How to remove moss ingress?
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
I’ve got water condensation inside both front fog lights and have got moss growing inside, is there anyway I can clean it? I’ve had a look and I can only see the small bulb inlet hole as the only entrance point to the inside of the reflector unit. Any suggestions?
CarbonChaos
Re: How to remove moss ingress?
Post by CarbonChaos »
You will need to remove both lamps ,you can then add some white spirit or similar and agitate with a small paint brush through the bulb apertures then allow to dry out completely.
IMO it’s probably going to come back because water/ condensation is getting in there, a more effective repair would be to replace them .
