Polo 6R - Useful Part Numbers
I will triple check it when I remove my hubs ( if any markings would be visible)
If you buy an OEM wheel bearing for the 6R, you'll get a SKF bearing in a VW box.
yes but that doesnt mean always that it's a first install part
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Can anyone confirm if "6R0971975A" is connector used for -- ignition starting? and do we get a female connector for this?
Yes it is, and no we don't.
ag69
Post by ag69 »
Thanks iichel.
wert90
Drives: 2011 Polo GTI
Post by wert90 »
Does anybody know if Polo R WRC springs are different than the 6R GTI ones? If so, do you know how much lower they are and the part code?
Does someone is the master cylinder from ibiza 1.4 tsi (2011) ( 23.8 / 23 FTE), does it accept the sensor ?
Seller has only one picture, and im not 100% sure.
Sure, i'm running the same 23mm
iichel wrote: Thu Oct 28, 2021 12:33 pm Sure, i'm running the same 23mm
Thank you iichel. What would be the real price for this part condition?
I don't think I paid more than 50 euros for it, with VAT and warranty
iichel wrote: Thu Oct 28, 2021 1:06 pm I don't think I paid more than 50 euros for it, with VAT and warranty
This guy doubled it, no warranty or the sensor.
Are there any other ones that are 23.8 and will fit polo ?
Edit: I agreed to buy, but in end It was the 22 FTE ( 22.2). So i guess ibiza 1.4 tsi is a no go.
Is it possible to retrofit AUX heater with analog ac controls ?
Is it hard to retrofit ?
6R0963235
You need climatronic for this
Thank you iichel
