Good evening all
This is a very strange one, hoping some can help.
I have an airbag light on my polo from when I removed the airbag to replace the wiper stork after it failed.
Tonight I fought I would plug it in and clear the fault..!!! The OBD2 isn't in its normal place..?? I can't see it anywhere..!! Just the empty area where the port would normally be.
Any suggestions...??
Dave Ager
2015 polo 1.0 OBD2 port
davidager13
- Drives: 1.0 polo 2015
davidager13
Re: 2015 polo 1.0 OBD2 port
davidager13 wrote: Wed Oct 06, 2021 8:13 pm Good evening all
Dave Ager
- 20211006_180556.jpg (2.19 MiB) Viewed 1046 times
- 20211006_180613.jpg (1.59 MiB) Viewed 1046 times
please refrain from opening multiple topics. i've deleted three of them in the wrong place. i think one is enough.
the obd should be at the top right of your picture, in the square hole, it seems to be missing.
- Platinum Member
that was done probably to prevent theft. try reaching up in the hole and feeling any type of the connector is should be like in 99% of the cases. If there isa different type of obd try looking for the extesion cable in your car. they re-pin the original.
davidager13
Thank, found it zip tied up in the back of the dashboard with a Bluetooth reader plugged in to it.
Many thanks
Dave Ager
Many thanks
Dave Ager
CarbonChaos
A lot of the fiesta ST owners with keyless entry/start do this to prevent thieves smashing a window and accessing the obd port to start the vehicle
