Aftermarket Radio Doesn't Power Off
Scarey
Drives: VW Polo 1.4 SE 2010
Post by Scarey »
Apologies if this has been asked before.
I have purchased an aftermarket radio for my VW Polo 2010 and it doesn't switch off with the ignition.
I kind of know why this is now, but was wondering what is the easiest way to connect to a switched power source.
Someone advised running the cable to the fuse box and using and ATMDT connector. Is this the easiest way or could I connect to another feed in the centre console area?
Re: Aftermarket Radio Doesn't Power Off
I'd take the fuse box.
Scarey
Post by Scarey »
Thanks iichel, that being the case does anyone know the best fuse to piggy back off of?
Any fuse that has 12v with key to on position.
