Polo brake shoe replacement
Poc854
Drives: VW polo
Post by Poc854 »
Tomorrow I will be changing the brake shoes on my polo and I'm just wondering if I need to remove the hub before I go out and buy the socket to remove it.
CarbonChaos
Re: Polo brake shoe replacement
Post by CarbonChaos »
I believe it can be done without removing the hub,but it does make the job a whole lot easier if you do remove it.
Good luck let us know how it goes
Poc854
Drives: VW polo
Post by Poc854 »
Ok thank you think I'll just remove it, I'll update tomorrow
In case you didn't know, the socket size for the rear hub nut is 30mm bihex, ie 12 point, that nut is, I seem to remember a nyloc nut so should not be reused or maybe you will get off with degreasing the threaded hub and applying blue Loctite.
Poc854
Drives: VW polo
Post by Poc854 »
Thank you for Letting me know, I'll just play it safe and replace it
Poc854
Drives: VW polo
Post by Poc854 »
So another question would cooper grase be ok to use on the hub
Poc854 wrote: Sun Mar 28, 2021 12:47 pm So another question would cooper grase be ok to use on the hub
Do you mean a very slight covering of that over the hub face to stop the drum sticking to it and on the outer face of the drum to stop the wheels sticking on - if so, yes though many of us have moved onto using ceramic loaded grease and/or aluminium loaded grease especially for the outer face if you have alloy wheels. I did use Copaslip for maybe 35 years with no noticeable adverse effects, but now I've moved on to ceramic and aluminium greases saving the last of my Copaslip for other areas. In the hub bearing I'd be using a high temperature lithium based grease or moly based grease depending on what the colour of the grease already there is.
Poc854
Drives: VW polo
Post by Poc854 »
Ok I'll keep that in mind, thank you.
