soon as 4B is registered in the CAN gateway, the MFSW stops working. Do you perhaps have an idea on this, ciclo?
it is certainly possible to have 4B besides an MFSW:
Thanks you in advance for your answer
This is my car Autoscan (i clear the faults codes on my engine now) :
Chassis Type: 6N0
Scan: 01 02 03 08 09 10 15 17 19 25 2E 44 4B 55 56 77
VIN: VSSZZZ6JZAR063156
4B-Multifunc. Module -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (------CAVE) Labels: Redir Fail!
Part No SW: 03C 906 027 AE HW: 03C 906 027 AD
Component: MED17.5.5 H10 5034
Revision: L2H10--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM14TSI03C906027AE A01007
ROD: EV_ECM14TSI03C906027AE.rod
3 Faults Found:
4063 - Cylinder 4: Misfire Detected
P0304 00 [096] - Cannot Be Tested at this Time
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 485 km
Date: 2001.14.11
Time: 16:46:07
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - Mechanical Failure
Fault Priority: 2
Fault Frequency: 1
Mileage: 485 km
Date: 2001.14.11
Time: 16:46:07
4655 - Brake Boost Vacuum System: Mechanical Failure
P1479 00 [096] - Cannot Be Tested at this Time
Readiness: 0000 0000
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 047 T HW: 0AM 927 769 D
Component: GSG DSG AG7 402 1310
Revision: 00040024 Serial number: 00000909110492
Coding: 0000020
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Coding: 110248DB837300B5882612E7C1D700411700
Shop #: WSC 04941 000 00000
Address 08: Auto HVAC Labels: None
Part No SW: 6J0 820 043 A HW: 6J0 820 043 A
Component: Climatronic H07 0404
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0025
Revision: BF009001 Serial number: 9955A257090788
Coding: 3C8829EF88610100092800007E0B1FC800C0420F608C00002000
Shop #: WSC 64564 324 38760
Part No: 1K0 955 559 AH
Component: RLS 090909 05 54 0402
Coding: 03302D
Part No SW: 6R0 959 801 A HW: 6R0 959 801 A
Component: J386__TSG_FT 001 0248
Coding: 020000
Part No SW: 6R0 959 802 C HW: 6R0 959 802 C
Component: J387__TSG_BT 001 0252
Coding: 020000
Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Coding: 000003
Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 010000
Address 10: Park/Steer Assist (J446) Labels: 6J0-919-475.clb
Part No SW: 6J0 919 475 A HW: 6J0 919 475 A
Component: PARKHILFE 4K H07 0007
Revision: -------- Serial number: 80320926500522
Coding: 000106
ASAM Dataset: EV_SE250ParkiAssis2 S01006
ROD: EV_SE250ParkiAssis2.rod
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA01 H09 0018
Revision: -------- Serial number: 003DW006H6SJ
Coding: 003031
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250_SE25.rod
Part No SW: 6J0 920 801 D HW: 6J0 920 801 D
Component: KOMBI H07 0110
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 422000
Component: IMMO H07 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 2E: Media Player 3 (J650) Labels: None
Part No SW: 6J0 035 342 B HW: 6J0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667564470
Coding: 020000
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10121
Shop #: WSC 06402
Coding: 0000002
Shop #: WSC 77005 000 00000
Address 55: Xenon Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0136
Revision: 00H04000 Serial number:
Coding: 2688036
Part No: 7L6 941 329 C
Component: AFS-Lst.-Modul l 0004
Coding: 00000041
Component: AFS-Lst.-Modul r 0004
Coding: 00000041
Address 56: Radio (J503) Labels: None
Part No SW: 6J0 035 153 HW: 6J0 035 153
Component: Radio H11 0027
Revision: R0000000 Serial number: SEZAZ1I7269434
Coding: 0002040002
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 C HW: 1Z0 035 729 C
Component: FSE_2P8x H35 0170
Revision: 00000000 Serial number: 00000005093275
Coding: 0010730
End ---------------------------------------------------------------------
Code:
Saturday,08,June,2019,10:05:09:27911
VCDS Version: 19.6.0.2 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: VSSZZZ6JZFR155588   License Plate: IBIZA
Mileage: 400km-248mi   Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZFR155588   Mileage: 400km-248miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
  Part No SW: 03F 906 070 GS    HW: 03F 907 309 AE
  Component: SIMOS10.22AH10 5494
  Revision: --H10---    Serial number:
  Coding: 002500D6202400080000
  Shop #: WSC 00049 770 00189
  ASAM Dataset: EV_ECM12TFS02103F906070GS 004007
  VCID: 79F9E5A8F8B45587D6-802C
Readiness: 0010 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
  Part No SW: 0AM 300 062 P    HW: 0AM 927 769 D
  Component: GSG DSG AG7     431 6201
  Revision: 00043014    Serial number: CU501504196286
  Coding: 0000020
  Shop #: WSC 01324 785 00200
  VCID: 397925A87034958796-806C
Address 03: ABS Brakes (J104)       Labels: None
  Part No SW: 6R0 907 379 BQ    HW: 6R0 907 379 AS
  Component: ESP9.0i front H03 0002
  Serial number: --------------
  Coding: 13DD287D412800C5C8191471825900880909
  Shop #: WSC 00788 648 00255
  ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
  VCID: 0E13A674D13A623F13-805A
2 Faults Found:
0018 - Suspension Sensors
         C104B 29 [008] - Signal Implausible
                   Fault Priority: 2
                   Fault Frequency: 1
                   Reset counter: 121
                   Mileage: 381 km
                   Date: 2019.06.03
                   Time: 01:02:44
0625 - Display for Tire Pressure Monitoring
         C1146 02 [137] - Signal Failure
                   Fault Priority: 2
                   Fault Frequency: 5
                   Reset counter: 0
                   Mileage: 380 km
                   Date: 2019.06.03
                   Time: 01:00:57
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
  Part No SW: 6R0 959 654     HW: 6R0 959 654
  Component: LENKW.SENSOR  H07 0070
  Serial number: 02051504651961
  Coding: 01
  Shop #: WSC 00000 000 00000
  ROD: EV_LWSKLOVW25X.rod
  VCID: 7EF3F6B4E19A72BFE3-802A
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
  Part No SW: 6J0 820 043 E    HW: 6J0 820 043 E
  Component: Climatronic   H03 0809
  Revision: S0000000
  VCID: 2643FED4518A0A7FCB-8072
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
  Part No SW: 7H0 937 090 D    HW: 7H0 937 090
  Component: BCM PQ25 Max4 H78 0725
  Revision: B9078001    Serial number: 0671 119150936
  Coding: 24882BE88861250093380EF06FCB9EC80FC063A9608C2049200000020000
  VCID: 2F6D1BF07E704B3738-807A
  Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
  Component: RLS 160415 05  54  0403
  Coding: 02242D
  Subsystem 2 - Part No SW: 6R0 959 802 AP    HW: 6R0 959 802 AP  Labels: 6R0-959-802.CLB
  Component: J386__TSG_FT  007 5110
  Serial number: 13202558140623154835
  Coding: 030000
  Subsystem 3 - Part No SW: 6R0 959 801 AM    HW: 6R0 959 801 AM  Labels: 6R0-959-801.CLB
  Component: J387__TSG_BT  007 5110
  Serial number: 13202563150303030918
  Coding: 030000
  Component: DWA-Sensor 00  001 0103
  Component: LIN BACKUP HO  H05 1501
  Subsystem 7 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B
  Component: E221__MFL-TAS  H30 0036
  Serial number: 0211742
  Coding: 010000
  Subsystem 8 - Part No SW: 6R0 959 811 K    HW: 6R0 959 811 K
  Component: J388__TSG_HL  006 5110
  Serial number: 13202567150504135456
  Subsystem 9 - Part No SW: 6R0 959 812 K    HW: 6R0 959 812 K
  Component: J389__TSG_HR  006 5110
  Serial number: 13102566150505065459
1 Fault Found:
03591 - Control Circuit for Horn
           011 - Open Circuit
                   Fault Status: 01101011
                   Fault Priority: 3
                   Fault Frequency: 19
                   Reset counter: 82
                   Mileage: 357 km
                   Time Indication: 0
                   Date: 2019.06.03
                   Time: 02:58:33
Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
  Part No SW: 6J0 919 475 E    HW: 7N0 919 475
  Component: PARKHILFE 8K  H01 0018
  Revision: --------    Serial number: 28291510300888
  Coding: 100102
  ASAM Dataset: EV_SE250ParkiAssis8K S01002
  ROD: EV_SE250ParkiAssis8K.rod
  VCID: 387F20AC833E8C8F69-806C
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
  Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
  Component: VW10AirbagA0D H10 0020
  Revision: --------    Serial number: 003GX02AKSUD
  Coding: 003044
  Shop #: WSC 00049 770 00114
  ROD: EV_AirbaVW10BPAVW250.rod
  VCID: 4A9B6A64EDD20E1F0F-801E
  Serial number: 3495RRB405D36OUMDH3B
  Serial number: 3505RRB405P36OUMFGT%
1 Fault Found:
9447251 - Seat Occupied Sensor; Passenger's Side
         B1027 53 [009] - Deactivated
                   Fault Priority: 6
                   Fault Frequency: 1
                   Mileage: 357 km
                   Date: 2019.06.03
                   Time: 02:57:52
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
  Part No SW: 6J0 920 907 P    HW: 6J0 920 907 P
  Component: KOMBI         H02 0805
  Coding: 110A01
  ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
  VCID: 3B753FA0B208A79784-806E
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
  Part No SW: 6N0 909 901     HW: 7H0 937 090
  Component: GW-K-CAN TP20 H78 0725
  Revision: B9078001
  Coding: 022200
  VCID: 70EFD88CA3CE14CF61-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
  Part No SW: 5K0 953 234     HW: 5K0 953 234
  Component: IMMO          H02 0805
  Serial number:
  ROD: EV_Immo_UDS_VDD_RM09.rod
  VCID: 6ADBCAE48D12EE1F2F-803E
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
  Part No: 6R0 423 156 C
  Component: LenkhilfeTRW        V278
  Coding: 11221
  Shop #: WSC 00788
  VCID: 306F188CF74E54CF21-8064
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
  Coding: 0000002
  VCID: 31691D88A8445DC72E-8064
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
  Part No SW: 6J0 035 156 A    HW: 6J0 035 156 A
  Component: Radio         H04 0013
  Revision: R0000000    Serial number: SEZAZ1R6894021
  Coding: 010004080203
  VCID: 2541F9D82C8C0167C2-8070
End-------------------------(Elapsed Time: 03:24)--------------------------
Tuesday,30,March,2021,15:00:13:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 21.3.0.0 (x64)  HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN:   License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 4B 55
          56 57 61 65 69 6C 77
VIN:
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Not registered 0001
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033400080000
   Shop #: WSC 31889 470 31889
   ASAM Dataset: EV_ECM12TDI03103P906021B
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 270B06DDAF6FF1F3EE9-8073
Readiness: 0 0 0 0 X
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Coding: 21DD2885432500C5841A146EC25500521505
   VCID: 0F7B4E7D27DF89B3069-805B
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   Shop #: WSC 31889 047 31889
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF61737E9-8063
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B773-806D
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB82BBF28EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
   VCID: 2B03FAEDB307D5930A1-807F
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0031195101
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 55F77C15C583B3638C5-8001
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [009]
Address 15: Airbags        Labels:. 5K0-959-655.clb
   Revision: J234     Serial number: --------
   Coding: 5657313041697262616730314D
   Shop #: WSC 01383 785 00200
   VCID: 4ACD9F691C3DEC9B117-801F
No ASAM data for: "" (VW25)
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   Shop #: WSC 12345 123 12345
   VCID: 3333E28D6BB78D53421-8067
No ASAM data for: "" (VW36 *)
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 688945E162713E8B273-803D
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 71331 km
                    Time Indication: 0
                    Date: 2063.14.08
                    Time: 13:57:52
   Component: FLA           H10
   Revision: AA001001
   Coding: 0404000000000000010000
   VCID: 2E05F3F98095A0BB2DF-807B
Address 25: Immobilizer (J334)       Labels:* None
   Part No HW: 5K0 953 234
   Coding: 000007
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   VCID: 2F3BEEFD879FA9B3269-807B
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987B65F-8063
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3269-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
   Subsystem 4 - Serial number: H21982ÿ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 001F00
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB703C8D-802D
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE8BE73-807D
   Coding: 0000002
   VCID: 313FE8859D2BBF4330D-8065
Address 55: Headlight Range        Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   VCID: 3A2DCFA94CDD7C1B817-806F
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8BE73-807D
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F7A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Component: RDKBERU30     H04
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3269-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E31C5-8031
Address 77: Telephone        Labels: None
   Part No HW: 3C8 035 730 E
   Component: Telefon       025 Telefon       025 0983
   Revision: J412     Serial number: 35502105254406
   Coding: 00
   ASAM Dataset: EV_UHVPremi 002709
   ROD: N/A
End----------(Elapsed Time: 02:55, VBatt start/end: 13.0V/12.9V)-----------
I suppose it is the same principle that when the controls for the trip computer are installed simultaneously in the Stalk and in the Steering wheel, it generates a communication conflict.
I know you want to install them because you want to have more modules in the Autoscan 🤭... (since you lost the MFSW reading when installing the CCE)
Ross-tech is going to have to design a new type of Autoscan for you ... like a book or something like that... :lol:
You are totally crazy 😆... :arrow: ... that point of madness that makes everything great.👌
ciclo wrote: Wed Mar 31, 2021 5:05 am I suppose it is the same principle that when the controls for the trip computer are installed simultaneously in the Stalk and in the Steering wheel, it generates a communication conflict.
Yes I had the same thought. What is interesting is that there are some Ibiza's with both the MFSW and the 4B module. But the 4B buttons and MFSW do work simultaneously, just not when 4B is checked in the gateway installation list.
So I was sort of slightly hoping that you would perhaps have an idea :D
Yes, guilty as charged. A gateway installation list is not a listing, it's a to-do list.
Well, in all seriousness, I've been asking them to make some custom ASAM data records/lists, since some of these modules simply don't belong in a Polo 6R (VW25 platform).
This is modules like the 5c0 47 sound system and 77 3c0 telephone module. But ross tech never failed to help me out :) it's great!
https://forums.ross-tech.com/index.php?threads/26919/
Hmm... what would happen if you enable Byte4 Bit7 in the BCM?
;LC,04,7,"Hotkey" Funktion aktiv (derzeit nur für SEAT)
iichel wrote: Wed Mar 31, 2021 8:42 am
:lol:
Ross-tech forum as cool as ever, ... super people!
Byte 4 bit 7 did not make a difference unfortunately. I'll try to connect the mfsw to the other Lin pin on the bcm, just to give it a try
