How do I remove tyre repair kit bracket?
PurplePanda
Drives: 2017
Post by PurplePanda »
Has a bolt in the middle with 12 points. I need to get the bracket out to clean underneath, can anyone help with how I can do this?
Re: How do I remove tyre repair kit bracket?
Spline is what that type of "grip" is called.
CarbonChaos
Post by CarbonChaos »
Search for ‘ multi spline tool ‘ or even ‘ triple square tool’ on google you will find a tool ,they come in various sizes like any other socket.
cheba
Drives: Polo R WRC 2014
Post by cheba »
As was mentioned above, this socket is commonly called "triple square" but the correct name is "XZN".
You'll need an XZN bit of the correct size to remove it.
