Digital Speedometer not working
Tjs_1445
Drives: 2013 Match edition
Post by Tjs_1445 »
Hi all,
I believe my polo has a digital speedo. However, it just shows 3 dashes where the digits should be. Image
I'm not sure if it has been de activated?
If it has, how would I re-activate it?
Many thanks
Re: Digital Speedometer not working
Looks like you're at the speed limiter screen. Not the digital speedo.
Tjs_1445
Post by Tjs_1445 »
Ah ok, perhaps it dosent have a digital speedo after all
Thanks for the help :)
Damon
Drives: 2010 Polo Moda 64
Post by Damon »
Tjs_1445 wrote: Tue May 04, 2021 8:31 pm Ah ok, perhaps it dosent have a digital speedo after all
Do you have buttons on your steering wheel or wiper stalk?
Theres a way to bring up the Digtial Speedo but you need buttons.
Tjs_1445
Post by Tjs_1445 »
I've got a rocker switch and a reset switch on my wiper stalk, but nothing on the steering wheel
Damon
Post by Damon »
Tjs_1445 wrote: Tue May 18, 2021 4:20 pm I've got a rocker switch and a reset switch on my wiper stalk, but nothing on the steering wheel
I read this on another group and people got it up.
You will need Carista or VCDS though.
Cluster region needs to be Australia.
Once thats done press Left button on the cluster three times
Mileage will flash
Press right Set/0.0 button then left button again
Then use the wiper stalk buttons to cycle through the display and it should show.
Maybe yours was alright done at one point so you could try using the buttons like instructions and see if it appears.
Tjs_1445
Post by Tjs_1445 »
Great, thanks!
I've ordered Carista so I'll give that a go tomorrow and will let you know :D
Damon
Post by Damon »
Tjs_1445 wrote: Tue May 18, 2021 8:50 pm Great, thanks!
No worries mate
Here’s a video showing what you need to do also
https://youtu.be/Lj5uLQVEZB8
Same exact process as Polo.
Wish I had buttons so I’m jealous I can’t do it but seen others successful doing it following instructions.
I’d be happy just to see my average mpg at least 💀💀
Only can see range or temperature sometimes sadly, but you should get the Speedo sorted. :)
Tjs_1445
Post by Tjs_1445 »
It worked, thanks again mate! :)
Damon
Post by Damon »
Tjs_1445 wrote: Thu May 20, 2021 9:30 am It worked, thanks again mate! :)
Glad you got it sorted.
Jealous though 😅
At least it’ll help someone else if they search for
same issue
