6C Full LED Headlights number
Re: 6C Full LED Headlights number
What is the partnumber of the new bcm?
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
7E0937090E is the new one
i'm pretty sure you need to learn keys with odis on that one
ZahariGeorgiev
The keys are not the main problem here, the car is completely undrivable when is getting dark...and now is getting dark very early
At the firs start of the car, everything is working perfect, and then when I turn the steering wheel and the low beam are getting off and on randomly, but mostly off. And that's why i start to think that the problem is related with this error:
Adressword : 04 (Steering Angle Sender} -
VAG no. : SW: HW:
SW version :
# Coding :
ASAM: Communication error.
DATASET:
>>> Errors found
VAG no. : SW: HW:
SW version :
# Coding :
DATASET:
>>> Errors found
Do you have any other errors in your bcm or other modules?
ZahariGeorgiev
Install a new steering ring, like the one of my 6R.
You will need to purchase the full set, ring with stalks, as the new ring is not compatible with your current stalks.
Look on eBay, there were always good deals.
You will have to do the G85 basic setting, in ABS unit.
For 6C headlights, the parking/side lights must be parameterized in the BCM with VCP. (D2 --> firegrafik thread)
ZahariGeorgiev
Hello Fernando,
Are you talking about this : 6R0959654?
And for the stalks i already purchase new one - 7E0953507B (the one with the returning spring) preparing it for HBA.
For the parking lights i already parameterized my BCM, and have no issue with them anymore!
Yes, it is the correct ring for your 6R and those 7E0 stalks.
You will need to do the wiring adaptation for HBA (BCM-T41-Fusebox) for those 7E0 stalks to work properly. (Even if you don't install the HBA mirror)
+ coding/adaptation.
https://drive.google.com/file/d/0B2nv91 ... B_5OxyUh0Q hmm ... in your case
https://drive.google.com/file/d/0B2nv91 ... 57A3T1S71w
https://www.uk-polos.net/viewtopic.php?p=503577#p503577
ZahariGeorgiev
One again BIG THANK YOU for shared information! My next project with HBA will wait till i solve this issue with the flashing low beams, i already bookmark those link with instructions and just cant wait to fulfill them
I found this on ebay: https://www.ebay.com/itm/313778073662?h ... SwkP9hp9Bo
And I think it will work for me, what do you think?
And here is one picture from this morning:
I also noticed that there is a new menu in MDF - LIGHT / VISION and in the submenu - Travel Mode, and watch:
[youtube]https://youtu.be/sy4n1SW1wCQ[/youtube]
- 20220106_105334.jpg (2.73 MiB) Viewed 2418 times
patil
Your 6R looks stunning with LED headlights and those alloys
Travel mode: When you cross borders from LHD to RHD country, travel mode can be used to avoid glaring to oncoming traffic. AFS unit dips the low beam a little when travel mode is activated.ZahariGeorgiev wrote: Thu Jan 06, 2022 12:03 pm
Welcome to India(RHD) to try travel mode.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
These dials looks different speed increment of 10 till 80 and then 20ZahariGeorgiev wrote: Thu Jan 06, 2022 12:03 pm I also noticed that there is a new menu in MDF - LIGHT / VISION and in the submenu - Travel Mode, and watch:
RPM in 10,20....
I think your best option would be this:ZahariGeorgiev wrote: Thu Jan 06, 2022 12:03 pm
https://www.ebay.com/itm/254940198224?e ... SwdndgdV9S
These 7E0 levers without CCS would be very useful for you in case you want to move the CCS buttons from the lever to the buttons on the multifunction steering wheel (with the CCEmulator).
viewtopic.php?p=588216#p588216 (ciclin)
viewtopic.php?p=588051#p588051 (iichelin)
+1patil wrote: Thu Jan 06, 2022 3:58 pm Travel mode: When you cross borders from LHD to RHD country, travel mode can be used to avoid glaring to oncoming traffic. AFS unit dips the low beam a little when travel mode is activated.
Welcome to India(RHD) to try travel mode.![]()
My dear doctor, thank you for your offer, but those of us who start to need glasses to see up close no longer appreciate these subtle differences, we only see big illuminated spots
ZahariGeorgiev
Thank you patil, a lots of people when they see it and ask me what kind of polo is that, and also they think it is Golf 7patil wrote: Thu Jan 06, 2022 3:58 pmYour 6R looks stunning with LED headlights and those alloysI can also see an old generation VW in background
When get dark i test that "travel mode", AFS unit lowering the low beam a little bit when activate it and start flashing yellow lamp for a few seconds and then its gone.
ZahariGeorgiev
These dials are from seat toledo, with 6C coverag69 wrote: Thu Jan 06, 2022 4:38 pmThese dials looks different speed increment of 10 till 80 and then 20ZahariGeorgiev wrote: Thu Jan 06, 2022 12:03 pm I also noticed that there is a new menu in MDF - LIGHT / VISION and in the submenu - Travel Mode, and watch:
RPM in 10,20....
