The last Byte in the two units/addresses, 37 and 10, define the car model.
Have you checked?
Try with this new coding for Address 37:
040004110400000000000000
The navigation unit must be RESET every time its coding is modified, etc.
In order to change some Bytes in Address 10, you may first have to enter security access code 71679.
rns-315 plus 8k ops in fabia 5j vrs 1.4 tsi
- Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: rns-315 plus 8k ops in fabia 5j vrs 1.4 tsi
Thanks for the quick response
I will check this afternoon and let you know
Best regards
Vasileios
Best regards
Vasileios
Hello Fernando again, i have insert the coding but nothing happens for another time . I am sending you some screenshots if you can figure out .
td bank atm hours
Best regards
Vasileios
td bank atm hours
Best regards
Vasileios
Ok, I see that RNS315 has a different way of being coded than RNS510. Thanks for the images.
Sorry for my big mistake.
Have you asked in the ross-tech forum?
Hello Fernando I asked several times but no one cares about .
The irony is that I am registered member there and no response from anybody.
Best regards
VV
Best regards
VV
- til3tsio
- Drives: Seat Toledo KG
I know it’s an old thread but,
have you ever found a solution to that problem?
I have a very similar problem on a seat Toledo with RNS315 and 3K OPS.
I swapped the original PDC unit with one from a seat mii / vw up because the original didn't support RVCamera.
In the OPS screen car figure shows up correctly as a toledo ,
but on the rear-view camera screen with mini ops it shows a seat alhambra / vw sharan
Unfortunately, vcds does not provide descriptions or a label file for the seat version of the same radio.
Changing can gateway to VW/Sedan changes mini ops in RVC to the correct car image but then the OPS screen shows as a hatchback…
I thing that PDC needs correct parameterization but I do not have access to odis or vcp.
Hello my friend the problem still exsists .
Regards
V
Regards
V
- til3tsio
Sorry to hear that.
If I ever get access to VCP cable I will try another parameterization set and let you know if it works.
Καλημέρα !
Καλημέρα !
- Drives: Skoda Fabia II 2012
Hey! I had a question on the AMUNDSEN+ (RNS-315), which is installed in you in Fabia.VASILEIOS1972 wrote: ↑Wed Jul 17, 2019 7:33 pm Hello there, I have retrofit complete ops oem pdc in my wife's fabia rs . The car is equipped with rns-315 Amundsen+ with partnumber...
Is it normally working with original Park Assist?
Is it normally working with buttons on the steering wheel?
Is it normal working with the Maxidot screen?
Thank you very much for your reply!
Good evening everything works great !
