Re: iichels Polo 6R 1.6TDI DSG Bluemotion --> OEM++ R-Line conversion
I am happy and proud to announce that the department of motor vehicles has approved my new engine.
They were very impressed with the build and all measures taken to promote safety and performance in such a little car.
The roller bench showed the power to be increased to 200bhp (150kW) and 412Nm.
- Platinum Member
amazing results and no smoke, thumbs up
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Congratulations
Waiting for a video with new exhaust
- Shadow109
- Drives: Vw t5.1 2013
Nice job
Congratulations
Congratulations
You're not going to be impressed haha. It's very silent.
patil
iichel wrote: Wed Nov 10, 2021 3:31 pm
Where you gonna use all this fire power
Congrats iichel
New mod: VW Scirocco 1K8 addition instruments. 1K8 919 527.
Connection is very simple: viewtopic.php?t=70404
Unlocked 1-100 kmh timer and 1/4 mile timer via EEPROM
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 HW: 1K8 919 527
Component: ZUSATZANZEIGE H08 0003
Coding: 05
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 75B71C952543D363847-8020Code: Select all
Friday,12,November,2021,16:59:46:11868
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4604.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ6RZBY123456 License Plate:
Mileage: Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 37 3C 44 47 55 56
61 65 69 B9
VIN: WVWZZZ6RZBY123456 Mileage:
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 KE HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000 CVN: 3BB1FB41
Coding: 00254036032401080000
Shop #: WSC 00066 000 00237
ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
ROD: GV_ECM16TDI021VW32X.rod
VCID: 73B3228D2B37CD53AA3-8026
VINID: 9E69EAAAA1A2A92A42085185103550A70A
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412500C5841A146E825500521504
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89B32EB-805A
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF617356B-8062
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B5F1-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBFA8EB3400B33807F1FFCB9FF0FF8067EFE00D78D031E400030800
VCID: 2B03FAEDB307D593223-807E
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195151
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 65
Mileage: 1 km
Date: 2021.11.12
Time: 16:54:53
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC9B395-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
Shop #: WSC 12345 123 12345
VCID: 3333E28D6BB78D536A3-8066
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042204
VCID: 688945E162713E8B0F1-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
VCID: 2E05F3F98095A0BB05D-807A
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9B195-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9B30EB-807A
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 H
Component: RNS-MID H26 6276
Revision: AB001001 Serial number: VWZ6Z7P1950254
Coding: 00070002010000A10001
VCID: 3635DB997845987B4DD-8062
Subsystem 1 - Part No: 1T0 051 859 AS
Component: EU West V17 8557
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B30EB-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB703E0F-802C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8BCF1-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1BA95-806E
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030F0A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 E HW: 1K0 907 383 E
Component: Anhaenger H07 0080
Revision: 3A002002 Serial number: 00000116932377
Coding: 0100000100000000
VCID: 2F3BEEFD871FA9B30EB-807A
Coding: 05
End----(Elapsed Time: 02:21, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)------ ag69
Iichel — assume you won’t mind
[youtube] https://youtu.be/Dmi9-hSxnWs[/youtube]
I dont mind but i dont understand what youre trying to tell us
- ag69
Just a pictorial reference to you mod
Ah yes, the mod i referenced above your post hahaha
Santaclaus is early this year:
OutofOffice
Hi iichel,
Need any relay between BCM and Headlight low beam, High beam, Fog lamp or can we connect directly. I am upgrading my skoda rapid BCM 86 to 89. So, need your suggestion.
I don't know. i don't know your car, your configuration, your headlights, etc. It is not possible to tell now.
