Gave me this:
- 1. Is it definitely the knock sensor?
- 2. Where is it exactly?
- 3. How easy would they be to replace? I'm by no means a mechanic but I used to fix pedal bikes for a living so I'm not exactly clueless either. Can get hold of a torque wrench (I'm aware these things need to be torqued up correctly).
- 4. If too hard how expensive a job is it for my mechanic? Rough idea if possible.
- 5. Is it safe to drive in the interim? It seems to work fine. Was hoping to use it a bit as its been sat unused for a while.
Car is basically a spare. It was my Dads. Relatively low mileage (75k) and I'm keeping it so my wife can use it (when she passes her test - failed twice now). So I'm hesitant to spend much money on it. Might just SORN it until she's passed.
Thanks in advance.
If the images aren't showing they can be found here:
https://imgur.com/a/4VwrKqx
https://imgur.com/a/s2jeyDU
