6C Full LED Headlights number
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
Re: 6C Full LED Headlights number
And here some video of the strange behavior of the lights:
Read Blue.
ZahariGeorgiev wrote: Fri Nov 05, 2021 2:52 pm I will say this: ciclo you are a GOD man:)
Thank you so much for the support!
I just coming form the garage and enter this code: 3EB82BBF48A10000013806F13CEB9FD9FF80600F60053041200000020000
And YES, finally working front parking lights. They not work exactly well - when i put lighting switch to off position - parking lights are on at full power-->in these conditions they are not the parking lights, they are the "DRL", it is totally correct, when turn on auto position - they are not so bright, same is for parking light position and low beam (I am not really sure is this the right behavior)-->it is as it should be
, and they don't turn off when got blinkers on ---> New BCM coding 3EB82BBF48A10000013806F13CEB9FD9FF80600F600530C1200000020000.
Also low beams doesn't activate when i put the switch to low beam... only when the switch position is to off position first time i unlock the car. Still got the error for Non coded module and no basic settings in headlights, and of course cannot perform them - Coding rejected.Error31: Request out of range. Still flashing lamp and AFS error on dashboard.
This strange behavior of the lights is related to the faults shown in the diagnostic. Install new dimmer and retry basic setting for headlights and coding for unit 55.
You may need to parameterize the headlight control units, as iichel told you, I am not aware of these details for the 6C LED headlights, but it is something that I had to do at my wife's Golf.
About the auto lights - you did the wiring for me... wiring for gods.
For the HBA still waiting to figure out what and where new cables i need to connect and i am still stuck at the led headlights and leveling system ....
About that leveling system, i still dint change my original dimer switch with manually adjustable headlights. Got the new one 6Q0941334 and the question is do i have to connect new cables (if yes, maybe that's my problem) just to plug new one ? You don't need to install any new wire for this, please install the new Dimmer (yes or yes).
Your leveling unit may not be for Polo 6R, it looks like it is for T6.
Front ?
Front ?
ZahariGeorgiev
Those eror was from my first scan with non original VCP, after i got the original one, and clear and then check, only 2 left - no basic settings and control module not coded.
That new BCM code is prefect ( DRL are turning of when blinkers are on ), BUT everything is perfect until i start do drive the car and spin the steering wheel... last night i drive it and it was just terrible, only with DRL light at the night with ~ 140 km/h ... never gonna do that again until i fix my lights!
I change the dimmer, try again basic setting and coding the module, still no success... i am really not sure where is the problem
... at the module - 6R0907357C (brand new), the rear axle sensor (used, from Polo) or the headlights itself (used)
Please post a full scan with the Original VCP.
Where did you get the power for unit 55?
ZahariGeorgiev
Will send you email with the instructions from kufatec, which i followedVCP+K v8.8.0 16.08.2021 "Keep Hope Alive" Autoscan protocol 2021-11-06 17:18:59.367
Adressword : 01 (Engine Control Module 1} - J623 R4 1.6l TDI
VAG no. : SW: 03L906023AH HW: 03L906023D
SW version : 9979
# Coding : 00254016002400080000
ASAM: UDS, EV_ECM16TDI02103L906023AH 003014
DATASET:
>>> No faults found
Adressword : 02 (Transmission Control Module} -
VAG no. : SW: HW:
SW version :
# Coding :
ASAM: Communication error.
DATASET:
>>> Errors found
Adressword : 03 (Brakes 1} - J104 ESP8.2i front
VAG no. : SW: 6R0907379AJ HW:
SW version : 0001
# Coding : 210228E3416D00B6842D14EA82DA00421300
ASAM: TP1.6, CANT=7A3 CANE=7A0
DATASET:
>>> No faults found
Adressword : 04 (Steering Angle Sender} -
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>>> Errors found
Adressword : 08 (Air Conditioning} - J255 Climatronic
VAG no. : SW: 6R0907044H HW: 6R0907044H
SW version : 0812
# Coding : 00000
ASAM: TP2.0, CANT=300 CANE=33C
DATASET:
>>> No faults found
Adressword : 09 (Central Electrics} - J519 BCM PQ25 Max4
VAG no. : SW: 7E0937090 HW: 7E0937090
SW version : 0736
# Coding : 3EB82BBF48A10000013806F13CEB9FD9FF80600F600530C1200000020000
ASAM: TP2.0, CANT=300 CANE=338
DATASET:
SLAVE[1] Part number: 5K7955559B
RLS 290415 03 SW: 0059 HW:
Coding : 0228DD
SLAVE[2] Part number: 6R0959801R
J386__TSG_FT SW: 0903 HW: 6R0959801R
Coding : 18BC30
SLAVE[3] Part number: 6R0959802T
J387__TSG_BT SW: 0902 HW: 6R0959802T
Coding : 08BC30
SLAVE[4] Part number: 1K8959442
E221__MFL-MD9 SW: 0103 HW: 1K8959442
Coding : A40000
SLAVE[5] Part number: 6R0959811F
J388__TSG_HL SW: 0902 HW: 6R0959811F
Coding : 08BC32
SLAVE[6] Part number: 6R0959812F
J389__TSG_HR SW: 0902 HW: 6R0959812F
Coding : 08BC32
>>> Errors found
03D2 Left low beam headlamp bulb
03D3 Right low beam headlamp bulb
Adressword : 10 (Parking Assistance 2} - J446 PARKHILFE 8K
VAG no. : SW: 7E0919475J HW: 7N0919475
SW version : 0105
# Coding : 308101
ASAM: UDS, EV_VW75XParkAssis8K 001003
DATASET:
>>> No faults found
Adressword : 15 (Airbag} - J234 VW10Airbag008
VAG no. : SW: 6R0959655C HW: 6R0959655C
SW version : 0018
# Coding : 003038
ASAM: UDS, EV_AirbaVW10BPAVW250 A01001
DATASET: v00301656R0
SLAVE[1] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[2] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[3] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[4] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[5] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[6] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[7] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[8] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[9] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[10] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[11] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[12] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
SLAVE[13] Part number: N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> No faults found
Adressword : 17 (Dash Board} - J285 KOMBI
VAG no. : SW: 6JA920840A HW: 6JA920840A
SW version : 0607
# Coding : 140E01
ASAM: UDS, EV_Kombi_UDS_VDD_RM09 A04716
DATASET: -----------
>>> No faults found
Adressword : 19 (Gateway} - J533 GW-K-CAN TP20
VAG no. : SW: 7E0909901 HW: 7E0937090
SW version : 0736
# Coding : 002200
ASAM: TP2.0, CANT=300 CANE=32E
DATASET:
>>> No faults found
Adressword : 25 (Immobilizer} - J334 IMMO
VAG no. : SW: 5K0953234 HW: 5K0953234
SW version : 0607
# Coding : 000000
ASAM: UDS, EV_Immo_UDS_VDD_RM09 A03709
>>> No faults found
Adressword : 44 (Steering Assistance} - Error reading ID.
VAG no. : SW: - HW:
SW version : -
# Coding : -
ASAM: TP1.6, CANT=7A9 CANE=7A0
DATASET:
>>> No faults found
Adressword : 55 (Headlight Regulation} - J431 AFS-ECU
VAG no. : SW: 6R0907357C HW: 6R0907357B
SW version : 0050
# Coding : 0000000000000000
ASAM: UDS, EV_HeadlRegulVWLWRCC 002006
DATASET: V03600097E0
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> Errors found
507E54 (C107E54) Headlamps no basic setting (Scheinwerfer keine Grundeinstellung)
D01300 (U101300) Control module not coded (Steuergeraet nicht kodiert)
Adressword : 56 (Radio} -
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>>> Errors found
Really?ZahariGeorgiev wrote: Sat Nov 06, 2021 6:26 pm
I did EXCEPTIONAL wiring for you viewtopic.php?p=565798#p565798 for BCM Max and Auto lights installation (which got everything working perfectly
In that poor installation guide, the wires installation for leveling unit 55 is not contemplated. ... and it doesn't answer the question I asked you.
Where did you get the power/feed for unit 55?
I mean the yellow/black wire that can be seen in the original diagrams of LED Headlights for 6R and family.
https://drive.google.com/file/d/17JQ98q ... sp=sharing
As you can see, it goes from leveling unit 55 (J431) pin T26a/23 to a fuse. Please explain in detail how you made the fuse part.
Thanks for the autoscan, it will help us.
For some unknown reason to me, on any given day, I did an autoscan with VCP from my 6R. (I use VCP for more important matters than autoscans. For fast coding, readings or autoscan the best one is VCDS)
VCP+K v8.6.8 18.07.2019 BitterSweet Autoscan protocol 2019-08-10 21:02:02.907
Adressword : 01 (Engine Control Module 1} - J623 SIMOS10.22A
VAG no. : SW: 03F906070GD HW: 03F907309AJ
SW version : 5466
# Coding : 001100D6202400080000
ASAM: UDS, EV_ECM12TFS02103F906070GD 004007
DATASET:
>>> No faults found
VAG no. : SW: 6R0907379BE HW:
SW version : 0001
# Coding : 210228E3216D00B5842814EA84D300401700
DATASET:
>>> No faults found
Adressword : 04 (Steering Angle Sender} - G085 LENKW.SENSOR
VAG no. : SW: 6R0959654 HW: 6R0959654
SW version : 0070
# Coding : 01
ASAM: UDS, EV_LWSKLOVW25X 005001
>>> No faults found
SW version : 0711
# Coding : 00000
DATASET:
>>> No faults found
VAG no. : SW: 7E0937090D HW: 7E0937090D
SW version : 0762
# Coding : 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
SLAVE[1] Part number: 5K7955547
RLHS 220816 0 SW: 0106 HW:
Coding : 0428DD
SLAVE[2] Part number: 6R0959801BD
J386__TSG_FT SW: 8612 HW: 6R0959801BD
Coding : 0200A3
SLAVE[3] Part number: 6R0959802BF
J387__TSG_BT SW: 8612 HW: 6R0959802BF
Coding : 1000A3
SLAVE[4] Part number: 1K8951171A
DWA-Sensor 00 SW: 0103 HW:
Coding : 000000
SLAVE[5] Part number: 1K8951605B
LIN BACKUP HO SW: 9005 HW:
Coding : 000000
SLAVE[6] Part number: 1K8951171A
Coding : 000000
SLAVE[7] Part number: 1K8959442
E221__MFL-DC1 SW: 0103 HW: 1K8959442
Coding : A4FFFF
SLAVE[8] Part number: 6R0959811G
J388__TSG_HL SW: 1611 HW: 6R0959811G
Coding : 18BC32
SLAVE[9] Part number: 6R0959812G
J389__TSG_HR SW: 1611 HW: 6R0959812G
Coding : 18BC32
>>> No faults found
VAG no. : SW: 7E0919475AA HW: 7N0919475
SW version : 0212
# Coding : 308001
ASAM: UDS, EV_VW75XParkAssis8K 001012
DATASET:
>>> No faults found
Adressword : 15 (Airbag} - J234 VW10Airbag01M
VAG no. : SW: 6R0959655K HW: 6R0959655K
SW version : 0020
# Coding : 00314D
DATASET: v00305696R0
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> No faults found
VAG no. : SW: 6RD920870A HW: 6RD920870A
SW version : 0805
# Coding : 140E01
ASAM: UDS, EV_Kombi_UDS_VDD_RM09 A04727
>>> No faults found
VAG no. : SW: 7E0909901 HW: 7E0937090D
SW version : 0762
# Coding : 002204
DATASET: V03935277BN
>>> No faults found
Adressword : 20 (High Beam Assistance} - J844 FLA
VAG no. : SW: 7E0857511G HW: 7E0857511E
SW version : 0003
# Coding : 0404000000000000000000
ASAM: UDS, EV_HighBeamAssisAU316 001004
>>> No faults found
SW version : 0805
# Coding : 000000
ASAM: UDS, EV_Immo_UDS_VDD_RM09 A03710
>>> No faults found
Adressword : 2E (Media Player Position 3} - J650 SG EXT.PLAYER
VAG no. : SW: 5N0035342F HW: 5N0035342F
SW version : 0530
# Coding : 010100
ASAM: TP2.0, CANT=300 CANE=4EC
DATASET:
>>> No faults found
Adressword : 37 (Navigation} - J0506RNS-MID
VAG no. : SW: 1T0035680L HW: 1T0035680C
SW version : 5274
# Coding : 04000442040000A10001
ASAM: TP2.0, CANT=300 CANE=4D8
SLAVE[1] Part number: 1T0919859B
EU West V15 SW: 8515 HW:
Coding :
>>> No faults found
VAG no. : SW: - HW:
SW version : -
# Coding : -
DATASET:
>>> No faults found
Adressword : 55 (Headlight Regulation} - J431 LWR-ECU
VAG no. : SW: 6R0907357 HW: 6R0907357
SW version : 0070
# Coding : 0112000001000000
ASAM: UDS, EV_HeadlRegulVWLWRPt 001004
DATASET: 6R0036v____
N/A SW: N/A HW: N/A
Coding : N/A
N/A SW: N/A HW: N/A
Coding : N/A
>>> No faults found
Adressword : 56 (Radio} - J0506RNS-MID
SW version : 5274
ASAM: TP2.0, CANT=300 CANE=4DA
Coding :
>>> No faults found
Adressword : 65 (Tire Pressure Monitoring 1} - J502 RDKBERU30
VAG no. : SW: 3AA907273F HW: 5Q0907273
SW version : 0011
# Coding :
ASAM: UDS, EV_RDKBERU30 005005
>>> No faults found
Adressword : 77 (Telephone} - J412 TELEFON
VAG no. : SW: 7P6035730L HW: 7P6035730L
SW version : 3200
# Coding : 0501000000010110
ASAM: UDS, EV_UHVNA 002720
DATASET: 7P6035730L
>>> No faults found
I'm trying to figure out what's going on in your 6R, like bad installation or parts compatibility ...
ZahariGeorgiev
About those communications errors for Adressword : 02 (Transmission Control Module) and Adressword : 04 (Steering Angle Sender), when i make autoscan with VCDS, no problems (No Errors), only with VCP no communication.
For the power/feed for unit 55, i have to disassemble my car again and see where is it connected, because the wirings was connected by one local electrical guy, and I don't know where he connected them. When i unplug the connector from unit 55, the headlights don't go up and down anymore when i start the car and the low beams are active. When plugged back, they are go up and down ... and i am not sure is it about the power/feed or some faulty unit or maybe f****d up headlights..
ZahariGeorgiev
Just come from the garage and i found this:
The other end of the T26a/23 is connected here in the fuse box, but i cannot see which number is it
- Inked20211107_152914_LI.jpg (2.48 MiB) Viewed 3067 times
Ok, thanks for the image and the effort, I appreciate it.
Clear up one of my doubts about it. The wire is in one of the possible correct places, +15, ... in the fuse box that you show us the +15 power bar can be seen.
Possibly here:
I'll tell you some more things shortly ... I'm looking for information on my laptop.
Stay tuned... if you want...
Possibly here:
Your DSG gearbox (02) and G85 Steering angle sender (04) are working fine, but your G85 (6Q0959654D -ESP-) may be out of date. Your 6R is a MY 2011, and the G85 was upgraded for MY 2013 onwards to 6R0959654 -ESP-.
Perhaps this could be one of the causes of poor communication between units and it could be that the behavior of your LED headlights in the video in which you turn the wheel could be influenced in this regard. Well, this is just a guess, so it will be relegated to another time.
As for the behavior of the LED headlights when they go up and down when starting it is correct, which means that your new 55 unit does its job, but the basic setting and coding must be done.
- For the basic setting it may be necessary to enter a security access (SA) before doing it.
Try with, 96428, or 20103.
- For coding try to enter the Bytes one by one, not the entire coding at once.
ZahariGeorgiev
Thanks for the answers,
Tomorrow I will take VCDS from a friend and try these security access codes.
ZahariGeorgiev
Still no success
Now i am searching for another used 6R0907357C from 6R with Bi-xenon, and see if there will be a difference.
Btw: Is it "5Q0907357" compatible for 6R?
Only for POLO 6C
ZahariGeorgiev
I have to buy a new module, couldn't find used one. Can you tell me exactly what is the number of that headlight range module suitable for 6R?
