Golf 7.5 Anti-theft alarm system + New RLHS. Coding.
BCM adaptation SECURITY ACCESS--> 31347
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,not active ,8 ... Active
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8 ... Active
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8 ... driver door contact thatcham
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,not installed ,8 ... sounder installed
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,not_active ,8 ... active
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,not_active ,8 ... active
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8 ...yes
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8 ...yes
Setting parameters for Golf mk7.5 (not Variant), """NO Parking heater, NO trailer hitch, NO Kessy"""
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66
Lock & unlock horn confirmation:
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10 ... not active (with alarm)
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10 ... normal or short (with alarm only)
Previously coded.
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active ,10 ... active (open)
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10 ... active (close)
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10 ... active
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10 ... active (Menu infotainment system)
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 72007150025702
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW37.rod
VCID: 015F7878518EE16380D-8054
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: S5
Y20M05D14H05M53S24
Coding: 06A8DD
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY191251XZQ
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0313
Serial number: 00002854456462182207
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
A new option appears in the menu for the door opening and closing settings, allowing you to deactivate the monitoring of the interior sensors in the event that someone or something is inside the vehicle.
In the event that the interior sensors need to be deactivated, they must be deactivated before removing the key from the ignition switch.
It works like the old button located on the B-pillar, it is activated automatically for the next time.
Added the following adaptation to the previous adaptations, it allows the deactivation of the interior monitoring by 'double click' on the closing button of the remote control.
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
...active
It works perfectly.
