Ready for my BCM upgrade...What's next?
Hi all,
Thanks for your time with me, even though I don't have a Polo
BCM7E0937090C arrived, how can I post my autoscan here? Says invalid file extension. Could someone help me with the wiring I need to accomplish this fit (before I even get around to retrofitting anything). Does anyone still make the looms, or am I on my own.
Re: Ready for my BCM upgrade...What's next?
Trying to post the autoscan,
Forbidden. Contains contacts. Message seems to be spam.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Try to check this thread : viewtopic.php?f=56&t=65724
Scroll down till you find word/header "VCDS autoscan:"
And try to trim your scan and post.
remove the row with the web adress and you should be fine
Can't really see any differenceag69 wrote: ↑Tue Jul 13, 2021 5:11 am Try to check this thread : viewtopic.php?f=56&t=65724
Looks like we have a winner!!
Saturday,10,July,2021,12:53:18:25072
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: VSSZZZ6JZDR082595 License Plate:
Mileage: 283780km-176332mi Repair Order:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6JZDR082595 Mileage: 283780km-176332miles
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LE HW: 03L 906 023 Q
Component: 1,6l R4 CR td H33 9651
Revision: --H33--- Serial number:
Coding: 00114016000500080000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_ECM16TDI02103L906023LE 003006
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 74B1DE9EDE3D30AB9BB-8020
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 100200DB007500B4082A00EB00D600000000
Shop #: WSC 04941 000 00000
VCID: 0059824E9A451C0B8F3-8054
Component: LENKW.SENSOR H06 0060
Serial number: 090465LGE000F0
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FCB6E0716AFBFDF-802A
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 273972 km
Date: 2020.01.25
Time: 15:24:06
Voltage terminal 15: 12.20 V
Voltage terminal 30: 12.35 V
Terminal 15 status: On
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002541622-
Shop #: WSC 06403 785 00200
VCID: 2411EEDE22DDE02BCBB-8070
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 283358 km
Time Indication: 0
Date: 2015.06.28
Time: 14:49:02
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 195121222
Coding: 3C880BE88861250092200CF06E2B0CC8B00000FF608C0000200000000000
Shop #: WSC 12345 123 61029
VCID: 45D7535AC5A7F923FC5-8010
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3110
Coding: 030000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3110
Coding: 020000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K8 951 171 A
2 Faults Found:
00975 - Heated Rear Window (Z1)
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 283765 km
Time Indication: 0
Date: 2015.11.29
Time: 14:13:33
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 27
Reset counter: 70
Time Indication: 0
Component: VW10AirbagA0D H10 0020
Revision: -------- Serial number: 003GX01AUF0M
Coding: 003044
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD6066EC39165B117-801E
Serial number: 3495RRB400G4UHC4893L
Serial number: 3505RRB400G4UHC4NHQG
Part No SW: 6J0 920 904 L HW: 6J0 920 904 L
Component: KOMBI H04 0508
Coding: 410A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 34311E9E9EBD70AB5BB-8060
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 322300
VCID: 70B9D28EAAA50C8B7F3-8024
Component: IMMO H04 0508
Serial number:
VCID: 6A8DC0E68CF9F65B317-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 10121
Shop #: WSC 00049
VCID: 3039128E63654C8B3F3-8064
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70B9D28EA6A50C8B7F3-8024
Address 56: Radio (J503) Labels: None
Part No SW: 6J2 035 153 H HW: 6J2 035 153 H
Component: Radio H15 0302
Revision: R0000000 Serial number: SEZAZ2M4945431
Coding: 0505020002
VCID: 2B0305E243032F530A1-807E
End----------(Elapsed Time: 01:23, VBatt start/end: 12.5V/12.4V)-----------
Ok guys,
So what's possible? If I upgrade BCM, and money, time and parts are no problem, what, from this list, is likely to be dooable (using @iichel list of OEM retrofits)
OEM: Proper front windscreen with RLS (heated)
OEM: Auto Front light upgrade (ideally bi-xenon, but that would require auto levelling and headlight washers)
OEM: Folding/Heated mirrors
OEM: Power rear windows
OEM: Climate Control (over normal aircon)
OEM: Cruise Control
OEM: 6J facelift dashboard
OEM: infotainment upgrade (with BT, USB/UAX)
OEM: Heated front seats (but not essential as the seats are not leather)
Not sure what else that there could be that would make my life more enjoyable
OEM: Cruise Control
Lucero79 wrote: ↑Fri Jul 16, 2021 9:47 am Ok guys,
OEM: Proper front windscreen with RLS (heated) --> possible with 087K
OEM: Folding/Heated mirrors --> possible with 087K
OEM: Power rear windows --> possible with 087K
OEM: Climate Control (over normal aircon) --> possible with 087K
OEM: Cruise Control --> possible with 087K
OEM: 6J facelift dashboard --> possible with 087K
OEM: infotainment upgrade (with BT, USB/UAX) --> possible with 087K, for MIB PQ you perhaps need 7E0
OEM: Heated front seats (but not essential as the seats are not leather) --> possible with 087K
ok, so not the BCM I got then
Can anyone help? Have I got the wrong BCM for the upgrades planned?
It's not a wrong BCM. For the things I commented in bold, your current BCM is fine so the 090 is a bit overkill. For the others, an upgrade is needed.
Oh wow, ok, I see what you are saying now. My current BCM is actually ok for most of the upgrades and wouldn't require any special wiring on my part. Is it likely then that the wiring looms in the car already contain most of the plugs / wiring needed for some of these upgrades?
No I expect none of the wiring to be there
