KamilPL
Drives: Seat Ibiza 6j1
Post by KamilPL »
To do this, I have to unscrew the steering wheel and pass the wires through it, it will take me some time due to the limited amount of time, these 2 cables will solve the problem with the mirrors and windows? :)
Do not know, maybe it won't fix it and you have to reinstall everything as it was at the beginning.
https://www.youtube.com/watch?v=wKz3wxf_6N4
https://www.youtube.com/watch?v=PUrg02fFTkg
https://www.youtube.com/watch?v=Ob0QCogk040
https://www.youtube.com/watch?v=SVSDAqcBbsU
:lol:
KamilPL
Post by KamilPL »
Ok Cyclo, in my free time I will try to understand it and we will come back to the topic on Monday 23.08, I do not know if my car has cables T73b / 57 to T32 / 29 and T73b54 to T32 / 28 because I do not have time to check it now, but looking at the wiring ibizy 6j5 2013, this is where the cables are connected :)
Your car does not have these cables, only cars with BCM 090 will have them.
iichel wrote: Wed Aug 18, 2021 1:23 pm Your car does not have these cables, only cars with BCM 090 will have them.
+1 🍻
KamilPL wrote: Wed Aug 18, 2021 1:01 pm ... looking at the wiring ibizy 6j5 2013, this is where the cables are connected :)
Those wiring looms will be perfect for our purpose 👌, they confirm our suspicions and knowledge about your 7H0 BCM Max and PQ25 platform...
- edit:
If everything goes well with the new CAN lines for your 7H0 BCM Max, the study for the rest of the wires and correct BCM coding for Automatic lights + CH & LH is already done ...
By the way, you have very small feet and large hands, which confirms that this forum helps all kinds of beings ...👽😅
You have to tell me exactly the month of manufacture of your Ibiza 6J (documentation) and take a clear photo of the BCM 087K serial number if it is the original/factory BCM.
I downloaded all the SEAT diagrams (all models 😏) from erWin and there may be discrepancies between those manufactured since June 2012 and those manufactured since November 2012.
KamilPL
Post by KamilPL »
Hi cyclo, my cables are twisted, but there is no time for assembly, maybe I will find a moment today to cover it, on August 26 I will be posting info on whether the windows are working on 7h0937090 to go further with the work on ibiza :) production of my ibiza 04.2012 BCM 6R0937087K Z11, 7H0937090 comes from Ibiza 6j5 03.2013 8)
KamilPL
Post by KamilPL »
8)
Thanks.
Ok, ok, now I understand some technical questions related to the VIN and the diagrams and that are not important to be explained.
Well, assuming that the new CAN lines will make the 7H0 BCM better manage the control units in your Ibiza, the next step is to feed the 7H0 BCM so that it can subsequently exercise full control over the low/dipped beams. Currently your dipped beams are managed/powered by relay J331.
Relay J331 is activated according to headlight models.
- From light switch ... for H7 dual headlights.
- From light switch + steering combination switch (HB/LB stalk/lever) ... for H4 headlights.
With 7H0 BCM this relay is not necessary (it must be removed, first remove and isolate the blue wire on the light switch T17/7), however this relay (holder/adapter) receives a RED power wire that is perfect for you to feed two pins of your 7H0 BCM, T73a/63 and T73b/68, from this RED wire.
Note (minor): These two new red/white wires also feed other pins on the 7H0 BCM (lights and BCM internals), which will cause some diagnostic faults. Some faults can be corrected by coding, but others cannot, and new wires must be installed to avoid diagnostic faults. Don't worry at this time, it has an easy solution. :)
The next step is to connect directly to the BCM connectors the Yellow and Yellow/Black wires that you remove from the output of the SC57 and SC58 fuses. The following diagrams shows the assignment.
The next step is to add a new 0.5mm2 wire from the SC36 fuse output to T73a/62.
The next step is to add the headlight control relay that will make automatic low beam control possible. This relay is called J828.
I show you in images/diagrams the identification and what you must do to install this relay.
Indentification:
Installation:
The next step is to add 5 new wires. Light switch - BCM - Dimmer. 58 signal, 58 power supply (58d), License plate lights, Auto function.
Note: If in your previous wire installation in the light switch you have done something different or if any of these 5 wires are joined together to achieve some trick 🤭, your installation is not correct.
To install these 5 new wires follow the order that I have established in the following diagram (download the image to see it enlarged).
The next step is to have the reversing light (back-up light) and rear fog light under BCM control.
To avoid confusion, I explain what you should do instead of showing it in diagrams.
Reversing light:
Only for manual gearbox, for DSG it is not necessary to do this step.
Explained for LHD models. For RHD models, it is the same but in the opposite taillight.
- Remove and isolate the original T6/4 wire from the right taillight connector.
- Add a new 0.5 mm2 wire from T73b/12 to T6/4. ...(5.5 - 6.5m)
Rear fog light:
- Remove the original wire T17/9 from the light switch and splice a new 1.0mm2 wire to this original wire, take/run this new wire up to T73a/6 BCM black connector.
- Add a new 0.5mm2 wire from T17/9 to T73b/43 BCM white connector.
Daytime running lights (DRL) (TFL -Tagfahrlicht-) for retrofitted 6P halogen headlights (PQ26) on an Ibiza 6J with an adapted BCM Max (PQ25). :)
Installation:
From Light switch - to BCM.
- Install a new 0.5mm2 wire from T17/3 light switch connector to T73b/29 BCM white connector.
From BCM - to 6P Halogen headlights with LED module.
The 6P Halogen headlights LED modules receive two power signals from the BCM, the one dedicated to the DRLs and the one dedicated to the Sidelights/Parking Lights.
Left headlight (two new 0.5mm2 wires).
DRL.
- Install a new wire from T73b/3 to T10/4 in headlight connector.
Parking/Side light.
Edition, November 11, 2021.
Do not perform the next step for parking lights. Reason here :arrow: viewtopic.php?p=587292#p587292
- Remove and isolate original T10/10 in headlight connector.
- Install a new wire from T73b/5 to T10/10.
Right headlight (two new 0.5mm2 wires).
DRL.
- Install a new wire from T73a/5 to T10/4 in headlight connector.
Parking/Side light.
- Install a new wire from T73b/6 to T10/10.
After doing this installation/adaptation it is necessary to code the BCM Max.
Editing ... please wait.. step by step, do not do anything at the moment until you know the results of the new CAN lines ... (SOLVED!)
I will support this info with diagrams and images.
KamilPL
Post by KamilPL »
Cables T32 / 29 - -> T73B / 57, T32 / 28 ---> T73b / 54 when released, the car does not start the windows do not work
KamilPL
Post by KamilPL »
Original cables T32 / 28, T32 / 29 removed and individually insulated, something wrong is my ibiza resistant to modification? 😂
KamilPL
Post by KamilPL »
KamilPL
Post by KamilPL »
Typ podwozia: 6J-SE25 (6N0)
Skanowanie: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZDR026882
01-Silnik -- Stan: Usterka 0010
03-ABS/hamulce -- Stan: Usterka 0010
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: Usterka 0010
09-Centr.zesp.elektr. -- Stan: Usterka 0010
15-Airbag -- Stan: Usterka 0010
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
2E-Media Player 3 -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: Usterka 0010
4B-Moduł wielofunkc. -- Stan: Usterka 0010
56-Radio -- Stan: Usterka 0010
77-Telefon -- Stan: Usterka 0010
Adres 01: Silnik        Plik etykiet: 03C-906-024-BXW.lbl
   Oznaczenie elementu SW: 03C 906 024 CD    HW: 03C 906 024 CD
   Komponent:       CGGB  MM4HV G 8548
   Weryfikacja: --H09---    Numer seryjny:
   Kodowanie: 0000071
   Kod serwisu: WSC 00200 935 12345
   VCID: 62CB1F8FBE4FB89BB5-5178
2 - ilość znalezionych błędów. Oto one:
17978 - Sterownik silnika zablokowany przez immobiliser
            P1570 - 000 -
             Ramka zamrożona:
                    Stan błędu: 01100000
                    Priorytet błędu: 2
                    Częstość błędu: 1
                    Wew.licznik błędów: 162
                    Wskaźnik czasu: 0
             Ramka zamrożona:
                    Bity binarnie: 00000001
                    Obciążenie: 25.9 %
                    Lambda: 0.0 %
                    Prędkość: 0.0 km/h
                    Temperatura: 72.0*C
                    Ciśnienie rzecz.: 303.6 mbar
                    Obroty silnika: 969 /min
28827 - Brak komunikacji z zestawem wskaźników
            U0155 - 000 -
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
             Ramka zamrożona:
                    Bity binarnie: 00000100
                    Obciążenie: 0.0 %
                    Lambda: 0.0 %
                    Prędkość: 0.0 km/h
                    Temperatura: 56.0*C
                    Ciśnienie rzecz.: 975.4 mbar
                    Obroty silnika: 0 /min
Kody gotowości: 0110 0001
Adres 03: ABS/hamulce (J104)       Plik etykiet:. 6R0-907-37x-ESP82.clb
   Oznaczenie elementu SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Komponent: ESP8.2i front H05 0002
   Weryfikacja: --------
   Kodowanie: 110224DB216F00B8882D24EA84D300401100
   VCID: 000F350797030A8BC3-8054
01317 - Sterownik w zestawie wskaźników (J285)
            004 - Brak sygnału / brak komunikacji
             Ramka zamrożona:
                    Stan błędu: 01100100
                    Priorytet błędu: 0
                    Częstość błędu: 3
                    Wew.licznik błędów: 167
                    Przebieg: 0 km
                    Wskaźnik czasu: 0
             Ramka zamrożona:
                    Wartość Hex: 0x0007
                    Wartość Hex: 0x0000
                    Wartość Hex: 0x3011
                    Wartość Hex: 0x259A
                    Wartość Hex: 0x007F
                    Wartość Hex: 0x7F7F
                    Wartość Hex: 0x7FF8
00474 - Sterownik immobilisera
             Ramka zamrożona:
                    Priorytet błędu: 0
                    Częstość błędu: 3
                    Przebieg: 0 km
                    Wskaźnik czasu: 0
             Ramka zamrożona:
                    Wartość Hex: 0x0000
                    Wartość Hex: 0x0000
                    Wartość Hex: 0x3032
                    Wartość Hex: 0x149A
                    Wartość Hex: 0x007F
                    Wartość Hex: 0x7F7F
                    Wartość Hex: 0x7FF8
Adres 08: Klimatyzacja (J255)       Plik etykiet: 6R0-907-044.clb
   Oznaczenie elementu SW: 6J0 820 043 D    HW: 6J0 820 043 D
   Komponent: Climatronic   H08 0707
   Weryfikacja: S0000000
   VCID: 254144932CE10FA390-8070
Znaleziono 1 błąd:
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:. 7H0-937-08x-09.clb
   Oznaczenie elementu SW: 7H0 937 090     HW: 7H0 937 090
   Komponent: BCM PQ25 Max4 H72 0708
   Weryfikacja: B9072001    Numer seryjny: 0531 063131236
   Kodowanie: 7C8829F8C861010001200EF07EA80EC8F0C042FF60842040200000000000
   VCID: 6BD572AB8A85F9D306-803E
   Podsystem 1 - Oznaczenie elementu: 1K0 955 559 AH  Plik etykiet: 1K0-955-559-AG.CLB
   Komponent: RLS 120315 05  54  0403
   Kodowanie: 07302D
   Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 AK    HW: 6R0 959 801 AK  Plik etykiet: 6R0-959-801.CLB
   Komponent: J386__TSG_FT  007 5110
   Numer seryjny: --------------------
   Kodowanie: 020000
   Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 AR    HW: 6R0 959 802 AR  Plik etykiet: 6R0-959-802.CLB
   Komponent: J387__TSG_BT  007 5110
   Kodowanie: 020000
01516 - Zacisk 30 po lewej stronie
            011 - Przerwa w obwodzie
             Ramka zamrożona:
                    Stan błędu: 01101011
                    Priorytet błędu: 3
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
00927 - Zacisk 30 po prawej stronie
             Ramka zamrożona:
                    Priorytet błędu: 3
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
Adres 15: Airbag (J234)       Plik etykiet:| 5K0-959-655.clb
   Oznaczenie elementu SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Komponent: VW10AirbagA01 H10 0020
   Weryfikacja: --------    Numer seryjny: 003GX016A6B0
   Kodowanie: 003031
   Kod serwisu: WSC 06401 785 00200
   Zbiór danych ASAM: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9BD72FEDBF00DB5D-801E
   Czujnik zderzenia bocznej poduszki bezpieczeństwa kierowcy:
   Numer seryjny: 3495RRB406316Q1G31E
   Czujnik zderzenia bocznej poduszki bezpieczeństwa po stronie przedniego pasażera:
   Numer seryjny: 3505RRB405117HSIJ13A
12670208 - Magistrala danych
          U1122 00 [009] - niewiarygodna informacja
          [Nowa funkcja - rozszerzone informacje o kodach błędów (protokół UDS) - jest dostępna wyłącznie przy użyciu najnowszych interfejsów, oferowanych na VCDS
          Potwierdzony - Testowany od skasowania kodów błędów
             Ramka zamrożona:
                    Stan błędu: 00000001
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 0 km
                    Data: 2000.00.00
                    Czas: 00:00:00
12674816 - Magistrala danych
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
                    Przebieg: 0 km
                    Data: 2000.00.00
                    Czas: 00:00:00
Adres 17: Zest.wskaźników
Nie może być osiągnięty
Adres 19: CAN Gateway (J533)       Plik etykiet:. 6N0-909-901-6R.clb
   Oznaczenie elementu SW: 6N0 909 901     HW: 7H0 937 090
   Komponent: GW-K-CAN TP20 H72 0708
   Kodowanie: 422000
   VCID: 70EF65C7A3A31A0B33-8024
02830 - Sterowanie mag.CAN jedn.odłączania syst.wspomagających kierowcę
            000 - -
             Ramka zamrożona:
                    Priorytet błędu: 3
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
00381 - Magistrala danych zestawu wskaźników
            014 - wadliwy
             Ramka zamrożona:
                    Stan błędu: 01101110
                    Priorytet błędu: 1
                    Częstość błędu: 1
                    Wskaźnik czasu: 0
Adres 25: Immobiliser
Adres 2E: Media Player 3 (J650)       Plik etykiet:. 5N0-035-342.lbl
   Oznaczenie elementu SW: 6J0 035 342 E    HW: 6J0 035 342 E
   Komponent: SG EXT.PLAYER H13 0240
   Weryfikacja: A1001003    Numer seryjny: 7662260740
   Kodowanie: 020000
   Kod serwisu: WSC 64564 324 38760
   VCID: 2643439F51E704BB99-8072
Nie znaleziono błędów.
Adres 44: Wsp.kierownicy        Plik etykiet: 6Q0-423-156.clb
   Oznaczenie elementu: 6R0 423 156 B
   Komponent: LenkhilfeTRW        V277
   Kodowanie: 11211
   Kod serwisu: WSC 06402
   VCID: 2F6DA6BBEA1D45F36A-807A
Znaleziono 1 błąd:
            49-00 - Brak komunikacji
Adres 4B: Moduł wielofunkc.        Plik etykiet: 6J0-959-441.clb
   Oznaczenie elementu: 6J0 959 441 A
   Komponent: MF-Modul       0007 0001
   Kodowanie: 0000002
   Kod serwisu: WSC 77005 000 00000
   VCID: 3169A0C3A82953037C-8064
Znaleziono 1 błąd:
00470 - Grupowa magistrala danych układu komfortu w jednoprzewodowym trybie pracy
            011 - Przerwa w obwodzie - Sporadyczny
Adres 56: Radio (J503)       Plik etykiet:. 6J0-035-153.clb
   Oznaczenie elementu SW: 6J1 035 153 G    HW: 6J1 035 153 G
   Komponent: Radio         H15 0204
   Weryfikacja: R0000000    Numer seryjny: SEZAZ2M4042195
   Kodowanie: 0001040002
   Kod serwisu: WSC 04941 000 00000
   VCID: 295948A340F92BC3B4-807C
Adres 77: Telefon (J412)       Plik etykiet:| 7P6-035-730.clb
   Oznaczenie elementu SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Komponent: TELEFON       H09 2730
   Weryfikacja: 1B001001    Numer seryjny: 00007662181617
   Kodowanie: 0E00000001010110
   Kod serwisu: WSC 06402 785 00200
   Zbiór danych ASAM: EV_UHVNA A01015
   ROD: EV_UHVNA_A01_VW25.rod
   VCID: 356194D394417F2320-8060
Znaleziono 1 błąd:
12670208 - Brak komunikacji z zestawem wskaźników
          U0155 00 [009] - -
          [Nowa funkcja - rozszerzone informacje o kodach błędów (protokół UDS) - jest dostępna wyłącznie przy użyciu najnowszych interfejsów, oferowanych na VCDS]
             Ramka zamrożona:
                    Priorytet błędu: 6
                    Częstość błędu: 1
Koniec --------------------(Skanowanie trwało: 02:54)----------------------
Could you please install the English version of vcds?
KamilPL
Post by KamilPL »
Yes, I can, but it's only tomorrow because I do not have access to the EN program installation
