- Drives: 6R 1,6MPI(CFNA) sedan
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
No, I just suggested the gearbox is still needed the K-line to be connected to the OBDII socket like can-bus. And the possible issue could be is in K-line wire is connected to the BCM's T73b/37 as well so it could cause the reading faults because of 7E0 BCM sends LIN data packets through the T73b/37 to the K-line.
As you wrote T73b/37 is not connetcet at all, so that could not be the reason of reading inability for the 02 addres, so for now I dont have another suggestion...
I think I did it... I replaced all control modules from my car originally came with, with another module. And added some.
- Installed 1.6 TDI engine
- Installed DSG gearbox + gear selector
- Installed K-Line from T25/11 to T16/7 (OBD)
- Adapted immobiliser
- Coded various modules to work in accordance with DSG gearbox
01-Engine -- Status: OK 0000 --> CFWA to CAYC
02-Auto Trans -- Status: OK 0000 --> manual to DSG7 DQ200
03-ABS Brakes -- Status: OK 0000 --> ESP8.2i to ESP9.0i
04-Steering Angle -- Status: OK 0000 --> 6R0 to 6C0
05-Acc/Start Auth. -- Status: OK 0000 --> retrofitted kessy
08-Auto HVAC -- Status: OK 0000 --> manual to climatronic
09-Cent. Elect. -- Status: OK 0000 --> 6R0 937 088B to 7E0 937 090 C
+ WRM front, to folding mirror
+ WRM rear, from manual to electric
+ RLS retrofitted
+ DWA retrofitted
+ MFSW retrofitted
10-Park/Steer Assist -- Status: Malfunction 0010 --> retrofitted
15-Airbags -- Status: OK 0000 --> changed for passenger airbag deactivation
17-Instruments -- Status: OK 0000 --> 6R0 midline to 2H0 highline
19-CAN Gateway -- Status: OK 0000 --> 6R0 to 7E0
20-High Beam Assist. -- Status: OK 0000 --> retrofitted
25-Immobilizer -- Status: OK 0000 --> from normal to kessy
2B-Steer. Col. Lock -- Status: OK 0000 --> retrofitted kessy
2E-Media Player 3 -- Status: OK 0000 --> retrofitted
37-Navigation -- Status: OK 0000 --> RCD210 to RNS510 DAB
3C-Lane Change -- Status: OK 0000 --> retrofitted
44-Steering Assist -- Status: OK 0000 --> from electrohydraulic to electromechanic
47-Sound System -- Status: OK 0000 --> retrofitted dynaudio
4B-Multifunc. Module -- Status: Malfunction 0010 --> retrofitted
55-Headlight Range -- Status: OK 0000 --> retrofitted AFS
56-Radio -- Status: OK 0000 --> RCD210 to RNS510 DAB
57-TV Tuner -- Status: OK 0000 --> retrofitted
61-Battery Regul. -- Status: OK 0000 --> 6R0 to 7E0
+ BDM J367 from 6R0 to 6C0 GTI
65-Tire Pressure -- Status: OK 0000 --> retrofitted
69-Trailer -- Status: OK 0000 --> retrofitted
6C-Back-up Cam. -- Status: OK 0000 --> retrofitted
77-Telephone -- Status: OK 0000 --> retrofitted
Friday,20,August,2021,14:33:16:11868
VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4544.4
Data version: 20210318 DS325.0
www.Ross-Tech.com
Dealer/Shop Name: iichel retrofitting
Workshop Code: 470 31889 031889
VIN: License Plate:
Mileage: Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55
56 57 61 65 69 6C 77 0B
VIN: Mileage:
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 DR HW: 03L 906 023 A
Component: R4 1.6l TDI H23 9978
Revision: --H23--- Serial number: 00000000000000
Coding: 00254036032401080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI02103L906023DR 003016
ROD: EV_ECM16TDI02103L997557Q.rod
VCID: 79AF10A5095BB703C8D-802C
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412500C5841A146E825500521504
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: N/A
VCID: 0F7B4E7D27DF89B3069-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 372BD69D7FCF61737E9-8062
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B773-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBFA8EB3400B33807F0BFCB9FF0FF8067EFE08D78D031E400030800
VCID: 2B03FAEDB307D5930A1-807E
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195101
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 246
Mileage: km
Date: 2021.08.20
Time: 14:30:19
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC9B117-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
Shop #: WSC 12345 123 12345
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3333E28D6BB78D53421-8066
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042204
VCID: 688945E162713E8B273-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
VCID: 2E05F3F98095A0BB2DF-807A
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9B317-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9B3269-807A
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7666620365
Coding: 010100
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987B65F-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B3269-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ÿ
Subsystem 4 - Serial number: H21982ÿ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8BE73-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1B817-806E
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 57: TV Tuner Labels: None
Part No SW: 3C0 919 148 B HW: 3C0 919 148
Component: R78 DTV-JP 0250
Revision: R0H14000 Serial number: 80100800042102
Coding: 0000816
Shop #: WSC 01324 020 00200
VCID: 280905E1AEF1FE8BE73-807C
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0010
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F7A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9B3269-807A
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7E0 907 441 HW: 7E0 907 441
Component: J772__Rearview 0040
Revision: 00H08000 Serial number: 525PA8-J060533
Coding: 0030115
VCID: 65974CD5996323E31C5-8030
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105254406
Coding: 020100000100010000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 25170CD5D563E3E3DC5-8070
End----------(Elapsed Time: 02:50, VBatt start/end: 12.8V/12.8V)-----------
+ RLS retrofitted
+ DWA retrofitted
+ MFSW retrofitted
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Re: iichels Polo 6R 1.6TDI DSG Bluemotion --> OEM++ R-Line conversion
Amazing iichel...
i am sure you would have a peaceful weekend
Waiting for a photo and video/s
There are still some small jobs to do, to put the car back into perfect condition.
But for now, I'm pretty f*****g happy
- ag69
iichel -- nice video. thank you. now we can see how much time and efforts it must have taken.
Also i liked the naming you used : Racing, No Racing & Super Speed
Great job again. Tons of efforts.
- Drives: 2013 1.2 6R in Flash Red
Hi iichel, just found this thread, I've read nearly all of it. Absolutely amazing work done to a humble Polo. Its a long way back, but I'm especially interested in your suspension that you mention on the first page.
"OEM 6R sports suspension springs
Koni FSD shock absorbers all around--> 2100-4122
OEM 1J Rear spring mounts from Cupra -10mm --> 1J0512149"
Do you have the part numbers for the springs? I assume they are OEM GTi springs? Also the Cupra rear spring mounts are something I've not seen before. Is it just a case of swapping the spring mounts and the rear is 10mm lower? I really want to lower my Polo a bit but I can't install aftermarket parts due to my insurance so this really interests me. One other thing, does anyone know if the GTI shock absorbers are different to the normal Polo? Or would I need GTI shocks as well if I was to install GTI springs?
Sorry for all the questions, would love to know more.
No, the springs are not OEM GTI springs, that wouldn't make sense since that's a lot heavier than the 1.2 TDI.
It really depends on the engine and gearbox. And GTI dampers are not specific to the GTI. They also appear on i.e. the 1.6 TDI.
If you do lower, I'd suggest to replace the rear dampers for i.e. Bilstein B4/B6 since 25+mm lowering on the rear will quickly demolish your standard dampers.
You can have a look here for genuine lowering springs --> viewtopic.php?p=444680#p444680
The cupra rear spring mounts will indeed drop you about 10mm.
Wow, thanks for the quick reply.
I wasn't aware of the OEM Sports springs so I was just assuming they were for a GTI. Do you know if the sports springs are designed to be used with the original shock absorbers? Or are there OEM sports dampers available too? I can't fit any aftermarket parts, only OEM stuff so it's a bit difficult to figure stuff out.
If anything the sports springs lower the car too much, the GTI springs lower about 15mm but they are unsuitable due to the weight difference between a 1.8T and my 1.2. Are there any OEM options that lower about 15mm but would work on my 1.2 6R?
I don't think there is an OEM solution for 15mm lower. GTI springs will probably make your car higher instead of lower since you're putting 1200kg springs on a 900kg car...
Usually insurance companies don't really mind non-OEM shock absorbers since you can simply put an aftermarket shock like a Bilstein, Eibach, etc in there instead of a Sachs.
It's not a 'listed' part, so to say. Springs on the other hand are a different matter. But that's based on my own experience with German, Belgian and Swiss legislation. I don't know about the UK but I suspect they are probably just as strict or less strict.
Maybe I will abandon plans to lower it for now then. Going back to the Cupra rear spring seat, is it a straight swap with the standard spring seat? Also, are they the lower or upper spring mount? I assume the one on the left in that picture is the Cupra part?
Yes, it's the left one. It's a straight swap at the bottom.
Would you happen to have a link to where you bought it? I'm only finding them with letters on the end of the part numbers, e.g 1j0512149b,c,g
i always buy my stuff at the dealership
