Thanks for the reply, as far as I know Ibiza only started to offer MFSW from 2016 and by then I think that's MQB platform but I found one post on another place that states:
if someone is interrested about MFSW for Ibiza 6J, I have tried new style steering wheel and its working fine in Ibiza 6J PQ25 platform with factory installed BCM 6R0937087H. Buttons backlight is working too.
You need to
1. replace only theese parts:
5f0880201J AAP / 6f0880201J AAP - airbag and mf buttons cable (orange)
7n5419091D - steering wheel
2. add two wires to steering wheel coil for 12V and LIN BUS
3. connect 12V cable to 12V from ignition switch [EASY]
and LIN-BUS cable to BCM [HARD JOB because there is little space arund the BCM under steering wheel]
4. remove original multi function module otherwise radio is possible to control only via multifunction module.
5. VCDS coding to enable MFSW
There are too much installation manuals for POLO 6R which have similar bcm and mf coil so it isnt needed write wirring installation manual in this thread.
7n5419091D is Alhambra 2016>>2013 and for Ibiza would be 5F0419091(x) so I think that the Ibiza one will also work.
- Capture.PNG (180.57 KiB) Viewed 16066 times
I have an Ibiza ST 6J8 2011 Ecomotive with Start/Stop and 6R0937088D BCM (higher than 6R0937087H from the post).
So... assuming that an Ibiza/ Leon/ Alhambra 2016>> steering wheel will work... I'll have to replace the right stalk with one without trip buttons (I have the original one because I myself retrofitted the trip computer after I bought the car) and also remove the Ibiza default MFSW stalk from the left side under the steering wheel and also remove it from the CAN Gateway Installation list so it will not conflict with the new wheel. Run the Lin wire to the BCM and +12v for the backlight in the wheel.
Will see if I can source a wheel and airbag and wire at a acceptable price in case this will not work...
A bit old but still relevant auto scan of my car:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 15 17 19 25 2E 44 4B 56 61 69 77
VIN: VSSZZZ6JZBR098475 Mileage: 206050km-128033miles
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J0000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AA HW: 03P 906 021 AA
Component: R3 1.2 DCM3.7 H04 9521
Revision: 12004001 Serial number: CVN: 876D4221
Coding: 00114014032401080000
Shop #: WSC 06402 785 00200
ASAM Dataset: EV_ECM12TDI03103P906021AA 001013
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 67DD0E9B9E6DDDB76E-8032
VINID: 9A38EAAAA19AA92880248107148D1F4F25
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 110224DB817600BA882924E981D600521300
Shop #: WSC 04941 000 00000
VCID: 071D2E1BB22D3DB78E-8052
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0320
Revision: 00 25 08 Serial number: 0000001205168-
VCID: 24475997E7DBF6AF8B-8070
Part No SW: 6R0 937 088 D HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0322
Revision: BU046001 Serial number: 0379 308100897
Coding: 3C880BE888210000002001F03F4B9C80CF80620F7E000449200000000000
Shop #: WSC 64564 324 38760
VCID: 3F8DF6FBAE7DB577F6-806A
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3110
Coding: 420000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3110
Coding: 420000
Component: VW10AirbagA09 H09 0020
Revision: -------- Serial number: 003GX00B6GBA
Coding: 003039
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00DF51-801E
Serial number: 3495RRB405T053R46OF-
Serial number: 3505RRB405T053R4C162
Part No SW: 6J0 920 802 J HW: 6J0 920 802 J
Component: KOMBI H05 0404
Coding: 110A00
Shop #: WSC 99999 123 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 2F6DA6BB761D45F766-807A
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 241010F1000096
Coding: 2532C2
Shop #: WSC 00000 000 00000
VCID: 3365AACB9235611702-8066
Component: IMMO H05 0404
Serial number:
VCID: 6ADB77AF8D7FE0DF71-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 6J0 035 342 D HW: 6J0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669377224
Coding: 020000
VCID: 254144932CE10FA79C-8070
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11231
Shop #: WSC 06402
VCID: 2F6DA6BBEA1D45F766-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441 A
Component: MF-Modul 0007 0001
Coding: 0000002
Shop #: WSC 77005 000 00000
VCID: 3169A0C3A829530770-8064
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 B HW: 6J0 035 153 B
Component: Radio G3 UL H56 0034
Revision: 0H001001 Serial number: SEZ1Z2I6324940
Coding: 0004040002
Shop #: WSC 04941 123 12345
VCID: 23455A8B22D5F197F2-8076
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 0303185A
VCID: 74E769D7D7BB262FDB-8020
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Serial number: 00000000009370264002
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000375465635
Coding: 0100000100000000
VCID: 306FA5C763235A0F7F-8064
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007666439460
Coding: 0200000001010110
Shop #: WSC 48178 001 104857
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 275D4E9B5EED1DB7AE-8072
End-------------------------(Elapsed Time: 02:19)--------------------------
PS: If you have any more input on this, please do share
