Is this engine noise normal (sound file incl.)
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
When starting the car today I noticed as it’s cold it idles around 1k and I could hear a vibration noise that I don’t usually hear. https://filebin.net/dpl2b2t05pkgbqee
Listen to 3 seconds when I increase revs to 1k when you can hear it. It doesn’t happen at 700rpm, only from around 1k and then goes away above 1.1k.
Could it be the alternator, or loose underbody cladding which is vibrating at a certain frequency?
Harrihealey02
Drives: 2018 SEL
Re: Is this engine noise normal (sound file incl.)
I think I found what’s causing the noise. Is there meant to be a screw or fixture in this black hole?
Looks like a screw is missing in the black hole?
Harrihealey02
Drives: 2018 SEL
Update - found the cause.
If anyone experiences a metallic vibration noise under the car, it is the exhaust heat shield above the rear bend of the exhaust pipe where the heatshield spreads out towards the front of the fuel tank. I bended mine slightly and the noise stopped.
Harrihealey02
Drives: 2018 SEL
