Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Benzinkopf's 2012 VW POLO 6R MK5 1.2TSI 105HP DSG
Post by benzinkopf »
noted and thanks ciclo.
just that the problem is my hexcan from 2012 wont be able to do adaptations anymore on these new unit n new car.
Buy a HEX-V2 for DIYers, maybe it's time for you to reward ross-tech for their great work, dedication and effort to all.
Please Amir, I beg you to understand what I have written in the best possible way just as we all understand the situations of others.
"The best for the best" :wink:
Thank you very much!
benzinkopf
sure. i totally understand their strategy. infact i think its worth it from day 1. Recently i just bought vcp. So the new vcds probably fall under next budget[emoji23]
benzinkopf
Ok since i cannot get polo image, anyone knows the code for Golf with sunroof/panoramic roof image?
It sounds silly but technically i would like to get more black area on the screen instead of white car. i just want to lower the white brightness at night. lol.
benzinkopf
achievement unlocked? [emoji1377][emoji1787]
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Cool....
A lot of hard work have gone in this....
Congratulations! Or maybe the opposite ...
(from now on you will be monitored on your travels wherever you go, and you will no longer be able to have secrets of your discoveries... :lol: , ...also invaded by a huge nonsense advertising :P )
:mrgreen:
benzinkopf
Thanks ciclo. its my achievement on the mileage[emoji23] not the carplay[emoji1787]. but yes. you re right with the invasion. in fact, even before having that, “they” has been doing it with all the social media platform... especially whatsapp
I thought the 300000 km was Photoshop... :mrgreen:
gsrsilver
Drives: A3 8v
Post by gsrsilver »
Hello, plese can you tell me part number of the boot light frame?
From which car is it?
The light frame
The light frame
megamind
Drives: Vento 1.6MPI
Post by megamind »
benzinkopf wrote: Sat Aug 24, 2019 2:33 pm Image
Finally, put an extra effort today to finish the long pending mod on all four door including the hatch: The door exit/warning light.
Hi benzinkopf, can you help me out with this mod in my VW polo sedan/Vento 2019?
I'm from India BTW & came to know about your mod from "TheLizardKing".
giannis20vt
Post by giannis20vt »
benzinkopf wrote: Thu Mar 19, 2020 2:50 pm so hello everyone, here's the details. Since it's quite lots of photos, so i decided to make a video instead. I guess its better. btw, the wiring part: of course referring to Ciclo's thread, where the wiring for these puddle lights LED are directly from the Footwell Light harness, going through the door connector etc.
Hi "benzinkopf", great mod.
I want to do the same with my polo 6c. I have already order the mirror base with dynamic led signal, and the puddle lights from Golf6
Do you have the exactly schematic for the opening ? I don't want to dismount the hole mirror, for doing this.
The wiring is simple as you already said, but i have some questions.
Did you wiring the footwell light harness throw the door connector with a cable, without pins?
I am planing to put some light to each door panel, as footwell light. So i will do them together. If i am thinking right i need only one cable through the door 28pin connector, from BCM (to my case Polo 6c, T73c/69) for positive. Am i right ? Please advice.
benzinkopf
gsrsilver wrote: Fri May 07, 2021 7:29 pm Hello, plese can you tell me part number of the boot light frame?
Hi. I'm really sorry for the delay reply. Been out of the "internet world" due to some reasons. btw. It's custom made part. 3Dprint. so there's no part number and not from any car.
benzinkopf
megamind wrote: Sun Jun 13, 2021 12:00 pm
Hello there. Anything i can help? My door exit/warning light is a simple connection with battery power +30 and the ground from the door lock switch.
benzinkopf
giannis20vt wrote: Wed Jun 16, 2021 2:03 pm
Hi there. Thanks. Hurm. I dont really have any schematic for the opening as the puddle light "module" is custom made. Yes, i bought the lights from Golf6, but we cant fit any of those in Polo 6R/6C mirror base. It is just not enough space. So i've to made my own light body.
Yes, I uses both wires from BCM/Footwell light in 6R through the door connector with pins. U can do without pins, but it will not be nice if you have to separate the door later. but hey, thats very unlikely anyway. For 6R, the footwell lights involve two pins from BCM and i cant just take the ground from the door. so i need to run through 2 wires through the door. I think because the bcm will switch over the ground wire to create the dimm effects on and off.
