Passat Airbag
Note:
Crystal clear.
Remembering a few things for friends:
2GM880201G ... the aribag shown above.
Horn: Blue/white from T5/4 and not from T12/8... and the two Earth terminals. Perfect! :)
The page where the following link is found is mainly dedicated to the original CCEmulator (2019 version) ...
viewtopic.php?p=564515#p564515
6R (PQ25*). Horn via T12/8.
Before post the images of the final result of the installation of the steering wheel from the Passat 8.5 in my 6R I would like to comment on the two possible ways in which the horn can work *according to equipment -type of airbag, airbag wiring, model of multifunction buttons, steering ring, CCEmulator version-.
There are two possibilities to get the horn signal to the BCM:
1- Via LIN dedicated to buttons control unit (integrated in the buttons).
T5/4 IN :arrow: T5/3 OUT, previously posted in images and diagrams. viewtopic.php?p=588049#p588049
2- Direct connection via steering ring. Normally used for steering wheels without multifunction buttons from the factory.
T12/8.
Airbag wiring modification. Add a new wire (if needed).
Take out the T5/4 wire (blue/white in this case) and cut the terminal. Add the correct terminal, MQS.
If you own a pre-facelift Amarok you should check this more closely, the diagrams for Amarok say it is T12/7 - T41/11 - T73a/29.
Insert in the appropriate place.
Add a new wire if necessary.
Warning!
If you install the CCEmulator, you must remove the wire T5/5 to T12/8 from the aribag wiring to avoid possible conflicts or malfunctions.
Based on the experiences from other users who requested help to solve their problems due to the equipment used in their vehicles. :)
POLO 6R. New MFSW from Passat 8.5 + CCEmulator 2021!
Why in the first image I do not have the upper cover of the steering column installed? Because it allows you to slightly correct the central position of the levers (stalks).
Note: Once corrected, the basic setting of the G85 sensor is made. Previously you can find the angle of the G85 sensor in the measurement values. (0.0º +/- 5.0º)
This way it is achieved that both the steering wheel and the levers are in a perfect and centered position. 8)
Buttons.
All buttons work perfectly.
Very nice to recover the MUTE function. 👍😄
Horn.
Or in case the button control unit is powered with +30. (6R -> 2010/2011)
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/_Ql7nufcn ... autoplay=1 👈😆 ... how about we make a haptic/capacitive horn? 😁
VCDS Autoscan.
Sunday,02,January,2022,16:36:05:32438
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: NEW PASSAT 8.5 MFSW + CCE 2021. OK!
Mileage: 58720km-36486mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO   Mileage: 58720km-36486miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000 CVN: 9A6217E3
   Coding: 001100D6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   ROD: EV_ECM12TFS021_VW25.rod
   VCID: 6A8D3FD44CF8023B195-803E
   VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D300401700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA7BB15-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9BD5D-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0711
   Revision: V0000000
   VCID: 3829D59C425460AB5F1-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670F600D39D0220400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D5033C7-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU003051200017821
   Coding: 18BC32
   Subsystem 9 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU010051200012315
   Coding: 18BC32
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28231708304294
   Coding: 308001
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71BF28B8612EF1E358F-8024
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E23B395-801E
   Serial number: 3575HRB405N1C4LI7929
   Serial number: 3585HRB405B1D5MS8GS2
   Serial number: 3515RRB405B17ABS901.
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F5326B-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC5274302B0F1-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   VCID: 2E05F3C4B090AE1B05D-807A
   Component: IMMO          H04 0805
   Shop #: WSC 00000 000 00000
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 010100
   VCID: 2A0DFFD48CF8C23BD95-807E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 F    HW: 1T0 035 686 f
   Component: RNS-MID       H27 6276
   Revision: AB001001    Serial number: VWZ6Z7T1727264
   Coding: 04000442040000A10001
   Shop #: WSC 33361 790 00118
   VCID: 372BD6A04F4A6FD356B-8062
   Subsystem 1 - Part No: 1T0 051 859 AS
   Component: EU West V17  8557
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA7130EB-807A
   Revision: --------    Serial number: --------------
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFD396B-8022
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FD356B-8062
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 L    HW: 7P6 035 730 L
   Component: TELEFON       H15 3200
   Revision: 1B001001    Serial number: 00007664158506
   Coding: 0501000000010110
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3B23CA9073E24BB3B23-806E
End----------(Elapsed Time: 02:05, VBatt start/end: 14.1V/14.1V)-----------
The next mod on my 6R will be in the same place where I am currently working on my wife's Golf, the room/compartment on the right side of the trunk, ... although the reason is very different.
I will be swapping out my current PDC 8K PQ25 unit...
... for a PDC 8K MQB unit ...
... something many of you have already done. E.g, viewtopic.php?p=576530#p576530 8) 🙏
My only reason, is to achieve "Automatic" PDC activation from the front parking sensors on my RNS510 screen, which is not possible with the PQ25 unit.
I am still waiting to receive the adapter wiring from Ali.
A priority 6 fault will hang on diagnosis, like the one that hangs from the Direct TPMS unit.
This does not affect the operation of all the functions of the vehicle. We will also live happily with this new priority 6 fault.🤦‍♂️😁
Harness adapter received...
Routine maintenance 🤭 before PDC unit swap from PQ to MQB.
After 10 years (+/-) with the Original RVC retrofitted in the VW emblem, ...
... the factory 325N Gas filled struts for tailgate have lost a bit of punch and sometimes the tailgate stops midway up.
I have decided to change them for other 350N Gas filled struts of homo-ABILUS STABILUS brand.
WWW.AUTODOC.EU
It is something I should have thought of ten years ago, but since I'm a bit slow, it has taken me 10 years to ponder this decision.
For my tailgate setup they work like the Originals without Original RVC installed on the tailgate 👌, however, it will take another 10 years to decide if I've taken the right decision for this change.
POLO 6R with "RNS510". Automatic activation of the PDC 8K system from the front parking sensors. OK!
To achieve it, the PDC 8K PQ25 unit must be swapped for the new PDC 8K MQB unit -5Q0- (see some info in previous post).
The new MQB unit must be flashed, parameterized, coded and adapted with the correct data. The identification of the correct data is included in the images below.
My new MQB unit was a nice gift from my dear friend Slavik.🤗
Installation of the new unit and Adapter harness.
Flashing the new unit. VCP.
Parameterization. VCP.
Coding and adaptation depends on your vehicle and personal tastes. See VCDS Autoscan, and Adaptation channels, at the end of this post.
With RNS510, and as far as I know, only the automatic activation of the front PDC sensors is possible without showing the OPS on the screen.
Video.
💎Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/FElTwZB0j ... autoplay=1 [----] :mrgreen:
Right at the beginning of the video the car goes forward towards a wall, the parking button lights up bright yellow and the mini front speaker for front sensors start beeping.
If your wish is to silence that continuous beep, you just have to press the parking button, ... so in my humble opinion the parking button still has an important function.
(@Patil -> 😁)
With RNS510 you also don't get the Park menu on the IC's MFD+.
See Patil's 6R post, with Discover Media PQ25, ...for comparisons. :arrow: viewtopic.php?p=576530#p576530
At this point just comment that we both have the same Instrument Cluster with the same SW, Patil did not edit the eeprom to display the new menu (park/maneuver).
Seems the old/new RNS510 (firmware) does not understand the data from the new MQB unit for front Optical Parking System (BAP protocol).
The automatic activation of the rear OPS works as before, when engaging the reverse gear.
Adaptation channels.
	SW:1K8-919-472-C   HW:5Q0-919-294-A ---  Park/Steer Assist
	Component:PARKHILFE 8K  H03 0480, Coding:0011191001
	EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
	Monday,07,February,2022,11:57:52:32438
	VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
IDE00001-Production mode,Deactivating ,3
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio lowering request,On ,1
IDE01170-Visual display for park assist,automatic ,1
IDE02332-Deactivate production mode,0 ,3
IDE03782-Switch-off speed for parking assist,15 km/h,1
MAS01426-Rear parking aid buzzer: volume,Stage 8 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
Elapsed Time: 00:05
VCDS Autoscan.
Monday,07,February,2022,12:51:03:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: PDC. MQB UNIT INSTALLED (FL,PARAM,COD/ADAP) TEST OK.
Mileage: 59600km-37033mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 59600km-37033miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331426800051
   Coding: 0011191001
   Shop #: WSC 00049 770 00107
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 230
                    Mileage: 59602 km
                    Date: 2022.02.07
                    Time: 12:48:57
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002204
   Revision: AA001001
   Coding: 010100
   Coding: 11260
   Shop #: WSC 00788
End----------(Elapsed Time: 02:04, VBatt start/end: 14.1V/14.0V)-----------
Super happy with my new Priority 6 bug. :lol:
I conclude this modification as a total success, I achieved exactly what I was looking for. 8)
I think I'm pretty sure I'm not going to swap my RNS510 for a DM PQ25, my wife's golf mods are more exciting now... 😊
6R 60000 km. Oil change and inspection.
The service expired by "time" due to the low use of the vehicle during the pandemic. I increased the time interval for the service by changing the values in the adaptation channels of the instrument cluster.
Today I decided to change the oil and check all the inspection points according to the maintenance indicated in erWin. I also reset the values for the next service with VCDS' SRI Reset.
Before...
After...
As I head to the recycling point, I check and add oil until I reach the MAX level on the dipstick.
Autoscan
Monday,21,February,2022,12:30:13:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: 60000 KM  OIL CHANGE / INSPECTION
Mileage: 60000km-37282mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 60000km-37282miles
   Revision: --------
   Coding: 01
   Revision: V0000000
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 0011191001
1 Fault Found:
12718592 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 1
                    Mileage: 60000 km
                    Date: 2022.02.21
                    Time: 12:27:08
   Coding: 00314D
   Coding: 140E01
   Revision: B9084001
   Coding: 002204
   Revision: AA001001
   Coding: 010100
   Coding: 11260
   Shop #: WSC 00788
End----------(Elapsed Time: 02:04, VBatt start/end: 13.8V/13.9V)-----------
From now on I allow all kinds of faults in the Autoscan related to improvements in the SW for better performance, Component Protection, and other inventions and fantasies... 🧙‍♂️😁
https://www.youtube.com/watch?v=GXUvCON ... DMM&t=170s
Enough for the 125 HP of my 6R.
Tomorrow.
60000km 👌 https://www.youtube.com/watch?v=yx_cq4MCHzc Platinum or Iridium. :lol:
I tried both, I recommend the Iridium ones, a slight improvement is noticeable 8) https://www.youtube.com/embed/sQdcjigAn ... autoplay=1
Ready2enjoy...🏎 😄
NEW Airbag model. Test.
Autoscan.
Tuesday,26,April,2022,09:47:34:32438
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDYOCICLO   License Plate: NEW MODEL OF MFSW AIRBAG. OK!
Mileage: 62190km-38643mi   Repair Order:
VIN: WVWZZZ6RZDY0CICLO   Mileage: 62190km-38643miles
   VCID: 6A8D3FD44CF8023B71B-803E
   Revision: --------
   VCID: 025D77745448FA7BD9B-8056
   Coding: 01
   VCID: 7EA5038420709E9BBD3-802A
   Revision: V0000000
   VCID: 3829D59C425460AB37F-806C
   VCID: 2D07F4C8BD16D503549-8078
   Coding: 0228DD
   Coding: 0200A3
   Coding: 1000A3
   Coding: 18BC32
   Coding: 18BC32
   Coding: 0011191001
   VCID: 372BD6A04FCA6FD33E5-8062
1 Fault Found:
12718592 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 77
                    Mileage: 62199 km
                    Date: 2022.04.26
                    Time: 09:44:24
   Coding: 00314D
   VCID: 4ACD9F542C38E23B51B-801E
   Coding: 140E01
   VCID: 47CBA6603F2A1F534E5-8012
   Revision: B9084001
   Coding: 002204
   VCID: 688945DC5274302B67F-803C
   Revision: AA001001
   VCID: 2E05F3C4B090AE1B6D3-807A
   Coding: 010100
   VCID: 2A0DFFD48CF8C23BB1B-807E
   VCID: 372BD6A04F4A6FD33E5-8062
   Coding: 11260
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA713665-807A
   VCID: 77AB16A00F4AAFD3FE5-8022
   VCID: 3B23CA9073E24BB3DAD-806E
End----------(Elapsed Time: 02:03, VBatt start/end: 14.1V/14.0V)-----------
3G0880201L ヾ(⌐■_■)ノ♪ 😄
6R (PQ25) / Golf 7.5 (MQB)
Reconditioning of Passat 8.5 multifunction steering wheel. Leather, Buttons frame and R-line logo.
During my winter/spring projects 2022 I purchased several/many MFSWs of the last models for one reason or another. Some of them not shown in my 6R and G7.5 topics.
Among all of them the one I show you below. Purchased on eBay, and according to the description, new but with some damage to the buttons frame and leather.
Renewed.
Leather.
I receive it at home, disassemble it and check the damages.
It feels new, unused.
- The damage to the leather is considerable and I decide to try to solve it. Recycle it, Renew it to be Reused later.
I buy the appropriate leather pattern (synthetic leather) with blue thread, also a logo R-line (old model).
Result of my work:
This blue stitching leaves a special feeling... 😊
Let's see how it looks when installed...
Tests in 6R (PQ25)
It looks gorgeous (IMHO)...
For proper operation the CCEmulator must be installed. :arrow: https://www.youtube.com/watch?v=nIwnWiBxOBY
It works like this...
All buttons work perfectly, as indicated in the image above.👌💎
Test in Golf 7.5 (MQB)
In the Golf (MQB) it is not necessary to install any emulator 😁, it is only necessary to have the appropriate equipment installed.
On my Golf, everything works perfectly after testing that the steering wheel contact detection works without problems due to the installation of the new leather... in fact, it works quite a bit better.👌 (... another diamond ...)
💎 Original Video :arrow: :arrow: :arrow: : https://www.youtube.com/embed/ssCCpbdEN ... autoplay=1
Updated previous post.
Locked
