The OEM fog lights on the GTI 6C are quite cream don't match the headlights particularly well..
Has anyone replaced these with whiter-looking ones? Could you advise what sort I need or some fitting instructions?
thanks
Whiter fog lights - GTI 6C
2fast4ya
- Drives: polo 1.8 tsi gti bluetec
Re: Whiter fog lights - GTI 6C
Yes i have replaced the fog light bulbs to led canbus ones& they match the brightness of the headlights better, but it brought a error warning on the dash which was the usual phanton error as the fog lights were fine , the error kept coming on but i found a setting on the obdeleven tool that corrects that for when you change from halogen to leds .i dont get that error warning now .
CarbonChaos
I’ve changed mine for the same reason and found no errors occurred with these bought from eBay
https://www.ebay.co.uk/itm/2x-H11-LED-H ... 635-2958-0
CarbonChaos
2fast4ya
I notice on the link with the led fog lights you brought have a cabled adapter?
The ones i brought look like the original halogen ones but with leds
- B61799CB-93DD-41F2-96DB-81F014614192.png (3.18 MiB) Viewed 1426 times
- 4F437FDF-A57A-4ABA-9788-3B022F366C8D.png (4.9 MiB) Viewed 1426 times
- 74778B13-4A98-4B18-90B0-C47434D37E1F.png (3.21 MiB) Viewed 1426 times
- 98F3EEAA-DE04-4FB6-A2B4-B3B453078FE9.png (2.93 MiB) Viewed 1426 times
CarbonChaos
I Went for those because they have a heat sink and fan to remove heat from the unit and are quite compact , the actual ones I got are slightly different , the ones linked are similar but only 6000K mine were 6500K ,the ones you pictured have NO way of removing heat build up.
https://www.ebay.co.uk/itm/2x-H8-H9-H11 ... 635-2958-0
