Hello Vw lovers.
Now it is the time for the replacement of front camera 3Q0980654H series to the L series begins.
The first question I have is how to remove the current camera from its current location, and if the battery connection should be removed ?
When the camera is changed then it will be time to parameterize the camera with OdisE because it comes from a TRoc with 17 Kms.
The next thing will be to put the current long coding but adding a last pair of 00 to the byte string.
Then comes the calibration with the VAS 6340.
From Stock Golf 7.5 to….
Carolco
- Drives: Golf 1.4 TSI 7.5
Re: From Stock Golf 7.5 to….
- c1.jpg (101.88 KiB) Viewed 24791 times
- c2.jpg (125.72 KiB) Viewed 24791 times
Carolco
Continuing with the modification of the warning lights doors, I have found a coding that I find interesting in terms of safety.
It tries to turn on the rear brake light when the door on that side is opened.
The modification is made in the adaptations of the 09 Bcm. The channels to be adapted are Leuchte20BR LA71 and Leuchte21BR RC8.
We select Lichtfunktion B20 in this channel and introduce a value to choose between:
For the Leuchte20BR LA71.
-Tuerausstiegslicht hinten links (only rear door)
-Tuerausstiegslicht vorne links (only front door)
-Tuerausstiegslicht links (front and rear door)
We select Lichtfunktion B21 in this channel and introduce a value to choose between:
For the Leuchte21BR RC8.
-Tuerausstiegslicht hinten rechts (only rear door)
-Tuerausstiegslicht vorne rechts (only front door)
-Tuerausstiegslicht rechts (front and rear door)
And this is the final result….
- AE60DE5A-68FB-4F0C-9EFC-99A1B6E0FBF6.jpeg (673.7 KiB) Viewed 24669 times
- EFC8CA93-F83F-4407-91B6-7D5E579CF163.jpeg (294.4 KiB) Viewed 24669 times
Carolco
Hello everyone.
The pieces are arriving to adapt the steering wheel of the MK8 in my golf 7.5.
I already have the steering wheel and the airbag has just arrived.
The decorative piece of the lower part is missing, which is still in the middle ground of the Post Office.....
Hello Carolco,
Forgive me for insisting on the following matter:
Please do not use images from other forums or other people to illustrate your posts without referring to their origin. The correct thing is that you use links to the places where these images come from so that we know their authors.
Nobody here wants our forum to be accused of using/stealing images or information without making a clear reference to their authors.
We want to respect copyright as much as possible even if the authors do not have them legally recognized.
As moderator I feel compelled to remind you.
Thank you very much!
Carolco
Hello Fernando. How are you?
Sorry about the photos. They got very fast. The first one is taken out on my table. The second comes from a screenshot of a YouTube video that I found very interesting. And the third and fourth are from Ebay of the two items I bought. If you need more information let me know.
Thank you very much for everything and good luck in your future projects.
1- This is not personal.Carolco wrote: Fri Feb 25, 2022 4:18 pm Hello Fernando. How are you?![]()
Sorry about the photos. They got very fast. The first one is taken out on my table. The second comes from a screenshot of a YouTube video that I found very interesting. And the third and fourth are from Ebay of the two items I bought. If you need more information let me know.![]()
Thank you very much for everything and good luck in your future projects.![]()
2- Please don't try to insult my intelligence with that grotesque and unnecessary attitude that pretends to hide with pleasant words what you really want to say, ... or I'll show you how very tiny you are.
3- You'll only get one chance. You're warned.
Carolco
I have finally chosen to remove all the images from the last post I made..
I reiterate my sincere apologies.
