Hi All
we have 01317 error code but cant be cleared but where is the airbag menu i,m using U281 scanner
error code
- Drives: 2002
Re: error code
http://wiki.ross-tech.com/wiki/index.php/01317
What is the connection with the air bag? You probably need VAG COM for that.
- Drives: 2002
Re: error code
Hi
I thought it was to do with instrument cluster as the low brake pad warning light is on but wires are bridged out
I have ordered cable ,coming on wednesday and will try and reset with vag com
Thanks for replying
Thanks for replying
Re: error code
I think this is an indication that the IC is failing/ faulty
- Drives: 2002
Re: error code
Hi
excuse me what is IC .dont know what IC means
- Drives: 2018 MK10 AW1
Re: error code
IC is the instrument cluster?.
- Drives: 2002
Re: error code
Hi
Thanks I was thinking that a new lead arrived today and I have downloaded vagcom
so will try that
thanks for this info
so will try that
- Drives: 2002
Re: error code
Hi
I think it needs a new Instrument cluster also a engine management light came on but silly me cleared it
it looked like throttle revving high
any idea will wait to see if it comes back
- Drives: 2002
Re: error code
Hi All
I have changed the instrument cluster but it is showing high Mileage more thank the other one and starts for 1 sec then dies
it comes up with immobilser stopping engine error code
do I have to get it programmed I have vag-com lite can that do it
I thought it was only 2x plugs and it would be ok but seems not
