Restoring lost abs long code with new vcds hex v2 pro
Acha86392
- Drives: VW Polo 1.2 TDi Manual
Re: Restoring lost abs long code with new vcds hex v2 pro
Currently doesn't want to do the full scan
But ill try it again and check that I can send it to you
Acha86392
Yes that's perfectly fine, thank you
Hi @iicheliichel wrote: Fri Nov 03, 2017 8:07 am No, that wouldn't work. In fact, we did that already. The polo from the UK is a hatchback, and you have a sedan. Those two are different.
If you're lucky, it could work with a Polo sedan with any ESP8.2i (so not 9.0i or ABS8.2) from India AND change byte 15 to '82'.
Can you please assist me with abs module coding as well. I have tried to use the same code of 2 other cars that are the same as mine. With the same ABS partnumbers as mine.
Please assist if you can.
Asking due to another tread that I saw.
Regards
Dewald
What's the situation?
I have 2 cars that I need help with.
WVWZZZ1KZBW273000
CDL engine
2011 Golf MK6 R
2.0 TFSI
DSG RHD
South Africa
My ABS module lost coding. The long code is "000000000" I do not have a pervious auto or full scan.
ABS module part number: 1K0 907 379 BE
Component: MK60ECT H31 0108
This module is still in the car, and we haven't replaced it.
Reason why it lost coding, is that the cluster was swopped with another golf mk 6R's cluster. The original cluster is back in the car now. Nothing has changed the coding is just lost.
Will post a full scan ASAP.
Thank you for the reply !
WVWZZZ1KZBW273000
CDL engine
2011 Golf MK6 R
2.0 TFSI
DSG RHD
South Africa
I'm guessing it's mk60/mk60EC1 since it's golf mk6. if you have a genuine vcds interface, you're eligible for support on the ross tech website as well, there are a lot of folks there that are very handy with these Mk60EC1 modules as well.
We have a genuine VCDS but its at the workshop thats currently 450kms away from me.
I only have a non original VCDS with me at the moment.
Monday,10,October,2022,10:06:12:00007
VIN: WVWZZZ1KZBW273000 License Plate:
Mileage: 57340km-35629mi Repair Order: APEX R
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW273000 Mileage: 57340km-35629miles
16-Steering wheel -- Status: OK 0000
22-AWD -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: Malfunction 1110
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 1K8 907 115 E HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH21--- Serial number:
Coding: 040300101C0F0160
Shop #: WSC 01286 386 08256
VCID: 306FA6C1A32354CA65-8064
7 Faults Found:
000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P0219 - 001 - -) - Intermittent
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57307 km
Time Indication: 0
Date: 2020.03.29
Time: 18:09:20
RPM: 7490 /min
Load: 53.7 %
Speed: 93.0 km/h
Temperature: 84.0°C
Temperature: 25.0°C
Absolute Pres.: 870.0 mbar
Voltage: 13.335 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:51
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
005748 - Powertrain Data Bus
P1674 - 004 - Implausible Message from Instrument Cluster - Intermittent
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
053273 - Control Module for Instrument Cluster
U1019 - 008 - Missing Signal for Oil Level/Temperature - Intermittent
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Readiness: 0010 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 013 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2610
Revision: 05351112 Serial number: 00001102211505
Coding: 0000024
Shop #: WSC 01357 011 00200
VCID: 1C376271DFABC0AA29-8048
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 00000000000000000000000000000000000000
Shop #: WSC 27942 001 1048576
VCID: 76E350D9C1C73AFAFF-8022
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 19:03:24
Count: 16391
Count: 12
Count: 16384
Count: 195
Count: 45824
Count: 0
Count: 65280
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 279
Count: 49408
Count: 0
Count: 65024
Count: 0
00778 - Steering Angle Sensor (G85)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 295
Count: 49408
Count: 0
Count: 65024
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 270
Count: 49408
Count: 0
Count: 65024
Count: 0
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000001002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 6ED378B9B197023A37-803A
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 4E180A3A8825F1C040080080340008E441550088736D8D60E48000240040
VCID: 387F9EE18B538C8A2D-806C
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 28021 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160311 05 54 0403
Coding: 0330AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
1 Fault Found:
00907 - Intervention load Management
000 - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 57348 km
Time Indication: 0
Date: 2017.03.02
Time: 15:48:51
Term 15 On
Voltage: 11.45 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 12501106000609
Coding: 108104
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RA2CK3C
Coding: 00003950
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3169A3C560295DC26A-8064
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME616D025EZZZ/
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4801525CZZZV
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME5049000CZZZL
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME700A055FZZZY
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KCC000N8
Coding: 1892140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76E350D9C9C73AFAFF-8022
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Serial number: 0015736
Coding: 830000
Part No SW: 5K6 920 871 B HW: 5K6 920 871 B
Component: KOMBI H20 0420
Coding: 170F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
VCID: 3365A9CD9A356FD218-8066
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 180311F2001242
Coding: 350003
Shop #: WSC 00000 576 59471
VCID: 306FA6C1632354CA65-8064
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 62
Mileage: 57332 km
Time Indication: 0
Date: 2017.02.28
Time: 02:11:34
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 4487FA11079BD86AB1-8010
Component: IMMO H20 0420
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE1A6B-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2152
Coding: 0000692
VCID: 3365A9CD52356FD218-8066
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 5N0 909 144 M
Component: EPS_ZFLS Kl. 251 3201
Revision: 00H20000
VCID: 3B7581ED7A65A792C0-806E
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57332 km
Time Indication: 0
Date: 2017.02.28
Time: 02:11:29
Battery Volts: 13.4 V
DU
Temperature: 47.0°C
Count: 8
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2120
Coding: 0000948
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 1475932
VCID: 3467AAD1573B68EA01-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 356197D55C4171E236-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 366390D941477AFA3F-8062
End-------------------------(Elapsed Time: 02:41)--------------------------
7 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57307 km
Time Indication: 0
Date: 2020.03.29
Time: 18:09:20
RPM: 7490 /min
Load: 53.7 %
Speed: 93.0 km/h
Temperature: 84.0°C
Temperature: 25.0°C
Voltage: 13.335 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:51
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57319 km
Time Indication: 0
Date: 2020.04.19
Time: 06:29:52
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 36.0°C
Temperature: 33.0°C
Voltage: 11.430 V
Coding: 0000024
Revision: 00H31001
4 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 19:03:24
Count: 16391
Count: 12
Count: 16384
Count: 195
Count: 45824
Count: 0
Count: 65280
Count: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 279
Count: 49408
Count: 0
Count: 65024
Count: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 295
Count: 49408
Count: 0
Count: 65024
Count: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 57332 km
Time Indication: 0
Date: 2017.03.01
Time: 18:52:51
Count: 3
Count: 14
Count: 29184
Count: 270
Count: 49408
Count: 0
Count: 65024
Count: 0
Revision: 00003001
Coding: 0000001002
Revision: 00103 AD
Coding: 009795
Coding: 0330AD
1 Fault Found:
000 - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 57348 km
Time Indication: 0
Date: 2017.03.02
Time: 15:48:51
Term 15 On
Voltage: 11.45 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 108104
Coding: 00003950
Coding: 1892140000
Coding: 830000
Coding: 170F01
Coding: 350003
1 Fault Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 9
Reset counter: 62
Mileage: 57332 km
Time Indication: 0
Date: 2017.02.28
Time: 02:11:34
Coding: 0000005
Coding: 0000692
Revision: 00H20000
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 57332 km
Time Indication: 0
Date: 2017.02.28
Time: 02:11:29
DU
Temperature: 47.0°C
Count: 8
Count: 0
SteerAng n.Init
Coding: 0000948
Coding: 1475932
Coding: 00000022
Coding: 00000022
Address 56: Radio
Cannot be reached
Coding: 0000144
Coding: 0000144
yes it is the MK60EC1 Module.iichel wrote: Mon Oct 10, 2022 8:18 am I'm guessing it's mk60/mk60EC1 since it's golf mk6. if you have a genuine vcds interface, you're eligible for support on the ross tech website as well, there are a lot of folks there that are very handy with these Mk60EC1 modules as well.
Also the full scan doesn't want to upload.
Regards
Try this: 164B800C092900FD680B01E490190081050C00
thank you for the quick reply
it rejected it and said request out of range
next try: 163B800D092900FD680B01E4901900813D0000
Hi I’m wondering if you can assist me. I have a vw polo 2011 that has lost its coding for the ABS. I tried to send the whole scan report but my laptop isn’t allowing me to so I hope these screenshots will do. It has front brake disc size 256mm and rear drums of 200mm. It’s an an ESP 8.2 module. Wondering if you could be any help to me please.
Thank you in advance
- 2AC7F554-96F6-43A4-98B6-6D1B13DB7DB3.jpeg (5.04 MiB) Viewed 3123 times
- 87920E49-89DA-4FC0-B105-EB57368B595C.jpeg (6.29 MiB) Viewed 3123 times
If you have genuine cable, go to Ross tech forum please and post full scan there. I'm a bit fed up with making all these codes for anyone and everyone for free and most people can't be asked to even post results. Like the guy above.
