So…I’ve been forced to replace my BNM engine due to a blown turbo which messed up my cylinders and pistons really bad.
After all the hard work is done, the one thing I forgot to document and can’t find anywhere on the web, is where does each vacuum line go?
I’ve linked a couple due to the length of the pipes but still have the rest to connect.
Anyone that has a schematic, the same engine that can trace the lines or any other input I would be extremely appreciated
Thank you
