Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
Post by vento2013 »
iichel wrote: Fri Jul 17, 2020 5:13 pm Mine also came with a chrome finish but I swapped it with a frame from a Polo 6C :mrgreen:
@iichel
Found 6C infotainment system trim in Japan. And I Got it . Its a used one. But in super clean condition. :)
6C0 858 071 A
this trim came in Japan Polo GTI.
Adding picture
Just some casual cleaning and a new seat connector 4F0972575B + 4F0972483B
Clean and clear. Perfect. 8) 👌
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Polo 6C / PQ35 Dynamic Chassis Control (parts):
Springs: 2x 6C0411105C + 6Q0511115CM
Front dampers 6C0413031BS + connector 6C0972483
Rear dampers 6C0512037BN + connector 1J0973702
Module 3C0 907 376A + connector 6Q0 973 047
Sensor left rear 3C0 907 503, to replace 1T0 907 503 on the AFS sensor + connector 4B0 973 712A
Sensor left front 3C0 412 521 B + connector 4B0 973 712 A
Sensor right front 3C0 412 522 B + connector 4B0 973 712 A
Accelerometer left front 1K0 412 575 + connector 4B0 972 883
Accelerometer right front 1K0 412 576 + connector 4B0 972 883
Accelerometer left rear 3C0 616 575B + connector 4B0 972 883
Or use 2x 3C0 907 651 and 1x 4F0 907 651 + connector 4B0 972 883
wiring:
basic settings:
other things to remember:
Super...😲
I've been searching a bit, and came on topic of battery vent tube ( tube that vents hydrogen gas from the battery - in case of battery being located inside of the car or in front of air cabin intake). And
I've been looking at the pics of your retrofit and cant spot it 🤔. Did the VAG skip on this detail? What do you think, its good from safety and rust prevention aspect
Yes there is no such part in the Polo 6r that I am aware of
What VW model are the seats you have chosen? Passat CC? or will it be an in depth mod?
Passat B7 cc with some upgrades like ventilation and massage on both sides. Parts will come at the end of the week to finish it.
I will post some more info later on the details. Even Slavik was impressed.
I'm also interested into seeing this mod. If you could post an image of how you bolted the seat to the chassis. I saw someone use a bolt and a nut...
Work in progress...
Passat CC 3C ergo comfort seats 'Frankenstein'
Passat CC base with full electric seats
Passat B7 module for the driver
Passat B8 airbags
Custom seat heating to circumvent 5K0 module
Passat B8 memory button module + wiring for driver seat
Arteon 3H backrest + module + wiring loom for passenger for massage function + 1Z0... 3-pin button
Oem seat ventilation 3C0963... Added
T17 wiring layout from 3G0 scheme
Now just need to wait for some parts from the dealership and align the holes in the seats with the holes in the car
Logically, you had already done a thorough study on these seats when you asked me about the terminals of the T17 connector, everything now makes clear sense.👍
Without having investigated this matter, I suppose that the holes for fixing these seats will need your creativity, always keeping in mind what is related to safety.
Although I don't need to say it, Thank you very much for sharing!
Good luck with this upgrade/improvement. 8)
