KamilPL
Drives: Seat Ibiza 6j1
Post by KamilPL »
If I buy another car and I want to play with the updates, I will give it up 😂🤣
Cyclo thank you again ❤️
Ibiza 6j update finished, I consider the topic closed 🔒
Extra: :)
It is possible to change those original yellowish W5W T10 filament bulbs dedicated to the Parking / Side lights for some white LEDs to make the 6P headlights look more pleasant when the Parking or Side lights are on.
And since these lights are under BCM control in your Ibiza 6J, Byte27 Bit2 must be enabled. (07 HEX in your case)
4000ºK or a little less is ok if the headlights bulbs for low beam are halogens with a white tendency (your case).
If you buy with 6000ºK or more, your halogen bulbs with a tendency to be white will look yellowish.
Model, example:
KamilPL
Post by KamilPL »
ciclo wrote: Sun Nov 21, 2021 2:57 am Extra: :)
Model, example:
Hi Cyclo, I have to ask you for help again, I have a problem not related to the upgrade to BCM MAX.
The washer fluid pump stopped working. when connected to the battery, it works.
The wipers operate normally, pulling the lever causes the wiper to move, and you cannot hear the pump.
I took off the bumper, the cube stripped on the yellow / green wire, no electricity, blue / black appears when the pump is turned on the rear window (the pump does not work)
tomorrow I have a departure 700km and the weather is like this. that after a few km the glass is as dirty as a pig ... :(
KamilPL wrote: Thu Dec 23, 2021 6:18 am ... the cube stripped on the yellow / green wire, no electricity, blue / black appears when the pump is turned on the rear window (the pump does not work) ...
Please write this part in Polish using the common language (please use the punctuation marks correctly, please construct the sentences correctly), maybe I can understand it better if I use the translator. Post images if possible. Thanks a lot.
KamilPL
Post by KamilPL »
1. yellow / green is + for the windshield and - for the rear
2. black / blue is - for the windshield and + for the rear
No current (+) to windshield washer
No ground (-) to rear window washer
Cable # 1 (Yellow-green) damaged? no error in BCM ??!!
KamilPL
Post by KamilPL »
ELSA in the Polish language version helped :)
I'm going to check SC18 which according to the diagram is a resistor for +/- yellow / green cable :)
SC18 is a 7.5 Amp "fuse", it may have blown, which is the most likely cause as per your indications.
Windshield washer fluid may be frozen and this triggers subsequent malfunctions when you try to use the windshield washer fluid system.
Try using a windshield washer fluid for those weather conditions.
If you permanently press the lever of the windshield washer fluid trying to get the fluid out and it does not come out, in the best case the SC18 fuse will blow, the next thing will be the breakage of the V59 pump.
Mathias
Drives: 6r
Post by Mathias »
ciclo wrote: Thu Dec 23, 2021 8:46 am
Hello.
I'm new here.
Ciclo - I have tried using your guide on BCM MAX upgrade for a 6R on a Beetle 5C. Including OEM Xenon install.
Is this possible to do without auto light Switch as the car does not has the function?
If yes. Can you guide me on what wires I need to make/reroute from BCM/Lightswitch/Fusebox
Best regards and thank you.
ps. I can not yet send PM to you.
KamilPL
Post by KamilPL »
Mathias wrote: Sun Dec 26, 2021 8:18 pm
Hello.
I'm new here.
Mateusz Mistrz Cyclo po mojej ibizie pisał gdzieś w poście że kończy z robieniem za kogoś od A do Z aktualizacji BCM i zablokował możliwość pisania na PW. musiałbyś musieć zmienić szybe i dołożyć czujnik, aktualizacje okablowania, żeby móc korzystać z funkcji AUTO
Hi KamilPL
With all the love in the world, I would like to remind you that the language used in this forum is Only and Exclusively English, preferably UK English, which is the one we all understand best. Australian English is also very, very, well, so I allow both forms of expression ... :lol:
My favorite is US English because it is the most fun ..., but the more correct the better, so it is best to use UK English.
Thank you.👍
BTW1: I already indicated to Mathias (DK) what he would have to do.
BTW2: what happened to your windshield washer fluid pump?
- It is always good to do a report on how the problem was solved when asking for help from others, so that everyone can benefit from this solution.
Happy New Year 2o22!🎉🥂
adamswiatek
Drives: Seat Ibiza
Post by adamswiatek »
Hi. Kamilu updated us that the problem was with fuse nr. 18 which was burned.
Thanks Kamil
adamswiatek
Drives: Seat Ibiza
Hi forum members.
I would like to write here about my problem with car.
I have Seat Ibiza 2013 , today I recognised I lost break light at all. I checked fuse nr 20 which is ok and scanned car wirh Vagcom which shown no errors.
I heard it could be break light sensor issue but I can not locate it close to break pedal.
Does anybody know where the sensor is located and how to replace it?
Thanks a lot
Hello, maybe this can help...
(RHD)
adamswiatek
Drives: Seat Ibiza
Thank you so much Ciclo.
Probably it is broken becouse I don't have brake lights at all.
I am very appreciated. 🙏🙏🙏
If you learn to use this :arrow: ETKA online you can locate the exact reference number of the brake light switch for your Ibiza after checking that this switch is present in your car.
For example (2013)
https://www.google.com/search?q=5G06984 ... 6&dpr=1.38
If you buy the brake light switch in a store near you where you live they will give you the exact reference number if you provide them with the VIN.
