Seat Ibiza 6J, 2.0 TDI FR, Auto Lights Retrofit (BCM 88D)
MIH11MI6
Drives: 6J FR 2.0TFSI CDLJ AWD
Re: Seat Ibiza 6J, 2.0 TDI FR, Auto Lights Retrofit (BCM 88D)
Post by MIH11MI6 »
Interior dimmer is working!
Coming home lights are working (side lights and dipped beam)
Output tests for brake lights successful
Indicators working
Dipped beam output test successful, auto lights not working with ignition on simulating darkness though, will investigate
Getting close!
Waiting on full beam relay to finish
But the big thing is that the coming home is working with the RLS. Couldn't be happier :D
MIH11MI6 wrote: Sat Dec 19, 2020 10:21 am
MIH11MI6 wrote: Sat Dec 19, 2020 9:29 am
iichel wrote: Sat Dec 19, 2020 6:23 am Yes you're right.
3C8829EFC8F32500932006007E8B9EC81080610F60882000200000030000
Just tried it and realised... my vcds is saying coding accepted, but the bcm isn't storing the settings 🤦‍♂️ any idea why that could be? Possibly battery voltage?
Update
Was battery voltage, got it to accept long coding, e20 interior lighting now works. Side lights still on permanently though
Changed patch of auto lights from T17/16 To T17/5. Side lights now work as expected
Isn't t17/12 the auto light setting?
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Sat Dec 19, 2020 11:15 am
Update
Yes T17/12 is auto lights and is fed to t73a/37 bcm
Video of coming home working:
https://youtu.be/zsvcqlpo_Ds
holy f*****g s**t hahaha! i knew the car was in a bit of a sorrow state but it's a SKELETON :mrgreen: :mrgreen:
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Sat Dec 19, 2020 11:34 am holy f*****g s**t hahaha! i knew the car was in a bit of a sorrow state but it's a SKELETON :mrgreen: :mrgreen:
I wasn't lying haha!
No glass, no panels, boot is half closed up from all wheel drive conversion. Just you wait! It'll be back on the road by March :D
Atleast the engine bay looks good!
Ill sort the headlight flasher on Monday when I get back to the car. Will be working on the heated seat loom today and tomorrow, came yesterday from kufatec but will need adapting for the 6J hazard switch
MIH11MI6
Post by MIH11MI6 »
Another quick update
LED number plate bulbs are here. Will make the loom for them shortly as the previous owner of the car cut the number plate cables 🤦‍♂️
MIH11MI6
Post by MIH11MI6 »
Hi all again, long time no speak.
I am nearing the final stages of my AWD 6J build, painting in a couple of weeks.
In the meantime I had the cabin stripped down and used it as an opportunity to tidy up the auto lights retrofit completed at the end of last year.
I ran a full test on all functions of once the loom got put back in and noticed that the auto lights are not working (dipped and full beam not turning on when in auto mode)
- I have the coming home lights/ leaving home lights set to dipped beam and they come on.
- I put the light sensor in a sealed box plugged in, ensuring it was dark enough and it did trigger.
- I also did an output test on the dipped beam from the BCM and they switched on individually perfectly fine.
I have attached an image of the long coding, best I could do without VCDS to hand at my new workshop, I plan on getting it soon.
@iichel or @ciclo looking at the long coding, can you see anything obvious as to why the auto lights aren't working even though all output tests work?
I thought it could potentially be because the engine wasn't running? but I didn't think that was the behaviour of the auto lights.
Headlight level switch also isn't working, but that's probably just me made a mistake so will be running through that tomorrow.
I know there is a rain and light recognition sensor fault, but it works for coming home/leaving home lights and they only switch on when the RLS is in a closed box (best way to simulate darkness)
Thanks!
It is obvious, in the BCM coding of the image (please, don't post a coding on an image 🤬😂, it doesn't help to help you) you have Byte18 coded to 42HEX, it should be as iichel told you (61? ).
Maybe it is necessary to code a few more Bytes, it depends on everything new that you have installed. I would not worry too much, finish installing what corresponds to this magnificent project, then we will code accordingly.😉
MIH11MI6
Post by MIH11MI6 »
ciclo wrote: Mon Mar 15, 2021 7:35 pm It is obvious, in the BCM coding of the image (please, don't post a coding on an image 🤬😂, it doesn't help to help you) you have Byte18 coded to 42HEX, it should be as iichel told you (61? ).
Apologies for the poor coding mechanism, was limited in my resources! Thanks for the help though, I agree, probably best. Cars getting painted next weekend, after that it'll be all hands on deck to code and output test everything before the dashboard goes back in
MIH11MI6
Post by MIH11MI6 »
Hi guys,
Running into some trouble getting the 6J project started.
Running output tests it looks as though the fuel injectors and HPFP are not getting a signal to engage. Diagnosed with my mechanic that is may be due to an issue in the instrument cluster (code U11100) function limitation due to mixed messages.
I used what code reader I had to look a bit further into it. And the code in the IC is: 12653568. From Googling this appears to be a communication issue to the haldex controller for all wheel drive.
ECU info obtained with Carista 5.4.3 for Android:
VIN: VSSZZZ6JZAR131492
Engine
Part #: 03L906018CR
Component: R4 2.0l TDI
Software version: 9979
ASAM/ODX identifier: EV_ECM20TDI01103L906018CR
Coding: 00190012042500080000 (hex)
Fault codes:
04911 Manufacturer-specific code
04912 Manufacturer-specific code
05132 Manufacturer-specific code
04881 Manufacturer-specific code
04900 Manufacturer-specific code
05257 Manufacturer-specific code
05258 Manufacturer-specific code
ABS
[ECU not present]
Instrument cluster
Part #: 6JA920940A
Component: KOMBI
Software version: 0607
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 110800 (hex)
Fault codes:
1416448 Manufacturer-specific code
12653568 Manufacturer-specific code
Airbags
Part #: 6R0959655H
Component: VW10AirbagA03
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW250
Coding: 003033 (hex)
Fault codes:
9437210 Manufacturer-specific code
9440027 Driver's side; side-airbag igniter (resistance too high)
9439771 Manufacturer-specific code
9438747 Igniter for seat belt tensioner; Driver's side
9442836 Front Passenger's Airbag Disabled Indicator Lamp
Power steering
[ECU not present]
Steering angle
[ECU not present]
Heater & air conditioning
Part #: 6J0820043E
Component: Climatronic
Software version: 0808
ASAM/ODX identifier: [none]
Coding: [none]
Fault codes:
00705 Coolant Fan Switched on (Relay 1, 1e Stage) (J279)
00706 Relay for Coolant Fan, 2e Stage (J513)
Radio
[ECU not present]
Central electronics
Part #: 7E0937090C
Component: BCM PQ25 Max4
Software version: 0752
Coding: 3C8829FFC8F32500932806007ECB1EC90080420F60880041200000030000 (hex)
Fault codes:
00446 Function Limitation due to Under-Voltage
03156 Sensor for Warning System Theft
01044 Control Module Incorrectly Coded
02745 Left daytime running light (DRL) lamp
02746 Right daytime running light (DRL) lamp
04194 Manufacturer-specific code
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 002107 (hex)
Fault codes:
01324 Control Module for All Wheel Drive (J492)
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
All-wheel-drive system
Part #: 1K0907554F
Component: Haldex 4Motion
Software version: [none]
Coding: 1 (decimal)
Fault codes:
01314 Engine Control Module (ECM)
01316 ABS Control Module
00778 Steering Angle Sensor (G85)
01317 Control Module in Instrument Cluster (J285)
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 530B1A73 (hex)
Fault codes:
00458 Controller for battery monitoring (J367)
02252 Generator
I'm surprised that this would stop the car from starting, but as it's canbus and it's feeding back information to the instrument cluster it isn't impossible.
Can anyone help with this? I'm worried if it's not this it's an issue with my wiring or the BCM/coding. I am going to get on VCDS to disable the AWD in the can gateway as I will be running a standalone system for it anyway.
Any help would be really appreciated. Really worried I've done something to brick the car now
MIH11MI6
Post by MIH11MI6 »
Hi all,
back again, car is back together and i also got it running! retrofitted pano roof is also working thanks to iichel!
Below is autoscan, only trivial issue left is that I can't seem to get the auto lights working. I changed byte 18 to hex 61 as suggested, but no change. output tests all work as expected, dipped, full, side lights, and leaving home lights work. just auto lights aren't. Also the rain sensor function isn't working either for some reason.
any help would be great! getting close now
Friday,09,April,2021,12:01:24:32543
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: VSSZZZ6JZAR131492   License Plate:
Chassis Type: 6J-SE25 (7E0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: VSSZZZ6JZAR131492   Mileage: 162560km-101010miles
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CFHD)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CR    HW: 03L 906 018 A
   Component: R4 2.0l TDI   H20 9979
   Revision: 43H20---    Serial number:
   Shop #: WSC 12345 210 12345
   ASAM Dataset: EV_ECM20TDI01103L906018CR 003008
   ROD: EV_ECM20TDI01103L906018A_003.rod
   VCID: 7CA1FED9566C961BD3B-8028
4 Faults Found:
4911 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [101] - Malfunction
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 162561 km
                    Date: 2021.04.09
                    Time: 11:49:39
                    Engine RPM: 923.50 /min
                    Normed load value: 70.6 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 7 °C
                    Intake air temperature: 9 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 13.800 V
                    Exhaust gas temperature sensor 1: 20.0 °C
                    Exhaust gas temperature sensor 2: -0.0 °C
                    Exhaust gas temperature sensor 3: 1000.0 °C
                    Exhaust gas temperature sensor 4: 2.0 °C
4881 - EGR Valve (N18)
          P1440 00 [039] - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 162561 km
                    Date: 2021.04.09
                    Time: 10:01:13
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 13.440 V
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 100.00 %
                    EGR valve: offset closed: 2.25 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 119
                    Actuator for high pressure EGR: status-Bits 0-7: 3
                    High press EGR actuator: actual unconditioned volt val: 0.8 mV
4900 - EGR Sensor 1
          P0405 00 [039] - Signal too Low
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 162561 km
                    Date: 2021.04.09
                    Time: 10:01:12
                    Voltage terminal 30: 13.420 V
                    Actuator for high pressure EGR: status-Bits 0-7: 55
5257 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [100] - Malfunction
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 162561 km
                    Date: 2021.04.09
                    Time: 11:49:34
                    Engine RPM: 197.00 /min
                    Normed load value: 100.0 %
                    Voltage terminal 30: 10.280 V
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 130248DB837000B3C82912EBC1D300821700
   Shop #: WSC 04941 123 12345
   VCID: 4DC7631DBD96EF93345-8018
1 Fault Found:
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 128
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2015.08.29
                    Time: 19:54:57
                    Hex Value: 0x0007
                    Hex Value: 0x0001
                    Hex Value: 0x1024
                    Hex Value: 0x036C
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Hex Value: 0x0000
   Part No SW: 6J0 820 043 E    HW: 6J0 820 043 E
   Component: Climatronic   H03 0808
   Revision: S0000000
   VCID: 2615FCB1F8E0FCCBD5F-8072
2 Faults Found:
00705 - Relay for Coolant Fan; Stage 1 (J279)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2015.08.31
                    Time: 11:26:41
00706 - Relay for Coolant Fan; Stage 2 (J513)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2015.08.31
                    Time: 11:26:41
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 300172843
   Coding: 3C8829FFC8F325009B2806003CAB1EC90080610E60080001200000030000
   Shop #: WSC 02739 534 139556
   VCID: 2B030D85E302C1A30A1-807E
   Subsystem 1 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 140411 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3130
   Coding: 030000
   Subsystem 3 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3130
   Coding: 020000
   Subsystem 5 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
   Subsystem 6 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 005300005068
   Coding: 000003
   Subsystem 7 - Part No: 1K8 951 171 A
   Subsystem 8 - Part No SW: 6JA 919 719 C    HW: 6JA 919 719 C
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B1376220316
   Coding: 001000
   Part No SW: 6R0 959 655 H    HW: 6R0 959 655 H
   Component: VW10AirbagA03 H08 0018
   Revision: --------    Serial number: 003EQ0000M7T
   Coding: 003033
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 47CB51355F2A05C30E9-8012
   Serial number: 3496GRB402JD1BPUPREW
   Serial number: 3506GRB402JD1BPV4J9Y
   Part No SW: 6JA 920 940 A    HW: 6JA 920 940 A
   Component: KOMBI         H16 0607
   Coding: 110800
   Shop #: WSC 73430 031 00125
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3A2D38C11CD8682B817-806E
1 Fault Found:
1416448 - Oil Level Thermal Sensor
          B1041 29 [009] - Signal Implausible
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 88
                    Mileage: 162561 km
                    Date: 2021.04.09
                    Time: 10:01:09
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 002107
   VCID: 6889B28932742ABB273-803C
1 Fault Found:
            000 - - - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2015.08.31
                    Time: 10:01:09
   Component: IMMO          H16 0607
   Shop #: WSC 00000 000 00000
   VCID: 6A8DC8812CF818AB317-803E
Address 44: Steering Assist        Labels: None
   VCID: 55F78B7D9C46A7538C5-8000
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 01:34, VBatt start/end: 13.9V/13.2V)-----------
Byte 16 -> F0
Byte 22 -> 20
MIH11MI6
Post by MIH11MI6 »
iichel wrote: Fri Apr 09, 2021 12:37 pm Byte 16 -> F0
Byte 22 -> 20
Worked again, absolute legend! Come live with me in the UK and fix all my problems haha!
Never will I ever haha. No offense
