Sevytcho wrote: Thu Apr 14, 2022 11:55 am
hello ciclo, i have installed original vw full led directional headlights on my golf 7 gti facelift and wanted to know if the headlights can be coded using vcds software only or not? I followed your vcds coding (page 25 on the other tutorial), I no longer have a dashboard lighting error but I only have the high beams that work and I can't to enter in modules 4B and A5. I don't have the camera on the windshield can you help me please
As I already told you in the comments of the videos on youtube:
- You need to parameterize the 4B module with the appropriate file, you can do it with VCP or with ODIS.
- You need to code the BUS MASTER with ODIS.
- You need to flash the headlight control units with the flash files for VCP.
Everything is perfectly detailed in the
thread dedicated to my wife's golf. It is already a great luck for you and many to have that info.
VCDS can help you with the rest of the procedures and codings, as explained in my wife's golf thread.
I do not provide any type of file, if that is your intention. I'm sure there are people out there who can help you, although you can also obtain them through the appropriate channels (paying the subscription to VCP, etc).
You already know everything you need to know, a new answer from you in this thread is neither necessary nor appropriate.
Share info from your Golf and maybe someone wants to help you a little more.
