6C Full LED Headlights number
RelaxedRedPanda
- Drives: VW Polo 6C 1.2TSI
Re: 6C Full LED Headlights number
I would do as @iichel suggested.
Try 6C0941607 instead, seem like a typo in ETKA when the part actually first was made for the 6C production.
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
https://www.oemvwshop.com/6c0941607-cover-cap-p969292/
It is written in the product specification: "Dimension 1,8 x 8,3 x 8,3" , i think that this is the right one!
I have already sent an email to the store support and am waiting for a response.
ZahariGeorgiev
Hello guys,
I have a very big problem finishing my upgrade with the headlights....
After i retrofit the AFS system, make the adapters for LED Headlighs, parameterized the BCM with original VCP, and here comes the problems:
- I don't have front parking lights at all ( maybe the problem is in the module for day driving lights )
- dipped beam are flashing from time to time
- on IC got the Adaptive front lighting system (AFS) failure" error message and flashing yellow lamp
When i make a scan for DTC'S with VCP i get this:
When i try to do the basic settings for the headlights i get this:
And for the coding of the module, i really need help here:
- 20211103_210004.jpg (4.33 MiB) Viewed 3562 times
- 20211102_184812.jpg (3.83 MiB) Viewed 3562 times
I don't know a lot from VCP, sorry. And half of the images are not working.
The non-functional parking lights and flashing low beam lights are probably BCM problems, not related to the AFS module.
ZahariGeorgiev
Still no results, when i try to code the module with 0112000001000000 it refused..
And here is the auto scan
VCP+K v8.8.0 16.08.2021 "Keep Hope Alive" Autoscan protocol 2021-11-04 00:39:19.959
Adressword : 01 (Engine Control Module 1} - J623 R4 1.6l TDI
VAG no. : SW: 03L906023AH HW: 03L906023D
SW version : 9979
# Coding : 00254016002400080000
ASAM: UDS, EV_ECM16TDI02103L906023AH 003014
DATASET:
>>> No faults found
Adressword : 02 (Transmission Control Module} -
VAG no. : SW: HW:
SW version :
# Coding :
ASAM: Communication error.
DATASET:
>>> Errors found
Adressword : 03 (Brakes 1} - J104 ESP8.2i front
VAG no. : SW: 6R0907379AJ HW:
SW version : 0001
# Coding : 210228E3416D00B6842D14EA82DA00421300
ASAM: TP1.6, CANT=7A3 CANE=7A0
DATASET:
>>> No faults found
Adressword : 04 (Steering Angle Sender} -
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>>> Errors found
Adressword : 08 (Air Conditioning} - J255 Climatronic
VAG no. : SW: 6R0907044H HW: 6R0907044H
SW version : 0812
# Coding : 00000
ASAM: TP2.0, CANT=300 CANE=33C
DATASET:
>>> No faults found
Adressword : 09 (Central Electrics} - J519 BCM PQ25 Max4
VAG no. : SW: 7E0937090 HW: 7E0937090
SW version : 0736
# Coding : 3EB82BBF48A10000013806F13EEB9FD9FF80660F60052249200000020000
ASAM: TP2.0, CANT=300 CANE=338
DATASET:
SLAVE[1] Part number: 5K7955559B
RLS 290415 03 SW: 0059 HW:
Coding : 0228DD
SLAVE[2] Part number: 6R0959801R
J386__TSG_FT SW: 0903 HW: 6R0959801R
Coding : 18BC30
SLAVE[3] Part number: 6R0959802T
J387__TSG_BT SW: 0902 HW: 6R0959802T
Coding : 08BC30
SLAVE[4] Part number: 1K8959442
E221__MFL-MD9 SW: 0103 HW: 1K8959442
Coding : A40000
SLAVE[5] Part number: 6R0959811F
J388__TSG_HL SW: 0902 HW: 6R0959811F
Coding : 08BC32
SLAVE[6] Part number: 6R0959812F
J389__TSG_HR SW: 0902 HW: 6R0959812F
Coding : 08BC32
>>> Errors found
03D2 Left low beam headlamp bulb
03D3 Right low beam headlamp bulb
Adressword : 10 (Parking Assistance 2} - J446 PARKHILFE 8K
VAG no. : SW: 7E0919475J HW: 7N0919475
SW version : 0105
# Coding : 308101
ASAM: UDS, EV_VW75XParkAssis8K 001003
DATASET:
>>> No faults found
Adressword : 15 (Airbag} - J234 VW10Airbag008
VAG no. : SW: 6R0959655C HW: 6R0959655C
SW version : 0018
# Coding : 003038
ASAM: UDS, EV_AirbaVW10BPAVW250 A01001
DATASET: v00301656R0
SLAVE[1] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[2] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[3] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[4] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[5] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[6] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[7] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[8] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[9] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[10] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[11] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[12] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[13] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> No faults found
Adressword : 17 (Dash Board} - J285 KOMBI
VAG no. : SW: 6JA920840A HW: 6JA920840A
SW version : 0607
# Coding : 140E01
ASAM: UDS, EV_Kombi_UDS_VDD_RM09 A04716
DATASET: -----------
>>> No faults found
Adressword : 19 (Gateway} - J533 GW-K-CAN TP20
VAG no. : SW: 7E0909901 HW: 7E0937090
SW version : 0736
# Coding : 002200
ASAM: TP2.0, CANT=300 CANE=32E
DATASET:
>>> No faults found
Adressword : 25 (Immobilizer} - J334 IMMO
VAG no. : SW: 5K0953234 HW: 5K0953234
SW version : 0607
# Coding : 000000
ASAM: UDS, EV_Immo_UDS_VDD_RM09 A03709
>>> No faults found
Adressword : 44 (Steering Assistance} - Error reading ID.
VAG no. : SW: - HW:
SW version : -
# Coding : -
ASAM: TP1.6, CANT=7A9 CANE=7A0
DATASET:
>>> No faults found
Adressword : 55 (Headlight Regulation} - J431 AFS-ECU
VAG no. : SW: 6R0907357C HW: 6R0907357B
SW version : 0050
# Coding : 0000000000000000
ASAM: UDS, EV_HeadlRegulVWLWRCC 002006
DATASET: V03600097E0
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> Errors found
507E54 (C107E54) Headlamps no basic setting (Scheinwerfer keine Grundeinstellung)
D01300 (U101300) Control module not coded (Steuergeraet nicht kodiert)
Adressword : 56 (Radio} -
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>>> Errors found
Try this coding: 0D4A000001000000
ZahariGeorgiev
I always get this message: Recode error - 24 Request sequence error. I am not really sure where is the problem - the coding, the headlight range module (which is brand new), the rear axle sensor (which is used and it is from polo), or i dont know what happening, but cannot finish my project for HBA until i solve this mystery with the LED headlights
- 20211104_180629.jpg (2.93 MiB) Viewed 3477 times
ZahariGeorgiev
Hello ciclo,
I already did this, and get rid of that error, but still can't code the module, and do the basic settings and got flashing low beam, and no front parking lights at all
VCP+K v8.8.0 16.08.2021 "Keep Hope Alive" Autoscan protocol 2021-11-04 22:08:22.252
SW version : 0736
# Coding : 3EB82BBF48A10000013806F13CEB9FD9FF80660F60052249200000020000
DATASET:
Coding : 0228DD
Coding : 18BC30
Coding : 08BC30
Coding : A40000
Coding : 08BC32
Coding : 08BC32
>>> Errors found
SW version : 0050
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> Errors found
Is your BCM suitable for LED headlights?
ZahariGeorgiev
Nice question, i really don't know the true answer
My BCM is 7E0937090 and i think it is suitable with the LED and just have to be parameterized with VCP ..
Why don't you start with parameterization of the LED headlights? Then you know why your exterior lights behave oddly.
Apart from what iichel comments, I have corrected some Bytes in your BCM coding.
Enter this New coding in your BCM (yes or yes), it is the starting point:
3EB82BBF48A10000013806F13CEB9FD9FF80600F60053041200000020000
Depending on the type of installation you have done for automatic lights and/or HBA, some Bytes may be different (there are two possible ways of installation).
We will solve it as we see progress.
Please inform us in detail of the result of the New BCM coding.
ZahariGeorgiev
I will say this: ciclo you are a GOD man:)
Thank you so much for the support!
I just coming form the garage and enter this code: 3EB82BBF48A10000013806F13CEB9FD9FF80600F60053041200000020000
And YES, finally working front parking lights. They not work exactly well - when i put lighting switch to off position - parking lights are on at full power, when turn on auto position - they are not so bright, same is for parking light position and low beam (I am not really sure is this the right behavior), and they don't turn off when got blinkers on. Also low beams doesn't activate when i put the switch to low beam... only when the switch position is to off position first time i unlock the car. Still got the error for Non coded module and no basic settings in headlights, and of course cannot perform them - Coding rejected.Error31: Request out of range. Still flashing lamp and AFS error on dashboard.
About the auto lights - you did the wiring for me
For the HBA still waiting to figure out what and where new cables i need to connect and i am still stuck at the led headlights and leveling system ....
About that leveling system, i still dint change my original dimer switch with manually adjustable headlights. Got the new one 6Q0941334 and the question is do i have to connect new cables (if yes, maybe that's my problem) just to plug new one ?
- 20211105_154425.jpg (4.9 MiB) Viewed 3317 times
You don't need to change any wiring for the new dimmer.
