KamilPL
Drives: Seat Ibiza 6j1
Post by KamilPL »
ciclo wrote: Wed Nov 10, 2021 5:11 am
KamilPL wrote: Tue Nov 09, 2021 7:53 pm ...
Cyclo your new coding :/
False, that is not the BCM coding that I provided you, my BCM coding here :arrow: viewtopic.php?p=585587#p585587
I said it was better not to touch the coding ... I don't know why I was ignored in this regard. :lol:
It does not matter, I am very used to the fact that due to multiple circumstances people say things incorrectly ... nothing to worry about! :)
To find out what's going on with your DRLs and side/parking lights, try these new BCM codings:
1-
7C8829F88861010001200EF06EEB9EC85FC067FF608D20C1200000030000
2-
7C8829F88861010001200EF06EEB9EC85FC067FF608C20C1200000030000
and tell us the results to know what is the next step to take.
Regarding the reversing light and rear fog light:
Some diagnostics were already disabled in your BCM coding, which may be the reason why the Autoscan does not show any faults, but I would like to remind you that diagnostic failures arise when those lights are activated.
If there are no faults in your instrument cluster, or in the diagnosis, and you are happy that way, leave it as original, but you may lose the diagnosis of said lamps in case the bulbs fail.
Work properly: When everything works correctly.😄
FC8829F88861010001200EF06EEB9EC85FC067FF608D30C1200000030000 (All candle lights, parking lights dim instead of drl)
FC8829F88861010001200EF06EEB9EC85FC067FF608D20C1200000030000(Drl flashes, no parking and road drl after switching on the dipped beam)
FC8829F88861010001200EF06EEB9EC85FC067FF608C20C1200000030000 (Drl flashes, no parking and road drl after switching on the dipped beam)
Light switch position:
- 0 = LED module full brightness. Drl.
- Parking = Parking lights ON, LED module dim brightness.
- Low Beam (dipped beam) = Low Beam ON, Parking lights ON, LED module dim brightness.
- AUTO:
Lights ON = Low Beam ON, Parking lights ON, LED module dim brightness.
LIghts OFF = LED module full brightness. Drl.
KamilPL
Post by KamilPL »
- 0 = full brightness of the LED module (drl) + parking full brightness
- Parking = Parking lights on, parking brightness dim + full brightness drl
- Low beam (low beam) = low beam on, parking lights dimmed, full brightness of the LED module.
- AUTO:
Lights on = dipped beam on, parking lights dimmed on, LED module full brightness.
Where is problem? I don’t know 😪
KamilPL
Post by KamilPL »
But, what BCM coding are you referring to?
Maybe it is better that you take pictures in a garage and in daylight conditions, because due of how your 6P halogen headlights with LED drl are built, it is possible that everything is working well...
Please show with pictures what's the problem. Make a comparison.
KamilPL
Post by KamilPL »
ciclo wrote: Wed Nov 10, 2021 12:59 pm But, what BCM coding are you referring to?
This coding works best, however there is a problem instead of the drl it reduces the power of the parking lights
What is the operation of your rear Parking lights in these conditions ...
KamilPL
Post by KamilPL »
Due to the behavior of the lights, it seems that, maybe, the two new cables that go to each headlight have been swapped of position in the T10 connector.
It is impossible to understand with total clarity the images if you do not add a comment with each one of them.
I am not an expert on halogen headlights, and even less so on SEAT halogen headlights.
KamilPL
Post by KamilPL »
ciclo wrote: Wed Nov 10, 2021 1:20 pm It is impossible to understand with total clarity the images if you do not add a comment with each one of them.
1.3 position 0
2 parking position
KamilPL
Post by KamilPL »
ciclo wrote: Wed Nov 10, 2021 1:14 pm Due to the behavior of the lights, it seems that, maybe, the two new cables that go to each headlight have been swapped of position in the T10 connector.
I do not have physical access to the car, the electrician says that when I replace the cables, the DRL goes out and throws an error
KamilPL
Post by KamilPL »
ciclo wrote: Wed Nov 10, 2021 1:04 pm What is the operation of your rear Parking lights in these conditions ...
Rear parking lights sparkle at full power
KamilPL
Post by KamilPL »
By replacing the cables T10 / 4 -> T10 / 10. LED lights + dimmed parking, parking with full power, the LED does not light at all
I have a feeling that the procedures are not being carried out the right way. Installation and coding are paired in a deep love, if any change is made in the electrical installation it must also be done in the coding.
I think the real problem is that there are three of us involved in this story, and there is no fluid communication between some of those involved.
What if we change the title of this thread:
The incredible tales of doing whatever I want.
Starring: the electrician, Kamil@what's happening.com, and the usual ciclOMFG.🤭
