Help Getting Long Code For ABS
JackCisco
Drives: 2011 6R 1.2L 3cyl
Post by JackCisco »
Somehow the long code for the ABS has magically poofed and it's causing the ABS light to illuminate on the dash, thus an MOT failure.
I have a 2011 1.2L 3cyl petrol, RHD.
Checked it in VCDS and the long code is all 0s and completely gone somehow.
I would really appreciate some help getting this long code back, I've been trying some I made myself based on research but everything I put in comes up with this error:
Coding rejected
Error 22: Conditions not correct or request sequence error
I'm attempting to code with the engine running.
Here is a full VCDS scan:
Friday,02,July,2021,14:33:41:21320
VCDS Version: 21.3.0.0 (x64)  HEX-NET CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBU046162   License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU046162   Mileage: 156360km-97157miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8319
   Revision: --------    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019M 001005
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E1001D671440DFB61-807A
3 Faults Found:
6056 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 156367 km
                    Date: 2021.07.02
                    Time: 14:18:30
                    Engine RPM: 853.00 /min
                    Normed load value: 14.5 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 85 °C
                    Intake air temperature: 45 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 13.507 V
                    Time since engine start: 807 s
                    Engine torque: 18.96875 Nm
                    Accelerator pedal travel-Accelerator position: 0.00 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: 8.250 °
6070 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 156367 km
                    Date: 2021.07.02
                    Time: 14:18:30
                    Engine RPM: 846.00 /min
                    Normed load value: 13.7 %
                    Time since engine start: 808 s
                    Engine torque: 20.06250 Nm
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: 10.125 °
13909 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 156367 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine RPM: 856.00 /min
                    Vehicle speed: 6 km/h
                    Coolant temperature: 84 °C
                    Time since engine start: 777 s
                    Engine torque: 14.93750 Nm
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: 0.375 °
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 31414 790 31414
   VCID: 06409976B57465BBF9-8052
5 Faults Found:
03306 - Coding Not Valid
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 44
                    Reset counter: 26
                    Mileage: 156367 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 14:29:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3209
                    Hex Value: 0x14AE
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
01042 - Control Module; Not Coded
            000 - -
                    Fault Priority: 0
                    Fault Frequency: 19
                    Reset counter: 26
                    Mileage: 156367 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 14:29:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3211
                    Hex Value: 0x14AE
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
            005 - No or Incorrect Basic Setting / Adaptation
                    Fault Status: 01100101
                    Fault Priority: 0
                    Fault Frequency: 19
                    Reset counter: 26
                    Mileage: 156367 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 14:29:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x32E1
                    Hex Value: 0x20AE
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Priority: 0
                    Fault Frequency: 44
                    Reset counter: 26
                    Mileage: 156367 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 14:29:53
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x3209
                    Hex Value: 0x14AE
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 26
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 16:54:44
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x3251
                    Hex Value: 0x1BAB
                    Hex Value: 0x006B
                    Hex Value: 0x7F7F
                    Hex Value: 0x7C00
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 312A1AAA687A12037C-8064
1 Fault Found:
01336 - Company Data Bus for Comfort System
            014 - Defective - Intermittent
                    Fault Status: 00101110
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 12
                    Mileage: 156367 km
                    Time Indication: 0
                    Date: 2011.09.09
                    Time: 14:18:30
   Part No SW: 6R0 937 085 D    HW: 6R0 937 085
   Component: BCM PQ25 M+   H46 0230
   Revision: BB046001    Serial number: 0390 092110366
   Coding: 64B02BBF08A10048002008003D2B0C900040410F60060000200000000000
   VCID: 3C343B9EBF38EF6BDF-8068
   Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 0903
   Serial number: KU0-KU001.10.1012191
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 0902
   Serial number: KU0-KU012.10.1012407
   Coding: 08BC30
14 Faults Found:
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:51
03432 - Activation of Right Parking Light
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:51
03435 - Terminal 30 for Interior Light and Parking Light
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
00329 - Control Circuit for Unlocking Rear Lid
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:51
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
03302 - Response Closing Status of Passenger's Door
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
03303 - Response Closing Status of Rear Left Door
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
03304 - Response Closing Status of Rear Right Door
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
01179 - Incorrect Key Programming
            000 - -
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 237
                    Mileage: 92873 km
                    Time Indication: 0
                    Date: 2015.02.22
                    Time: 01:26:06
03396 - Supply voltage terminal 30 for central locking
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:45
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 66
                    Time Indication: 0
00446 - Function Limitation due to Under-Voltage
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 66
                    Mileage: 93145 km
                    Time Indication: 0
                    Date: 2015.03.21
                    Time: 00:00:01
01598 - Drive Battery Voltage
            000 - - - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 66
                    Mileage: 93145 km
                    Time Indication: 0
                    Date: 2015.03.23
                    Time: 00:01:10
03591 - Control Circuit for Horn
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 66
                    Mileage: 156369 km
                    Time Indication: 0
                    Date: 2015.11.23
                    Time: 15:05:46
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX00A8L9E
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AD86D46EDEC41DB5D-801E
   Serial number: 3575HRB405N09RECB1DM
   Serial number: 3585HRB4061096J64PB
   Serial number: 3515RRB406500IUGD99H
   Serial number: 3525RRB406500IUGL1LU
   Part No SW: 6R0 920 960 E    HW: 6R0 920 960 E
   Component: KOMBI         H04 0304
   Coding: 440200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   VCID: 373E24B28E1ECC3332-8062
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 12
                    Mileage: 156367 km
                    Date: 2021.07.02
                    Time: 14:18:30
   Part No SW: 6N0 909 901     HW: 6R0 937 085
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70ACDFAEA3F05B0B33-8024
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 61
                    Reset counter: 26
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2015.03.02
                    Time: 09:43:04
   Component: IMMO          H04 0304
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6A98CDC68D2CA1DB7D-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 31414
   VCID: 2F2E1CD2EA4E04F36A-807A
1 Fault Found:
            49-10 - No Communications - Intermittent
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 13.2V/13.2V)-----------
ABS: Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
ESP8.2i
The code I came up with was as follows:
200224E3017100B8042624E884D300800170
Any help is greatly appreciated. I can only get it retested today before I need it for the weekend, so if someone comes in and saves me before the garage shuts in 3 hours you're a legend.
(I would post on RossTech but I don't have a forum account and I understand it takes a bit of time to get authorised to post in certain sections so hoping someone can help me here)
Re: Help Getting Long Code For ABS
Why is the coding lost?
JackCisco
Post by JackCisco »
iichel wrote: Fri Jul 02, 2021 4:39 pm Why is the coding lost?
Honestly I have no idea. I haven't touched the ABS system.
I was replacing things, BCM, gauge cluster. Could that have caused it?
To be clear original parts are back in the vehicle.
I found your thread on here to figure out the coding using the spreadsheets, however the link for ESP8.2i is dead.
I've never had access to VCDS before this happened so I haven't got previously saved scans.
Have you ever done an autoscan before on your car?
JackCisco
Post by JackCisco »
amer6R wrote: Fri Jul 02, 2021 5:22 pm Have you ever done an autoscan before on your car?
Unfortunately no I haven't otherwise I could just get the old code from one :/
I've just tried making another code but it hasn't worked:
210224C2417100B8842609E841D300800100
I was referencing this:
https://www.mypolo.nl/xenforo/threads/6 ... ish.11914/
What does the error that I'm getting mean specifically?
JackCisco wrote: Fri Jul 02, 2021 5:26 pm
use this software https://skodapilot.com/espcalculator-bo ... i/?lang=en
JackCisco
Post by JackCisco »
amer6R wrote: Fri Jul 02, 2021 9:06 pm
Thanks for the help.
So I generated 210224C2217100B8842624E884D300820100 using the following settings:
Unfortunately still getting the same error 22.
I'm pretty certain the settings I've chosen are correct.
My vehicle doesn't have TPMS, I'm sure it doesn't have XDR, but does have HHC as when I take my foot of the brakes on a hill it holds the brakes for about a second. (I did try all settings and a mix of them in case I was wrong).
The engine type selected was the only RHD option.
I tried both drum brake options just in case too.
Is the instrument cluster a match to the engine control unit?
JackCisco
Post by JackCisco »
iichel wrote: Fri Jul 02, 2021 10:14 pm Is the instrument cluster a match to the engine control unit?
Yes the original instrument cluster has been in use while attempting this recode, and will remain in use.
230224E3217100B8C42624E884D300801700
or
230224E3217100B8C42624E884D300800700
JackCisco
Post by JackCisco »
iichel wrote: Sat Jul 03, 2021 7:45 am 230224E3217100B8C42624E884D300801700
or
Thank you so much, you're a legend! If I could buy you a beer I would!
The first code worked. Then I just turned off the TPMS. All accepted and no more ABS and TPMS light!
Just got to sort these out:
Saturday,03,July,2021,10:11:44:21320
VCDS Version: Release 21.3.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP82.clb
Control Module Part Number: 6R0 907 379 AJ    HW: 6R0 907 379 AF
  Component and/or Version: ESP8.2i front H05 0001
           Software Coding: 230224E3217100B8C42624E884D300801500
            Work Shop Code: WSC 31414 790 31414
2 Faults Found:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 156370 km
                    Time Indication: 0
                    Date: 2051.14.02
                    Time: 12:43:31
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1251
                    Hex Value: 0x1BA1
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 156370 km
                    Time Indication: 0
                    Date: 2051.14.02
                    Time: 12:43:31
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12E1
                    Hex Value: 0x20A1
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
And also figure out why the traction control light is still on. But if I have any issues figuring those out I will make a new thread.
I'm going to see if I can figure out what I did wrong when trying to make the code myself so I can learn how to do it properly :)
Thanks to the others that assisted me with this issue too!
(SAVING A SCAN NOW).
You need to do a basic setting of the steering angle sensor and esp unit
Fredydx7
Drives: Polo 2014 1.2
Post by Fredydx7 »
hello michel could you help me with my long code is a polo 2014 1.2
Fredydx7
Post by Fredydx7 »
hello michel could you help me with my long code is a polo 2014 1.2 TSI
Fredydx7 wrote: Mon Jan 10, 2022 9:47 pm
Let's talk in one place, here --> viewtopic.php?p=588461#p588461
