Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
ow...
Please keep us posted, this is very interesting.
Remember to code BCM Byte29 Bit6 if use the other LIN (b36?) ... you already know. :wink:
Yes I remember from the other experiments. I'll inform you. Do you have any Erwin pdfs for this Ibiza?
til3tsio
Drives: Seat Toledo KG
Re: iichels Polo 6R 1.2TDI Rosa Line Bluemotion
Post by til3tsio »
iichel wrote: Sat Mar 03, 2018 2:16 pm for my Golf 7 light switch, the back of the 5ND switch was a 1:1 swap, I can still use the 8E0 connector 8)
I know its been a while but do you remember what part numbers you combined ?
If i am not mistaken the 5ND switches has screws on the back of the switch but the 5G0 has locking tabs.
til3tsio wrote: Thu Apr 01, 2021 1:14 pm
I don't remember but I had a look, it was 5GG941431D. Which is probably an Aliexpress part, but can't say for sure.
MFSW to T73b/36 + byte 29 bit 6 = fail too with 4B in the gateway installation list.
ciclo, do you know anything about the MFSW codings (so the E221 module itself) for 5K0/6C0/5G0 buttons?
So far I've only been able to identity byte 0 bit 0 (DSG paddles installed) and bit 7 (PQ/MQB platform) in the 5G0 wheels.
Byte 0 bit 5 seems to be 1 all the time, while bit 6 seems to be 0 all the time.
I haven't discovered yet why sometimes the values are FF FF for byte 1/2 or 00 00. There doesn't seem to be a pattern.
dominis23
Drives: POLO 6R
Post by dominis23 »
iichel wrote: Thu Feb 11, 2021 1:27 pm I took it from scirocco 1k8
I still have a question if you did parameterization of the amplifier. If so, you did vcp or odis
No I did not.
iichel wrote: Mon Apr 05, 2021 8:14 pm ciclo, do you know anything about the MFSW codings (so the E221 module itself) for 5K0/6C0/5G0 buttons?
Some time ago I did a study about it, but now I can't find the file ... sorry. :oops:
The important coding is in Byte0, ... what you have already mentioned - DSG and platforms -, and for the speed control system buttons - Yes/no: CCS, ACC, and other small differences in button configuration -.
Also some time ago I tested FF and 00 for Bytes 1 and 2 on the 6R and also in my wife's Golf for the sports steering wheels that I installed and there were no differences in performance, nor were there any faults in the Autoscan.
I have normally found that FF was used for sports steering wheels and 00 for standard steering wheels but it doesn't seem to be relevant.
In MQB, these modules are currently self-coding when installed.
Davidek66
Drives: 6r 1.6tdi
Post by Davidek66 »
Love the white LED conversion inside 🥵 do you know which led’s you have used for the buttons like ESP, Heated Window etc? Been trying loads of LED’s but cannot get it to work.. or did you use any resistors?
I'm really sorry but I don't remember
dominis23
Drives: POLO 6R
Post by dominis23 »
Hi you are able to send me a flash from the amplifier (5C6035456C). Unfortunately, vcp support is not able to help me. greetings
Today my new Mirabeau wheels received their TPMS sensors too. Great thanks to my local tire service company. They always help me well with alignment and tire changes.
since you're all taking such great interest in my project :mrgreen: :mrgreen:
Rear Polo AW 'Polo' text --> 6N5853687 2ZZ
2021-04-29 09.15.46.jpg (1.78 MiB) Viewed 4556 times
1.2 TDI engine :)
