Hi Guys
I have a 1998 Polo i have replaced the fuel pump the coil Ht leads sparkplugs and distributor cap but it is still lacks real pulling power any idea what it could be ? Thanks for any reply.
Having trouble.
- JUUL
- Drives: 6N 1995
Re: Having trouble.
Try plugging an obd reader onto the car. There may be some fault codes stored in the ECU which might point you in the right direction.
Re: Having trouble.
Hi Guys
I found the pressure in number 2 and 3 cylinders was way down so a new gasket etc is ready to be fitted after getting the head skimmed.
