giannis20vt
Posts: 425 Joined: Sat May 15, 2021 6:23 am
Post
by giannis20vt » Wed Dec 29, 2021 6:45 am
Finally, yesterday i made the cluster swap.
The new cluster working fine, but i have some errors when i scan with VCDS.
Address 17: Instruments Labels: 5G0-920-XXX-17.CLB-SRI3
Control Module Part Number: 6C0 920 740 C HW: 6C0 920 740 C
Component and/or Version: KOMBI 201 1420
Software Coding: 072409002180000801882A011000000000000000
Work Shop Code: WSC 00788 648 00255
ASAM Dataset: EV_DashBoardVDDMQBAB 009046 (VW26)
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 224B5F8F35CFF89BF5-8076
3 Faults Found:
16777028 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 254
Mileage: 63407 km
Date: 2021.12.29
Time: 06:41:15
16776960 - Databus
U1121 00 [009] - Missing Message
Fault Priority: 2
Fault Frequency: 1
Reset counter: 254
Mileage: 63407 km
Date: 2021.12.29
Time: 06:41:12
16776961 - Databus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 254
Mileage: 63407 km
Date: 2021.12.29
Time: 06:41:12
Any ideas about those errors ?
Posts: 1305 Joined: Thu Feb 06, 2020 7:57 am
Post
by amer6R » Wed Dec 29, 2021 9:57 am
You heed Hex V2, or ODIS to read the faults.
giannis20vt
Post
by giannis20vt » Thu Dec 30, 2021 10:02 am
I will do the scanning with ODIS probably today and i will upload the results.
giannis20vt
Post
by giannis20vt » Tue Jan 04, 2022 4:07 pm
Finally, i scan test from a shop:
Tuesday,04,January,2022,16:27:14:45969
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.8.0.1 HEX-NET CB: 0.4543.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: WVWZZZ6RZGY308378 License Plate:
Mileage: 63422km-39408mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378 Mileage: 63422km-39408miles
Address 01: Engine (J623-CHYB) Labels: None
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000
Coding: 01110012020400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AA_VW26.rod
VCID: 658256CF64D2576E19-8030
Readiness: 1110 0001
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08512057160424
Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
Shop #: WSC 49716 005 1048576
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 373ECC878EFE15FE7B-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1605161B-0418
Coding: 200000000000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26_VW26.rod
VCID: 1F0E0427060E4DBE93-804A
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 6C0 937 087 C HW: 6C0 937 087
Component: BCM PQ26 Me4R H08 0087
Serial number: 006088052444
Coding: 000008404053005B4F844000400703000000580051010000000000000000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005_VW26.rod
VCID: 2E10E9E371A4D43628-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 801 DG HW: 6R0 959 801 DG Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU012051661335260
Coding: 0000A0
Front Passengers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 DL HW: 6R0 959 802 DL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU030041661212448
Coding: 1000A0
Drivers Door Rear Control Module:
Subsystem 3 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661198823
Coding: 0000A0
Passengers Rear Door Control Module:
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU002051661233279
Coding: 1000A0
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00A 002 0380
Revision: -------- Serial number: 003TH006KLNX
Coding: 88C0C000000000005C000000000800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A38D5B3BDEC089684-806E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 820 305 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A520BDDD2520R
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 821 104 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A5209A1C310AF
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1FACC94822/
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 152 204 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D61520W
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 070409002180000811882A011000000000000000
VCID: 22080DD3357C6056BC-8076
3 Faults Found:
U1110 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 63422 km
Date: 2022.01.04
Time: 16:25:17
16776960 - Databus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 63422 km
Date: 2022.01.04
Time: 16:25:14
16776961 - Databus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 3
Mileage: 63422 km
Date: 2022.01.04
Time: 16:25:14
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H08 0087
Revision: -------- Serial number: 006088052444
Coding: 01000008200A640071000000000000000001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_VW26.rod
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PG5Q1139
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6D922EEFBC226F2E51-8038
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 6C0 035 888 B HW: 6C0 035 888 B
Component: MU-E--ER 851 6490
Serial number: 19041600012060
Coding: 026200003C00000041110001010000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 2B16E0F742B6A11E0F-807E
1 Fault Found:
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 3
Mileage: 63422 km
Date: 2022.01.04
Time: 16:25:46
Voltage terminal 30: 12.3 V
End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.2V)-----------
3 errors at Address 17: Instruments (J285)
Since i swap the cluster, i can't synchronized the remote control keys. I don't know if it is relevant or not.
giannis20vt
Post
by giannis20vt » Fri Jan 14, 2022 8:37 pm
Hi, i really need your help.
Today i was at a shop which has on line connection with ODIS ...
We were trying for 3,5 hours to adapt the remote keys. We even put back again the old (original) cluster, but still the error message was the same.
The remote key adaptation was not successful.
The following fault occurred
0χ31
Request out of range.
So now i have my old cluster on the car and no remote keys. I am desperate.
Here is the full scan i made it afterwards with my VCDS cable.
Saturday,15,January,2022,08:10:09:00009
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY308378 License Plate: KIK3070
Mileage: 64333km-39974mi Repair Order:
VIN: WVWZZZ6RZGY308378 Mileage: 64333km-39974miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Revision: 33H20000
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 65C104936461CFA350-8030
Readiness: 0100 0001
VCID: 377D9EDB8E4D8D3332-8062
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F4D567B06BDD573DA-804A
Shop #: WSC 131071 1023 2097151
ROD: EV_BCMA0_005.rod
VCID: 2E53BBBF71174CFB61-807A
Driver door control module:
Coding: 0000A0
Front passenger door control module:
Coding: 1000A0
Coding: 0000A0
Coding: 1000A0
VCID: 3A7B87EFBD5F905BCD-806E
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 730 G HW: 6C0 920 730 G
Component: KOMBI 101 1420
Coding: 0724090021000008110808000000000000000000
VCID: 2541449324E10FA390-8070
2 Faults Found:
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
Fault Priority: 4
Fault Frequency: 3
Reset counter: 26
Mileage: 64326 km
Date: 2021.12.25
Time: 00:05:05
9603840 - Incorrect Key Programming for Remote Control
B128B 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 64326 km
Date: 2021.12.25
Time: 00:05:30
ROD: EV_GatewA0Lear_013_VW26.rod
Coding: 000700
VCID: 6DD17CB3BC91F7E318-8038
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2B55B2AB420539D346-807E
End-------------------------(Elapsed Time: 02:15)--------------------------
giannis20vt
Post
by giannis20vt » Fri Jan 21, 2022 10:34 am
And just like that, without any reason the keys started working again. I didn't do anything.
I will do a VCDS scanning later to see if there is any new error codes, or something new in general.
Posts: 6695 Joined: Fri Nov 14, 2014 2:14 pm
Post
by iichel » Fri Jan 21, 2022 10:47 am
would be interesting to see if your 2 errors in your instrument cluster have disappeared
giannis20vt
Post
by giannis20vt » Sat Jan 22, 2022 5:21 am
Update:
The errors are still exist. erased them but they reappeared immediately.
Both of keys working fine !!!
So far i didn't managed to have a successful swap of the cluster instrument. But at least i have my remote keys working again.
Maybe i have to swap first the BCM module, my original is the most simply BCM of all Polos 6c. (6C0937087 C)
giannis20vt
Post
by giannis20vt » Wed Aug 28, 2024 7:43 am
Update.
I managed to make the change successfully, it's been a while, I forgot to update the thread.
First I changed the BCM with 6C0937090E and then I changed the cluster, with success this time. I don't know if it was meant to be with this series, it just happened to me.
