Electric Windows both stopped Working
imawheel
Drives: VW POLO 2006 1.4
Post by imawheel »
I'm not sure if this is the right forum, I have a Polo 2006 1.4, I thought it was a mk4 from looking online, but it doesn't appear to fit the correct year range looking on here.
Anyway, both front windows stopped working at the same time (I don't have electric rear windows), I've been told it's probably a fuse issue or a relay. I checked the window fuses in the driver's side of the dash and they both are fine. I'm not sure how to locate or access where the relay for the electric windows are though. If anyone can help with that it'd be great! Also, how do I test the relay? Can I just swap it with any other one in there (that looks the same) and see if it works?
Thank you!!
