Skills and experience are required for the perfect manual crimp of terminals, as well as knowledge of each type of terminal and wires.
I have about 10 different crimp tools, one of my favorites is not the most expensive ...
The same can be said for removing terminals from plastic connectors.
There is only one way to extract a terminal smoothly, you have to find it, then everything will be child's play ...
KamilPL
- Drives: Seat Ibiza 6j1
I'm stupid
success works, the windows counter works all right
we can go to the next step, I think I know where I would have the error that it did not work before
connected T32/28 -> T72/57 | T32/29 -> T72/59 so the other way around
Cornering light does not work
Don't worry, we've all done more stupid stuff than this. Happy you found it.
KamilPL
Sorry for the lack of EN language in VCDS I only have PL language
Typ podwozia: 6J-SE25 (6N0)
Skanowanie: 01 03 04 08 09 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZDR026882 Przebieg: 163670km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-Kąt skrętu kierow. -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: Usterka 0010
15-Airbag -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
2E-Media Player 3 -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
4B-Moduł wielofunkc. -- Stan: OK 0000
56-Radio -- Stan: OK 0000
77-Telefon -- Stan: OK 0000
Adres 01: Silnik Plik etykiet: 03C-906-024-BXW.lbl
Oznaczenie elementu SW: 03C 906 024 CD HW: 03C 906 024 CD
Komponent: CGGB MM4HV G 8548
Weryfikacja: --H09--- Numer seryjny:
Kodowanie: 0000071
Kod serwisu: WSC 00200 935 12345
VCID: 62CB1F8FBE4FB89BB5-515A
Nie znaleziono błędów.
Kody gotowości: 0000 0000
Adres 03: ABS/hamulce (J104) Plik etykiet:. 6R0-907-37x-ESP82.clb
Oznaczenie elementu SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Komponent: ESP8.2i front H05 0002
Weryfikacja: --------
Kodowanie: 110224DB216F00B8882D24EA84D300401100
VCID: 000F350797030A8BC3-8054
Adres 08: Klimatyzacja (J255) Plik etykiet: 6R0-907-044.clb
Oznaczenie elementu SW: 6J0 820 043 D HW: 6J0 820 043 D
Komponent: Climatronic H08 0707
Weryfikacja: S0000000
VCID: 254144932CE10FA390-8070
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. 7H0-937-08x-09.clb
Oznaczenie elementu SW: 7H0 937 090 HW: 7H0 937 090
Komponent: BCM PQ25 Max4 H72 0708
Weryfikacja: B9072001 Numer seryjny: 0531 063131236
Kodowanie: 7C8829F8C861010001200EF07EA80EC8F0C042FF608D2040200000000000
VCID: 6BD572AB8A85F9D306-803E
Podsystem 1 - Oznaczenie elementu: 1K0 955 559 AH Plik etykiet: 1K0-955-559-AG.CLB
Komponent: RLS 120315 05 54 0403
Kodowanie: 07302D
Podsystem 2 - Oznaczenie elementu SW: 6R0 959 801 AK HW: 6R0 959 801 AK Plik etykiet: 6R0-959-801.CLB
Komponent: J386__TSG_FT 007 5110
Numer seryjny: --------------------
Kodowanie: 020000
Podsystem 3 - Oznaczenie elementu SW: 6R0 959 802 AR HW: 6R0 959 802 AR Plik etykiet: 6R0-959-802.CLB
Komponent: J387__TSG_BT 007 5110
Kodowanie: 020000
2 - ilość znalezionych błędów. Oto one:
01516 - Zacisk 30 po lewej stronie
011 - Przerwa w obwodzie
Ramka zamrożona:
Stan błędu: 01101011
Priorytet błędu: 3
Częstość błędu: 1
Wew.licznik błędów: 167
Przebieg: 163671 km
Wskaźnik czasu: 0
Data: 2016.01.22
Czas: 02:37:51
00927 - Zacisk 30 po prawej stronie
Ramka zamrożona:
Priorytet błędu: 3
Częstość błędu: 1
Przebieg: 163671 km
Wskaźnik czasu: 0
Data: 2016.01.22
Czas: 02:37:51
Adres 15: Airbag (J234) Plik etykiet:| 5K0-959-655.clb
Oznaczenie elementu SW: 6R0 959 655 K HW: 6R0 959 655 K
Komponent: VW10AirbagA01 H10 0020
Weryfikacja: -------- Numer seryjny: 003GX016A6B0
Kodowanie: 003031
Kod serwisu: WSC 06401 785 00200
Zbiór danych ASAM: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00DB5D-801E
Czujnik zderzenia bocznej poduszki bezpieczeństwa kierowcy:
Numer seryjny: 3495RRB406316Q1G31E
Czujnik zderzenia bocznej poduszki bezpieczeństwa po stronie przedniego pasażera:
Numer seryjny: 3505RRB405117HSIJ13A
Adres 17: Zest.wskaźników (J285) Plik etykiet:| 5K0-920-xxx-17.clb-SRI1
Oznaczenie elementu SW: 6J0 920 804 K HW: 6J0 920 804 K
Komponent: KOMBI H03 0507
Numer seryjny: 00000000000000
Kodowanie: 110A00
Kod serwisu: WSC 12345 123 01234
Zbiór danych ASAM: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 326BAFCF652F681B05-8066
Adres 19: CAN Gateway (J533) Plik etykiet:. 6N0-909-901-6R.clb
Oznaczenie elementu SW: 6N0 909 901 HW: 7H0 937 090
Komponent: GW-K-CAN TP20 H72 0708
Kodowanie: 422000
VCID: 70EF65C7A3A31A0B33-8024
Adres 25: Immobiliser (J334) Plik etykiet:| 5K0-920-xxx-25.clb
Oznaczenie elementu SW: 5K0 953 234 HW: 5K0 953 234
Komponent: IMMO H03 0507
Numer seryjny:
Kodowanie: 000000
Kod serwisu: WSC 00000 000 00000
Zbiór danych ASAM: EV_Immo_UDS_VDD_RM09 A03009
VCID: 6ADB77AF8D7FE0DB7D-803E
Adres 2E: Media Player 3 (J650) Plik etykiet:. 5N0-035-342.lbl
Oznaczenie elementu SW: 6J0 035 342 E HW: 6J0 035 342 E
Komponent: SG EXT.PLAYER H13 0240
Weryfikacja: A1001003 Numer seryjny: 7662260740
Kodowanie: 020000
Kod serwisu: WSC 64564 324 38760
VCID: 2643439F51E704BB99-8072
Adres 44: Wsp.kierownicy Plik etykiet: 6Q0-423-156.clb
Oznaczenie elementu: 6R0 423 156 B
Komponent: LenkhilfeTRW V277
Kodowanie: 11211
Kod serwisu: WSC 06402
VCID: 2F6DA6BBEA1D45F36A-807A
Adres 4B: Moduł wielofunkc. Plik etykiet: 6J0-959-441.clb
Oznaczenie elementu: 6J0 959 441 A
Komponent: MF-Modul 0007 0001
Kodowanie: 0000002
Kod serwisu: WSC 77005 000 00000
VCID: 3169A0C3A82953037C-8064
Adres 56: Radio (J503) Plik etykiet:. 6J0-035-153.clb
Oznaczenie elementu SW: 6J1 035 153 G HW: 6J1 035 153 G
Komponent: Radio H15 0204
Weryfikacja: R0000000 Numer seryjny: SEZAZ2M4042195
Kodowanie: 0001040002
Kod serwisu: WSC 04941 000 00000
VCID: 295948A340F92BC3B4-807C
Adres 77: Telefon (J412) Plik etykiet:| 7P6-035-730.clb
Oznaczenie elementu SW: 7P6 035 730 F HW: 7P6 035 730 F
Komponent: TELEFON H09 2730
Weryfikacja: 1B001001 Numer seryjny: 00007662181617
Kodowanie: 0E00000001010110
Kod serwisu: WSC 06402 785 00200
Zbiór danych ASAM: EV_UHVNA A01015
ROD: EV_UHVNA_A01_VW25.rod
VCID: 356194D394417F2320-8060
Znaleziono 1 błąd:
0022 - Radio
U1066 00 [000] - Brak komunikacji
[Nowa funkcja - rozszerzone informacje o kodach błędów (protokół UDS) - jest dostępna wyłącznie przy użyciu najnowszych interfejsów, oferowanych na VCDS
Sporadyczny - Niepotwierdzony - Testowany od skasowania kodów błędów
PerfectKamilPL wrote: Tue Aug 31, 2021 5:05 pm I'm stupidsuccess works, the windows counter works all right
And do not worry, it is better to make a mistake at the beginning to stay alert in the following works/steps,
you can start with them whenever you want.
I'll take a look at the BCM coding.
Warning:
I will do the new BCM coding based on the Autoscan with the original BCM 087, which seems more reasonable to me than the Autocan with 7H0 BCM (with some inappropriate changes).
Later you can modify what you think is convenient, but remember that the one I provide should be your starting point for the BCM Max 7H0.
My recommendation is that you do not touch the new BCM coding that I provide you during the installation process (as if you were a magician's apprentice
KamilPL
now I have to do everything you gave in this link viewtopic.php?p=585264#p585264 and everything will work?
leaving home machine works, coming home machine does not work / traffic light lever
Yes, ... if you don't make mistakes, everything will work perfectly.
The process is:
Installation ---> Coding ---> Troubleshooting in case of mistakes. (step by step)
The process is:
KamilPL
And why does coming home not work by pulling the high beam lever / via the RLS sensor?
We will stop the topic temporarily, I will return to the topic as the electrician will take over the electrician, because I gave advice to drag 2 cables and then I will give it to the electrician
I'll post your new BCM Max coding shortly, stay tuned ...
In the parameterization data that I have for BCMs PQ25 (factory), this function is not contemplated.KamilPL wrote: Tue Aug 31, 2021 8:42 pm And why does coming home not work by pulling the high beam lever / via the RLS sensor?
read my quote again ⬆ciclo wrote: Tue Aug 31, 2021 7:49 pm Warning:
My recommendation is that you do not touch the new BCM coding that I provide you during the installation process (as if you were a magician's apprentice![]()
), otherwise, we will not be able to know what is happening in case of faults.
7C8829F88861010001200EF06EEB9EC85FC067FF608D30C1200000030000
That is, the next autoscan must be with all new wires installed and with this BCM coding. Good luck!
KamilPL
in the meantime, another question rain closing does not work despite activating bcm / rls + locked car from the key, any advice?
Is it possible in Ibiza 6j window motors to program the mirrors to close / open when opening / closing the car with the remote control?
How to install the washer fluid level sensor? no sensor no wiring loom
Update : 13.09 ibiza goes to an electrician, around a week it will be constant so +/- 20.09 we come back to the topic
I'm afraid that your WRMs don't support those functions, they must be with a higher SW. However, once you code the BCM and RLS to "rain closing active" the WRMs must learn the new coding by setting the "comfort function" again with the window switches (owner manual). Try it.
I do not recommend activating this feature.
As for the G33 Ibiza 6J, this is the diagram:
Once installed, it must be activated in the IC.
You may be inspired to install it with this info:
https://www.youtube.com/watch?v=pG7Rn7XDffA ...the sensor is the same. (Ali)
In addition to ciclo's excellent post above, the brown/white wire can also be replaced by a 'normal' ground wire to chassis.
KamilPL
translator twists sentences and I don't understand everything exactly
We let go of the washer fluid level topic
It is not possible to close / open the mirrors when locking / opening the car in ibiza?
What do I need to do for Active Rain Shutdown to work?
